Tarot 450 Thrust Bearing Tail Blade Holder Assembly
I received a silver version of the Tarot 450 thrust bearing tail blade holder assembly, from Infinity Hobby.
http://www.infinity-hobby.com/main/p...oducts_id=8794 http://www.infinity-hobby.com/main/p...oducts_id=8793 I've been waiting for someone to do this for some time, after having repeated failures of the outer bearing in the 450 tail blade holders. The main reason for this is the radial bearings are too close together, a common mistake Align makes. This unit uses bigger radial bearings with the thrust bearing in the middle, so you get the best of both worlds. The bearings are spaced out further, and the thrust bearings take the centrifugal load. To achieve this Tarot have had to reduce the hub center to the minimum possible and move out the blade holder screws by about 1mm. This means the blade diameter is now 2mm larger than before. This could also be a good thing, by slightly increasing the tail authority, albeit while increasing the tail loading, as well. When I ordered the silver version I was expecting a plain machined finish, but it's actually powder coated silver, and looks very nice! Tarot have done a really nice job of this unit. The quality is excellent, right down to the collar screws for the blades. Best of all, the blade holder hub screws can be done up tightly, without any binding or play. The only negative, the slot for the blades is a little on the tight side. I prefer a loose fit, with a slight tweak of the blade screw to give the blade some resistance in the grip. UPDATE: For the black version I received, the tail blade fit was perfect. Please note, the blade holder hub screws are not thread locked, so make sure you remove these and thread lock them. I used a toothpick to put a small amount of thread lock in the hub. Also be careful you don't lose the small washer on the screw. Additional pictures attached. Weathers pretty bad at the moment but will try to have a test flight tomorrow, before work. Update: Flight report: http://www.rcgroups.com/forums/showp...23&postcount=9 |
http://www.oomodel.com/tarot-450-pro...t-p-63647.html Test flight will have to be tomorrow now. The weather is looking promising for the rest of the week. Quote:
Hopefully I wont *crosses fingers, legs and arms*, but it's nice to know if I do, it will be easy to replace them.
Also, the heli it's going in does a lot of testing, so getting the leads more easily past the boom mount will make life much easier (I don't like messy wiring, even on a test heli). This heli is now flying with it's 3rd brand of FBL unit. Currently I want to change the tail servo in it, so that will happen at the same time the new boom mount goes in. |
Latest blog entry: RC Parts Suppliers - The Good and the...
WOW, i like that !! my tail has been acting a bit gritty, maybe its time to change to this one
Latest blog entry: NH airshow
Seattle Area
Joined Aug 2007
![]() I was going to buy a couple of these to replace the bad HK/EXI tail boxes in my current 450s, any opinions? http://www.infinity-hobby.com/main/p...oducts_id=6697 |
Here you go:
http://www.infinity-hobby.com/main/p...oducts_id=8794 Unfortunately already out of stock. That tail gear box looks like a really nice design.
oomodel also have it:
http://www.oomodel.com/tarot-450-pro...t-p-63999.html But the small amount extra at Infinity Hobby is worth it for the fast shipping and excellent customer service you get. |
Joined Dec 2011
| Thread Tools | |
| Discussion Will an EXI 450 belt tail work on a Tarot 450 FBL? | kbohip | Beginner Training Area (Heli-Electric) | 1 | Jul 25, 2012 06:33 PM |
| Sold 450 class metal tail assembly and 12mm CF tail boom with metal servo holders | helitaiwan963 | Aircraft - Electric - Helis (FS/W) | 0 | Feb 13, 2009 09:35 AM |
| Discussion Need help with finding a replacement tail-stepdown-gear-shaft bearing holder... (450) | StarmanDXE | Mini Helis | 5 | Apr 28, 2008 02:23 PM |
| Question Is there a replacement for the tail blade holder bearing? | avt | Mini Helis | 3 | Oct 03, 2007 09:30 AM |
| Help! Thrust Bearing In Blade Holder Assembly | direstraits | Fuel Heli Talk | 7 | Apr 02, 2006 12:14 PM |
