Old Oct 07, 2012, 06:25 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Carbon Fiber Landing Gear
Hi All,
Anyone ever lay-up their own carbon fiber main landing gear?
I'm looking to make a one-piece to replace a 10-12 lb kit's aluminum gear.
- Fabric weight?
- how many plys?
- type epoxy resin used?
- worth the work?
Thanks!
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Oct 08, 2012, 06:32 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Never understood carbon gear.
why not fibreglass?
Odysis is offline Find More Posts by Odysis
Old Oct 08, 2012, 07:54 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
Not stiff enough for the weight.
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Oct 08, 2012, 08:25 AM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Someone might have better ideas than me, but your looking at a lot of money, time, and effort.
But! It could be done. You could make a quick mold from an existing gear. I'd use some 3k plain weave, and maybe some uni as well... You'd want some layers on the bias as well, for side loaded landings.
Does this help?
heliwill10 is offline Find More Posts by heliwill10
Old Oct 08, 2012, 08:33 AM
Odysis is offline
Joined May 2007
But carbon's not flexible enough to absorb any energy?
Do you have the kit's metal LG? If so, you can wax and lay up straight onto the for a 'mould'.
Other q's:
How many plys, and of what weight, are entirely up to you. How heavy can the part be, how rigid does it need to be? Multiple layers tend to perform better, so don't get a very heavy cloth.
What resin: Any laminating resin. Unfortunately, the more $$, the better they are to work with
Worth the work - unless it's a particularly strange aircraft, not really. Especially if you don't have the wax, pva, resin etc already. Set up costs can outstrip the component cost by a factor of 10 for small pieces like that.
Old Oct 08, 2012, 02:07 PM
Lawrence B is offline
Find More Posts by Lawrence B
Live and let Fly !
Lawrence B's Avatar
Mill Hill - London
Joined Aug 2009
My carbon U/C's were always way too stiff. Kevlar is better but it's a sod to process (cut / sand) post cure.
my glass only units have been the best compromise
Regards,
LB
Lawrence B is offline Find More Posts by Lawrence B
Old Oct 08, 2012, 02:24 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
I would build them from glass as well. Glass is tougher, has better strain properties, and better at absorbing impact than carbon.
If you don't have all the materials then the cost of making one will be rather higher. It would be cheaper to just go buy one.
wyowindworks is offline Find More Posts by wyowindworks
Old Oct 09, 2012, 09:34 PM
Wetafly is offline
Find More Posts by Wetafly
Joined Feb 2004
I have made quite a few now. From 2M F3A up to 3.2M IMAC. Had 1 failure due to not wrapping the uni carbon with cloth. This stops delamination. I have done build logs of these on FG username Rod.
Wetafly is offline Find More Posts by Wetafly
Old Oct 11, 2012, 01:40 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thank you gents.
Rod,
Are you in New Zealand? If so, I found you on FG, but did not see a thread on landing gear.
EJWash
Old Oct 11, 2012, 04:31 PM
Wetafly is offline
Joined Feb 2004
Originally Posted by EJWash1 View Post
Thank you gents.
Rod,
EJWash
Hi Sorry there is no thread dedicated to UC building. Each project has molded carbon gear and the process is imbeded in that thread. Have just had a look at the Miro F3A thread and here is the page with the UC build.
http://www.flyinggiants.com/forums/s...t=13974&page=7
Not much to it really these legs are still going strong.
Old Oct 11, 2012, 06:10 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Wetafly,
Thanks! Very nice work!
EJWash
Old Oct 12, 2012, 05:16 PM
doc993 is offline
Find More Posts by doc993
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Yes I used 1.7 carbon/glass.
doc993 is offline Find More Posts by doc993
For Sale CineStar 3-Axis 360 Digital Camera Gimbal Mount w/ Landing Gear Carbon Fiber FreeFly RASCO Aircraft - Electric - Helis (FS/W) 0 Jun 23, 2012 06:30 PM
For Sale Two piece carbon fiber landing gear with wheels sammydabull Aircraft - General - Miscellaneous (FS/W) 0 Apr 01, 2012 03:39 AM
Sold Blade MCP X Carbon Fiber Landing Gear TGKconnectors Aircraft - Electric - Helis (FS/W) 1 Mar 26, 2012 04:38 PM
Wanted Carbon fiber landing gear J. Wydronek Aircraft - Fuel - Airplanes (FS/W) 0 Mar 21, 2012 03:21 PM
Sold 1.20 size carbon fiber. Landing gear and tailwheel RCGill Aircraft - General - Miscellaneous (FS/W) 1 Mar 16, 2012 08:39 PM
