Old Oct 07, 2012, 06:10 PM
houseboat is offline
Find More Posts by houseboat
United States, OH, Blanchester
Joined Oct 2009
mcpx mods
Is it better to change out to the metal parts or just replace what breaks on the Mpcx ? Example I have broken main frame. Same one 9 dollars upgrade 46 dollars big differents I guess ! does it ready make a differents ? and is it worth the money ?
Thanks for any Ideals or opinions
houseboat is offline Find More Posts by houseboat
Old Oct 08, 2012, 05:22 PM
C6Silver is offline
Find More Posts by C6Silver
United States, WA, Seattle
Joined Sep 2011
The mCPX doesn't yell out "mod me" like other larger helicopters. I know people mod on the one hand to make something personal and all their own. However, from a utility point of view the mCPX doesn't really have much that I'd think would be worth it. There aren't that many parts to break let alone those you'd want to add weight and reduced flying time for. The tail is clearly the weakest link and really the only part I'd consider. Outside of that I think it is mostly bling. Again others will likely disagree particularly extreme fliers who are pushing the envelope in terms of what this thing can do (perhaps that is you as well). In short, the tail perhaps. Anything else, not really.
C6Silver is offline Find More Posts by C6Silver
Old Oct 08, 2012, 07:33 PM
Imzzaudae is offline
Find More Posts by Imzzaudae
Joined Sep 2011
My 2 cents
If you have been flying MCPX for more than a year, and have stopped crashing the helicopter. Bling-ing up your MCPX is a nice idea. But if you are going to do this,
Get the rudder fet replaced with the same one as the main motor not the small fet.
Then go brush-less with a 120SR tail so it has the power to handle the aluminum
upgrades and the tail to handle the power of the Brush-less motor!
Then make it look nice if you like.
If you are going to do it. Do it right or you will not like what you end up with.
Be prepared to drop $400.00 to $500.00 or keep it stock!
Imzzaudae is offline Find More Posts by Imzzaudae
Old Oct 08, 2012, 07:46 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I only upgrade if there is something specific I desired to fix. Mine flys nicely stock.
Roto Rob is offline Find More Posts by Roto Rob
Old Oct 09, 2012, 02:14 PM
Joined Oct 2009
Thanks for the info
only thing I want to do is make floats for it ,because i am at the lake alot,maybe add brushless motor just weight ?
Old Oct 09, 2012, 10:09 PM
fooferdoggie is offline
Find More Posts by fooferdoggie
United States, OR, Happy Valley
Joined Aug 2012
I upgraded to landing gear with tail boom supports as I have cracked three tail booms. also a metal swash plate and I have broken the balls off a couple of them.
fooferdoggie is offline Find More Posts by fooferdoggie
For Sale Modded MCPX V2 board with flashed XP-7A nartac Aircraft - Electric - Helis (FS/W) 5 Oct 07, 2012 12:47 AM
Discussion SR 120 tail mod on an mcpx aerojunkie Micro Helis 0 Sep 01, 2012 05:17 PM
Wanted WTT soft modded wii plus accessories for mcpx , mqx or ?? StampedTees Aircraft - Electric - Helis (FS/W) 4 Aug 12, 2012 04:37 PM
Discussion Modded Mcpx blades to prevent feather shaft bending d12bn Micro Helis 0 Mar 15, 2012 11:31 AM
Wanted Mcpx v2 brushless mod and lots of spare parts TMAC4123 Aircraft - Electric - Helis (FS/W) 0 Feb 24, 2012 08:02 PM
