Espritmodel.com Heli Air
Old Oct 08, 2012, 07:49 AM
Joined Jul 2008
Originally Posted by metap0Pe View Post
Can you please link, so I am absolutely sure not to mess things up? :P
FrSky Module:
http://www.hobbyking.com/hobbyking/s...8FR_II_RX.html
Turnigy 9X:
http://www.hobbyking.com/hobbyking/s...Firmware_.html
LiPo Battery for the 9X:
http://www.hobbyking.com/hobbyking/s...utaba_JR_.html
Difference between mode 1 and 2 is where the throttle (non self centering stick) is located. On mode 1 it's on the right side, on mode 2 it's on the left side. Most people prefer mode 2, some countries traditionally use mode1, I never researched it, so I can't explain why....
Gh05trider is offline Find More Posts by Gh05trider
Old Oct 08, 2012, 08:32 AM
Merry Christmas... :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
Mode 1 throttle on right stick, Mode 2 throttle on left stick.
The link Gh05trider put up is probably the best simple solution to a really good radio combo along with the 9X. I run just the standard 9X on 2 multirotors. One with the FrSky module and one as the radio came from HK. They both work fine. I'm probably going to go to a second module for the stock setup just so I have failsafe.
Mark
KCV6 is offline Find More Posts by KCV6
KCV6's Avatar
Joined Aug 2009
LOL beaten too it by that much
I fly Mode 1 (most in Aus do)
Mark
Old Oct 08, 2012, 08:37 AM
Joined Oct 2012
Soo, with the combo linked will i have failsafe. And more important, what does this falisafe do LOL!
metap0Pe is offline Find More Posts by metap0Pe
Old Oct 08, 2012, 08:44 AM
KCV6's Avatar
Joined Aug 2009
Failsafe allows you to set a pre-determined "stick and switch" position setting should you loose bind. Say for example rather than a split second glitch you loose signal for a second or two, the RX will output what you set as failsafe. On my basic multirotor I have it set to middle stick and throttle just above hover. If you have GPS you can set it so it either position holds or returns to home.
Mark
Old Oct 08, 2012, 09:05 AM
Joined Oct 2012
Thank you very much Mark. I have made a new thread, and if you would chime in there, i would greatly apriciate it.
Old Oct 08, 2012, 10:36 AM
Hong Kong
Joined Sep 2004
I'm not going to recommend a brand, but look at your TX in this way. Treat your TX like a tool and your multis as the toy. You will eventually end up with many toys, but most probably the same tool to fly them with.
I always recommend anyone to touch and get a feel for their TX and try as many different TX as you can get your hands on. Check out the position and distance of the switches, everyone has different size hands.
Don't get too hung up on the quirkiness of the program software, they all require learning and once you get use to one...... you will be stuck with it.
I myself am a JR man. I also have the Turnigy 9x, so I would not consider myself a TX snob. I even once bought a Futaba 8, because I liked the feel in my hands. However I ended up selling before setting up my first model. The difference in the JR method of programming is just TOO different from the Futaba way..... real pity. Right now I use both the JR DSM2 module and the Frsky modules on my JR 11x.
dtm360 is offline Find More Posts by dtm360
Old Oct 08, 2012, 03:48 PM
Australia, VIC, Narre Warren South
Joined Jul 2012
Mode 1/2 determine which side has the throttle, easy to change which everyone you buy, instructions in the forum somewhere
(Ignore this, I missed page 2 where it was answered )
Zapphoid is offline Find More Posts by Zapphoid
For Sale Tower Hobbies System 3000 4 Channel Transmitter and Reciever mray Aircraft - General - Radio Equipment (FS/W) 1 Dec 10, 2012 07:31 PM
Discussion Got another problem, this time with my transmitter/reciever I_Am_the_Stig Off-road Cars 1 Jul 13, 2012 04:47 PM
Sold Transmitters and recievers SBP Aircraft - General - Radio Equipment (FS/W) 3 Jul 07, 2012 09:54 PM
For Sale 2 Airtronics transmitters and 3 recievers shannon1978 Aircraft - General - Radio Equipment (FS/W) 1 Jul 04, 2012 02:09 AM
Discussion Futaba Attack-r, which reciever? -james- Radios 2 Apr 21, 2012 11:05 PM
