Old Oct 08, 2012, 02:43 AM
akauts is offline
Find More Posts by akauts
Joined Sep 2011
Help!
artech su27
Hi, i need help on my su-27. im newbie in EDF, and bought an underpowered EDF last year, and then neglected it. last month i planned to make it fly, because it never flown. I purchase 2x64mm alloy EDF include 4300KV BL at HK, 2x 70a ESC and use 1x1800mah 4s 20-30c..... and the result was, it still cant fly
then i asked a friend to hand-launched it and the 1st and 2nd launch, but it still cant fly. questions:
1. where are the problems? does it need higher cells battery or?
2. how to calculate the CG for su27?
please help...
i recorded it, here are the videos
Sukhoi 27 Maiden 20121007-a (0 min 15 sec)
Sukhoi 27 Maiden 20121007-b (0 min 7 sec)
akauts is offline Find More Posts by akauts
Old Oct 08, 2012, 07:00 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Use the wheels! Let it get up to speed.
I used 4s 2200's on mine (RIP), and it pulled around 70A in total. Went OK.
Where is your centre of gravity? If it's constantly pitching up and down, chances are it's too far back.
Odysis is offline Find More Posts by Odysis
Old Oct 08, 2012, 01:01 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
PM answered.
ATIS is offline Find More Posts by ATIS
Old Oct 08, 2012, 08:29 PM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
You need speed before the EDF's become efficient and generate thrust. So you should launch the plane with a bungee cord (see attached video).
Bungee Launch No2 without frame (1 min 50 sec)
Secondly, looks to me that it's tail heavy. Try to move the batteries forward if you can.
djacob7 is offline Find More Posts by djacob7
Old Oct 08, 2012, 08:41 PM
akauts is offline
Joined Sep 2011
thanks for your info, i will try to move the battery forward. you're right seemingly problem on its CG. is it same with rc propeller plane? where the CG is 1/3 of Leading Edge?
Originally Posted by ATIS View Post
PM answered.
hi ATIS, thanks for all of you info. I read and will follow you suggestions in PM
Thanks djacob7, its great... the bungee cord should be the solution for me, because i cant find the longer runway here yet. And you're right, its tail heavy. so how to calculte CG for this kind plane (su 27)? is it 1/3 of Leading Edge?
Old Oct 08, 2012, 09:09 PM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
It's hard to define the leading edge on a fighter type wing because it's so slanted. I built two similar fighter jets so my guess at the CG is shown below.
Old Oct 08, 2012, 09:16 PM
akauts is offline
Joined Sep 2011
djacob7, Thank you very much --- finally you give me the solution for thing i was looking for so long
Old Oct 08, 2012, 11:52 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
"I purchase 2x64mm alloy EDF include 4300KV BL at HK, 2x 70a ESC and use (((((1x1800mah 4s 20-30c)))))..... and the result was, it still cant fly"
There's your problem. Or one of em. Plane will pull 70 amps total. Needs two batteries of this size or larger probably, or one 4000 20C approximately.
(Your battery is rated at 36 to 57 amps max....Probably killing this battery just running up the plane. And likely the airframe was designed to have more weight forward so you are running insanely tail heavy)
Michael Paxton is offline Find More Posts by Michael Paxton
Old Oct 09, 2012, 07:07 AM
akauts is offline
Joined Sep 2011
thanks for your advice, and i am now understand about the pull amp vs battery amp.
i will try to use 2 battery in order to provide more capacity when the ESC pull amps and to have proper CG.
thanks...
Old Oct 10, 2012, 08:32 PM
ATIS is offline
Member 120mph Club
ATIS's Avatar
I ran a similar set up in mine but on 3s 2500 (30C) lipo but I was using EFlite 400 (4200kv) inrunners on two 40 amp ESC's. Like I said in the PM, 4s 2500 (40c) lipo is about the smallest you might be able to get away with. A nice 4s 3200 (40c) would be better. Be carefully making room for the lipo as the foam around the intakes and turtle deck gets thin fast and a hard landing will break the nose off just behind the cockpit.
Old Mar 15, 2016, 04:03 PM
chillmoon is online now
Find More Posts by chillmoon
Canada, ON, Ottawa
Joined Apr 2007
stock power
My Su 27 is bone stock: uses only a pair of 18a esc from Artech, i use a 4s 1800mah battery, she flew fine, crashed a few times and now even with a ton of hot glue and tape, enough power to hand launch. Be care of using too much ESC and battery, they only weigh her her down. Flight time approx 3-4min.
chillmoon is online now Find More Posts by chillmoon
Old Mar 15, 2016, 04:05 PM
bandetlol is online now
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
4 year old thread bro
bandetlol is online now Find More Posts by bandetlol
Discussion maiden on artech 2500 fastfwd Electric Plane Talk 0 Aug 26, 2012 11:44 PM
Rant grumania SU27 KIT RUDE OWNER new2flight Trader Talk 16 Mar 22, 2012 08:51 AM
Discussion artech su27 flanker mike.v Foamies (Kits) 0 Mar 12, 2009 04:28 PM
Question Fiberglassing Artech su27 MitchDigger Composites Fabrication 0 Oct 16, 2006 09:32 PM
Question Fiberglassing ArTech su27 foamy MitchDigger Foamy EDFs 0 Oct 16, 2006 07:18 PM
