Old Oct 07, 2012, 10:15 PM
ISRDAN is offline
Find More Posts by ISRDAN
ISRDAN's Avatar
Joined Jul 2007
Discovery plane Crash
Just wanted to be the first to say it.
shouldn't first class be in the back of the plane?
ISRDAN is offline Find More Posts by ISRDAN
Old Oct 07, 2012, 11:21 PM
flyzwell is offline
Find More Posts by flyzwell
flyzwell's Avatar
So Cal
Joined May 2008
But when there's turbulence the back of the plane is the bumpiest and they might spill their Chardonnay on their lobster.
flyzwell is offline Find More Posts by flyzwell
Old Oct 07, 2012, 11:54 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
R.h.i.p.
F.i.f.o.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Oct 08, 2012, 01:02 AM
flyzwell is offline
flyzwell's Avatar
So Cal
Joined May 2008
OK, rank has it's privileges, and first in out. They also take off first, but they are the LAST to land.
Old Oct 08, 2012, 01:18 AM
tinkering is offline
Find More Posts by tinkering
Shrinking the fleet
United States, CA, Carlsbad
Joined Jun 2012
I'd take the low noise level at the front of the plane any day (and the big seat, the drinks and the food that's actually edible). If it crashes I think you are almost toast anyway.
There's something reassuring sitting in the top deck of the Jumbo in the row behind the pilot.
I guess the days of being able to take a shaped charge on the flight so you can cut your own exit hatch in an emergency are well gone. Cutting your way out with a plastic knife is going to take too long.
Mick
tinkering is offline Find More Posts by tinkering
Old Oct 08, 2012, 01:26 AM
Dale Thompson is offline
Find More Posts by Dale Thompson
F3J-F3K-F3F- What to Fly??
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
But what's up with the short range of the TX/RX?
If they just ran a remote antenna they should have gotten more range than the
short distance they talked about.
Dale Thompson is offline Find More Posts by Dale Thompson
Old Oct 08, 2012, 01:37 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
They did pretty good considering they're punching a 2.4Ghz signal through a metal shell.
Easy to talk about a remote antenna on the Rx, but not that easy to implement.
If you try to put 2.4Ghz through say 30 feet of RG-58 cable, you're losing at least 10dB
of signal strength. Much higher loss in the tiny coax cables of the average 2.4Ghz Rx.
And then you still have to figure out where to actually run the antenna to get it outside the plane
easily so it's not totally blocked as you move from one side to the other (as they did).
I'd have chosen something like a long range UHF control system (such as we use on FPV planes)
but they were clearly trying to keep the system as simple as possible.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 08, 2012, 01:45 AM
flyzwell is offline
flyzwell's Avatar
So Cal
Joined May 2008
And if you do first class right you're already toasted so it might not be such a bad way to go.
Old Oct 08, 2012, 10:35 AM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
The plane crashes?!! darnit! I recorded it but haven't had a chance to watch it yet. Thanks for ruining Plane Crash for me guys!
-hutch
Hutch is offline Find More Posts by Hutch
Old Oct 08, 2012, 11:23 AM
mr_editor is offline
Find More Posts by mr_editor
Biting ankles since '53
No Pants Island
Joined Feb 2007
Nobody tell him about the snakes...
mr_editor is offline Find More Posts by mr_editor
Old Oct 08, 2012, 03:31 PM
Tick Point is offline
Find More Posts by Tick Point
Tick Point's Avatar
Joined Mar 2008
They landed thousands of feet short of the runway and at over twice the rate of descent as planned. Sounds like me!
But really, what's their excuse? Depth perception?
Dave,
not proud of the rc piloting on this one
Tick Point is offline Find More Posts by Tick Point
Old Oct 08, 2012, 03:42 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Actually their target descent rate was 2000fpm, and they impacted at 1500fpm.
In the context of the short "landing" one of the guys in the case plane made a comment that they
wouldn't have had a problem if they'd had the faster chase plane. My interpretation there
was that they started the initial descent and the 727 started to pull away from the chase plane
(risking loss of control) so all they could do was cut the throttle to slow it down a bit and pretty
much let it drop where they were (short) instead of flying it under power to the runway.
ian
Old Oct 08, 2012, 04:50 PM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Dave- all they'd need would be a thicket of telephone poles to ding their LE's to really simulate the slope experience.
slopemeno is online now Find More Posts by slopemeno
Old Oct 08, 2012, 10:56 PM
HahnSolo is offline
Find More Posts by HahnSolo
Great, kid! Don't get Cocky!
HahnSolo's Avatar
Joined Sep 2006
Seriously. . . they gambled millions of dollars and four years of prep work on an RC system that was only good for 50 yards?!? Then, to add insult to injury, they ended up using a chase plane that could just BARELY keep up with the 727. Slip out of that 50 yard range and it's all over. This had to be the most egregious newbie error I've ever seen on a project involving numerous scientists / engineers.
I won't even launch my slopers with less than a 75 yard range check. What the hell were they thinking? If 2.4GHz doesn't work, go back to a 72MHz system and use extendable whip antennas on both the Tx and Rx links. Unbelievable. . .
Solo
HahnSolo is offline Find More Posts by HahnSolo
Old Oct 09, 2012, 11:45 AM
alvinho is offline
Find More Posts by alvinho
United States, CA, Torrance
Joined Oct 2007
I couldn't agree more!
It would be interesting to hear what the explanation to that.
Also, If the range problem was caused by the fact the receiver was mounted inside the plane, why they didn't they just mounted it externally?
This is really unbelievable.
Solo
alvinho is offline Find More Posts by alvinho
Discussion ** crashed composite repairs, i can fix your expensive crashed plane xzatx High Performance 1 Feb 23, 2012 10:06 PM
Link ** crashed composite repairs, i can fix your expensive crashed plane xzatx Dynamic Soaring 0 Feb 23, 2012 06:39 PM
Discussion ** crashed composite repairs, i can fix your expensive crashed plane xzatx Sailplane Talk 0 Feb 23, 2012 06:39 PM
Help! CRASHED !! Discovery ST Model Plane Johann1975 South Africa 1 Sep 19, 2011 09:39 PM
