Old Oct 07, 2012, 10:35 PM
davidterrell80 is online now
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
Build Log
Bashing a GWS Zero into a Nakajima Rufe.
As per the title, I am bashing a GWS kit of the A6M2 Zero into the A6M2-N Rufe.
I'm going to keep the build log in my blog, linked here but, thought I'd drop a note in this forum, for those interested.
As I reach major milestones, I'll probably return here to post a picture but, the details of the build will be on my blog.
David
davidterrell80 is online now Find More Posts by davidterrell80
Latest blog entry: Ace Wing Cores
Old Oct 08, 2012, 02:22 AM
floss is offline
Find More Posts by floss
floss's Avatar
Auckland, New Zealand
Joined Sep 2005
Always liked the Rufe. Will be interested to see how she turns out
floss is offline Find More Posts by floss
Old Oct 08, 2012, 03:12 AM
Sopwith Mike is online now
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
Me too: in fact I got a kit just the other day with the very same intention! I was hoping to find a GWS float set to make it all easy, but no luck so far. The biggest challenge will be keeping the tip floats secure, I think!
I'm a great admirer of these little planes, having just done the Corsair with a small brushless motor.
Sopwith Mike is online now Find More Posts by Sopwith Mike
Old Oct 08, 2012, 07:41 AM
Joined Apr 2012
Mike, as I've started examining the kit in detail, I see that the incidence angle of the wing, at its root, is about 2 degrees relative to the axis of the fuselage, while the horizontal stabilizer and elevator is parallel to the fuselage axis.
Have you noticed the same in the Corsair? If so, how did you orient the motor with regard to down-thrust? Did you reduce the incidence angle in the wing saddle?
This is why I plan to assemble the and fly plane in a relatively unmodified condition, changing only the ailerons to a more scale profile, to allow for later addition of split flaps. I can counteract any tendency for the aircraft to "balloon" under power using a programmed mixing but, I want to see how pronounced the effect is... and will ponder the effect adding the floats will induce.
Cheers,
David
Old Oct 08, 2012, 01:39 PM
jhspring is online now
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
David, having cut my teeth on the GWS kits, the Zero was designed for brushed/nicads and as such the designers put in a fair bit of wing incidence. There are some long threads around about it, but all of us who went brushless took out the + incidence, either by shimming down the LE, or sanding the wing saddle to raise the TE. Very difficult to get it trimmed for power changes without adjusting it.
Looking forward to seeing your Rufe come together,
Regards,
Jeff
jhspring is online now Find More Posts by jhspring
Old Oct 08, 2012, 04:43 PM
Joined Apr 2012
Jeff,
You confirm what my "spidey-sense" was telling me. I suspect I will go the LE shim route, cutting away the wing fillet for now... building it back up later, when she's trimmed out.
With thanks and best complements,
David
Old Oct 08, 2012, 04:49 PM
Joined Aug 2004
I didn't change the Corsair at all, and added (then subsequently removed) some downthrust on my little 2812 motor. I like the way it flies and have had a lot of fun with it. I left the rudder fixed and really do not think that adding flaps is worthwhile on a model this small: I mean I know it is possible, but just don't think it adds anything except realism. But that's as good a reason as any I suppose!
I think the Rufe will need rudder (or maybe just a water rudder) to handle take-offs. I'll be very interested to see how you get on.
Old Oct 08, 2012, 07:19 PM
Wolpertinger is online now
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
I would omit the flaps. Flaps increase lift at low speed, yes, but another function of flaps is to be able to be able to make a steeper approach. Exactly what you don't want when water flying. Leave out the flap servo and associated linkages, and you will be a bit lighter, which is the best flap of all. I agree with Mike that a rudder will be essential with this model. I think this is a great project, by the way!
Wolpertinger is online now Find More Posts by Wolpertinger
Old Oct 10, 2012, 08:24 PM
scale_only is offline
Find More Posts by scale_only
on'tday eedfay ethay ollstray
scale_only's Avatar
United States, OH, Avon Lake
Joined Apr 2010
My build thread,, enjoy
http://www.rcuniverse.com/forum/fb.asp?m=9625739
actully just put it up for sale
scale_only is offline Find More Posts by scale_only
Old Oct 11, 2012, 09:53 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"The biggest challenge will be keeping the tip floats secure, I think!"
No. The biggest challenge is trying to get both tip floats out of the water before one of them pinwheels the plane. Been there, done that. And you don't really want the floats too secure, you would like them to break free in a botched landing.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Oct 12, 2012, 04:36 AM
Joined Apr 2012
I was thinking about the "tip float dig" issue last night. The scale floats have a "vee" cross section to reduce slapping. But I dont have a pilot to worry about. So, I'm thinking of flattening the bottom of the tip floats , leaving a scale side view and perhaps using painting to imply the scale shape from a distance... slightly shortening the strut length to allow more roll allowance... Perhaps even adding some transparent chines to the main float so it doesn't dig in so much.
Old Oct 12, 2012, 09:32 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
"Perhaps even adding some transparent chines to the main float so it doesn't dig in so much. "
Someone, somewhere, suggested that on a PBY, and I utilized it on my Albatross flying boat. Helped, a lot.
Les
Old Oct 12, 2012, 09:48 AM
scale_only's Avatar
Joined Apr 2010
It's more about angle of attack, you'll want to angle them up much more than the "scale angle" 3-views show, this lets them act like a water ski lifting the tip before it can dig in.
Old Oct 12, 2012, 10:47 AM
Joined Apr 2012
Good thoughts, all. I'm also considering one of the orange 3-axis stabilization devices. It might serve to counteract the wave-induced buffeting during takeoff and landing.
Old Oct 12, 2012, 10:57 AM
scale_only's Avatar
Joined Apr 2010
i surmised my problem with take off being I didn't glass the float, It was just painted and created too much friction, I might try to shoot it with some satin clear I have, but truth be told after burning up two ESCs playing with it I lost interest
Did you look over my build thread on RCU?
Discussion Nakajima A6M2-N Rufe LedKitty Parkflyers 40 Sep 03, 2014 10:24 PM
Discussion Nakajima Rufe as an ARF? JKinTX Waterplanes 19 Oct 07, 2012 09:49 PM
For Sale GWS Zero w/ Rufe conversion scale_only Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2012 07:27 AM
Gallery Nakajima A6M2-N Rufe (zero floatplane) prunner Waterplanes 0 Nov 07, 2009 09:25 PM
