Old Jan 27, 2013, 12:30 PM
Romania, BV, Brasov
Joined Apr 2010
Hello,
I am surprised by these results. You got peak efficiency at speeds which seems for me too high for a 24N28P motor. I also wonder that you (and the manufacturer) recommend not so big propellers. Particularly, the last reviewed motor XM4010TE-7 is recomended to be used in the range of 10-16V with a propeller of up to 12x10.
Currently I am using the quite similar NX-4008 motor: http://hobbyking.com/hobbyking/store...ter_Motor.html, rewound by myself to have Kv=500rpm/V. (It can be compared to your last reviewed XM4010TE-7.)
The power supply is not 3-4s as recommended (for the original Kv=620rpm/V), but 2s and I use really big propellers: Aeronaut CAM 16x13 and even 18.5x15 (on Easy Glider). It performs very well and I fly usually 1h25' with 2s 3.3Ah.
Can you test one of them (let's say XM4010TE-7) at 2s to find out the peakeff for 2s? Or even for 6V? (because my rewound NX-4008 with Kv=500rpm/V supplied at 8V can be compared with XM4010TE-7 at 6V)
ViorelX is offline Find More Posts by ViorelX
Old Jan 27, 2013, 01:34 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi ViorelX
XM4010TE-7 @ 6V
6,01 V ; no load Io = 0,86 A ; 3853 rpm ; Peakeff 78,4%
taking Rm = 0,0920 ohm
Using Dualsky Calc 3.20 on XM4010TE-7 (motor #56)
http://www.rcgroups.com/forums/showthread.php?t=1078160
On 2S you could go to APC 17x8E at limit 18A
But you are far away from Peakeff
You need also some cooling, because temperature is the major actor
On your rewound 4008 (Kv 500 rpm/V) what is your mesured ph-ph resistance ?
Louis
Fourdan is offline Find More Posts by Fourdan
Old Jan 27, 2013, 02:10 PM
Romania, BV, Brasov
Joined Apr 2010
Hi Louis,
I got a ph-ph resistance of 85mOhms. If the motor is turned at about 3000rpm (with a lathe) a phase generate a 4.4V voltage and thus I determined a Kv of about 500rpm/V (actually, the lathe rpm may be of 2800rpm).
With the 16x13 propeller the static current consumption on full throttle is of 18A. After 1min of running the motor is still cold.
With the 18.5x15 propeller the motor takes 22A and warms up a bit after 1 min of run. It doesn't seem to me that it runs far away from the peak efficiency.
And, of course, I haven't had any problems with the heat inflight after long time running.
Old Jan 27, 2013, 03:16 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi ViorelX
Is your 4.4V peak (oscilloscope) or rms (AC DMM) ?
Louis
Old Jan 28, 2013, 01:06 AM
Romania, BV, Brasov
Joined Apr 2010
Not peak, I measured the rms value by a digital multimeter.
Old Apr 12, 2013, 08:52 AM
Joined Mar 2013
Neodymium grade
Great review, thank you.
What is the grade of neodymium? In for example XM5015TE-3.
Luxo is offline Find More Posts by Luxo
Old Apr 15, 2013, 05:04 AM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Hereunder is the reply coming from Dualsky HQ Shanghai after my asking:
The magnets for TE series are N42SH, the temperature grade is 150°C
Louis
Old Apr 15, 2013, 08:08 AM
Jack
USA, ME, Ellsworth
Joined May 2008
And here, at K&J Magnetics, are a couple of pages that present some handy specs for the various grades of magnets:
Neodymium Magnet Physical Properties - http://www.kjmagnetics.com/specs.asp
Pull Force and Surface Field Data - http://www.kjmagnetics.com/magnetsummary.asp
I can't vouch for the honesty or accuracy of all the info but to those of us that know little, it seems more interesting than knowing less...
Jack
jackerbes is offline Find More Posts by jackerbes
Wanted Futaba FG series GOLD FP-xx transmitter Boofer Aircraft - General - Radio Equipment (FS/W) 5 Oct 14, 2011 11:51 PM
For Sale triton jr good condition or trade for a mega mtor 16-15-xx series ED3 Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 29, 2010 07:00 PM
Sold Radial Mount for AXI 2212xx/xx Series NIP Bajora Aircraft - Electric - Power Systems (FS/W) 3 Aug 10, 2006 11:08 PM
Does anybody have any experience with the Mega 16/25/xx series Masterpiece Power Systems 14 Oct 30, 2003 11:04 AM
Anyone Use Mega 22/10/xx Series: BL for Kwik-E kelvin Power Systems 0 Nov 29, 2002 09:13 PM
