Old Oct 10, 2012, 10:38 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Originally Posted by Atomic Skull View Post
The Ironic thing is that if Align takes notice of this and brings out their own they'll be copying Tarot.
Then again Align didn't seem to have a problem with copying the Compass FBL head when they "invented" DFC.
And that Compass head has to be the best looking piece of machined ally I've ever seen!
2Doggs is offline Find More Posts by 2Doggs
Old Oct 10, 2012, 03:42 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Much lower vibration than the Align style tailcase. Tight fitting bearings with no play but use some bearing retainer anyway because 10,000rpm could still potentially cause the bearing to spin in it's race. .
Hey thanks, I'll get a couple.
eagle777 is offline Find More Posts by eagle777
Old Oct 14, 2012, 03:49 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
My black tail assembly came without grease on the thrustbearings.
First flights on my Nightfly 450.... Super!
Tail feels smooth on control and the tailservo has a lower temperature after 6 minutes soft-3D.
Highly recommended upgrade!
sp00fman is offline Find More Posts by sp00fman
Old Oct 14, 2012, 05:48 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm glad to hear you like it as well.
Interesting to hear that there is no grease in the thread bearing. Could they have been lightly oiled? It's probably all that's required. I didn't remove my bearings to check the thrust bearings. I just put a small drop of scorpion motor oil into the thrust bearing, when I had the hub removed.
beenflying is offline Find More Posts by beenflying
Old Oct 15, 2012, 07:12 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The Tail Rotor Hub mounts to what size shaft?
Blade 400 tail shaft is 3 mm and Blade 450 tail shaft is 4mm ,just trying to decide how much trouble to adapt this one to a Blade 400.
Charles
Old Oct 15, 2012, 11:33 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
3mm, as used on all the Align 450's.
Old Oct 15, 2012, 12:52 PM
Southern Pride
Thanks that should make it super simple as long as the geometry ,ball size etc. are the same. The Tarot is inexpensive enough to make it a worth while upgrade for the Blade 400. I have the e Flite aluinum tail grips on mine but they do not use thrust bearings. I have a spare Blade 450 tail which I could fit to the 400 but would require more work.
Charles
Old Oct 15, 2012, 03:04 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
I've always thought the Blade style forked control arm was a much less sloppy way to move the slider than the Align arm, acting on a linkage ball on one side of the slider. A similar arrangement on my Caliber 50 nitro heli has virtually zero slop.
Old Oct 17, 2012, 12:24 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Another great source from ebay.
http://www.ebay.com/itm/Tarot-Thrust...item4608ec1386
ridge_racer is offline Find More Posts by ridge_racer
Old Oct 17, 2012, 02:39 PM
Southern Pride
Thanks for the link. $8 plus $1.50 so slow boat shipping but should be here in a month or so perhaps. Right now the Blade aluinum tail grip assembly with fresh bearing in it is doing great and now that I have replaced the DS75 cyclics with HS 5065MG on my 450 I will likely be flying it more than the 400.
Perhaps it is just a mind thing but the 450 just feels more solid in flight even if the 400 does have more power. B400 has a B 450 motor in it and the 450 has a 400 motor in it. Need to decide which one to put my Scorpion 2221-8 back into.
Charles
Old Oct 17, 2012, 03:13 PM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
Thanks. Ordered another one before everything is sold out
I like to keep an assembled and vibration checked tail with everything on ready to pop in as a spare.
Old Oct 17, 2012, 04:08 PM
jl449 is offline
Find More Posts by jl449
Salinas, CA
Joined Dec 2007
Charles
Pay a little bit more and get it here in the states!
LINK
I need to order one myself. I went thru 2 bearings already.
jl449 is offline Find More Posts by jl449
Old Oct 17, 2012, 04:14 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by ridge_racer View Post
Thanks. Another source at a good price.
Old Oct 17, 2012, 05:34 PM
Southern Pride
$8 plus $1.50 = $9.50
$13.50 plus $2.12 = $15.62 or $6 or 63% more total.
Charles
Old Oct 17, 2012, 05:36 PM
Joined Nov 2010
If you have a functionally tail then just wait and order from overseas...Most all my shipments from gogorc have been to my door in NYC within 10-14 days.
Discussion Will an EXI 450 belt tail work on a Tarot 450 FBL? kbohip Beginner Training Area (Heli-Electric) 1 Jul 25, 2012 06:33 PM
Sold 450 class metal tail assembly and 12mm CF tail boom with metal servo holders helitaiwan963 Aircraft - Electric - Helis (FS/W) 0 Feb 13, 2009 09:35 AM
Discussion Need help with finding a replacement tail-stepdown-gear-shaft bearing holder... (450) StarmanDXE Mini Helis 5 Apr 28, 2008 02:23 PM
Question Is there a replacement for the tail blade holder bearing? avt Mini Helis 3 Oct 03, 2007 09:30 AM
Help! Thrust Bearing In Blade Holder Assembly direstraits Fuel Heli Talk 7 Apr 02, 2006 12:14 PM
