Old Oct 07, 2012, 07:07 PM
p47mayhem is offline
Find More Posts by p47mayhem
Closed Account
Joined Oct 2012
Hangar 9 P47 Thunderbolt 60
Any suggestions on a engine for this plane. Thinking zenoah 20ei, dle20, saito 100. Any suggestions will help and any suggestions on radio and servos will be appreciated. It also will have electric retracts. This is a new build so any previous builders of this aircraft feel free to chime in. I also would like to run a 4 blade prop if anybody has had a setup like that please assist.
p47mayhem is offline Find More Posts by p47mayhem
Old Oct 08, 2012, 06:00 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
A 20cc gas engine is an excellent fit for this plane. Won't need an after-market muffler, either. I have a 5 year-old H-9 P-47 with an rcgf 20, but would recommend the DLE as a better choice. Flies great and lands smoothly. Terrific airplane.
Lifer is offline Find More Posts by Lifer
Old Oct 08, 2012, 09:25 AM
Closed Account
Joined Oct 2012
Thanks man. What prop you swinging?
Old Oct 09, 2012, 05:34 AM
Lifer is offline
Kansas City
Joined Apr 2010
The rcgf likes a 16x6. The DLE uses a 16x8.
Old Oct 09, 2012, 07:25 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I have three of the H9 fighters all running .91 4-strokes. The power is good enough to get you out of trouble if needed. That 1.00 would be about right. All of mine came in under 9 lbs which helped a lot with the landing. The stock gear holds up ok at that weight. At 10lbs or over the stock gear dont do too good. But for good yahoo fun flyin, a 20cc should do it.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Oct 09, 2012, 10:22 AM
Closed Account
Joined Oct 2012
Thanks man real helpful.
Old Oct 09, 2012, 11:22 AM
JazzboneCuit is offline
Find More Posts by JazzboneCuit
JazzboneCuit's Avatar
Ontario, Canada
Joined Mar 2010
I have an OS .91 Surpass 2 in mine, and I find it a little (just a little) lacking in ummmph...If I we're to change it out I'd like to try a Saito 115 in it...
I have a DLE-20 in another plane that's 2lbs heavier and it hauls, so was apprehensive in putting it in the Jug...I think it'd be overkill, but it might be fun to try....
Jazzbone
JazzboneCuit is offline Find More Posts by JazzboneCuit
Old Oct 09, 2012, 11:30 AM
edwin1 is offline
Joined Sep 2003
Many years back I tried an experiment in a Rascal110 that I'd been running a saito 1.20 in. I put in a rcgf 20cc gasser. Performance wise it was almost exactly the same as far as power. The only difference was the added weight. I couldnt thermal anymore with the gasser. In a warbird, I would think a 20cc would do fine, but you gotta keep the structural strength in mind when putting a gasser in.
Edwin
Old Oct 11, 2012, 06:05 AM
Closed Account
Joined Oct 2012
Thanks for all your help.
Old Oct 16, 2012, 08:59 PM
rpstar is online now
Find More Posts by rpstar
rpstar's Avatar
Dacula, GA
Joined Feb 2008
Considering putting a DLE-20 in mine also. Was planning to go electric but now considering my first gas plane... I refuse to mess with nitro but gas I can do.
rpstar is online now Find More Posts by rpstar
Discussion Hanger 9 P47 Thunderbolt 60 Size Bigplumbs Fuel Warbirds 432 Sep 16, 2014 10:45 PM
Discussion Hangar 9 P47 Thunderbolt 60 p47mayhem Electric Warbirds 9 Oct 11, 2012 12:22 PM
For Sale Hangar 9 Thunderbolt 60 LPU ncflyer79 Aircraft - Electric - Airplanes (FS/W) 4 Oct 02, 2012 04:52 PM
Discussion Hangar 9 -P47 .60 Thunderbolt Electricc Conversion to Razorback Dadrulesathome Electric Warbirds 4 Dec 08, 2010 10:31 PM
Sold Hangar 9 P-47 Thunderbolt 60 ARF New!!! jetfan20 Aircraft - Fuel - Airplanes (FS/W) 1 Dec 08, 2009 06:52 PM
