Old Oct 07, 2012, 05:01 PM
groundman is offline
Find More Posts by groundman
Joined Jul 2012
my rolls are to slow
flying a crank yak, i think my rolls are to slow. what can i do to speed them up? thanks.
groundman is offline Find More Posts by groundman
Old Oct 07, 2012, 05:42 PM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
You can increase aileron deflection, increase the size of your ailerons or fly faster. Mix and match as you find necessary.
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Oct 07, 2012, 06:34 PM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
When you roll, add rudder to the same direction and a little elevator. It will not be very aligned, but your barrels will be fast as hell.
Gedexas is offline Find More Posts by Gedexas
Old Oct 09, 2012, 04:26 PM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
sounds like a snap roll
rtbates is offline Find More Posts by rtbates
Old Oct 09, 2012, 05:26 PM
cfircav8r is online now
Find More Posts by cfircav8r
You can't take the sky from me
cfircav8r's Avatar
United States, IA, Hampton
Joined May 2012
If you are fighting adverse yaw adding a little rudder will make it faster. increasing the throw may help but you do reach a point of diminishing returns. You should try adding a little rudder and see what that does before changing throw. If you do decide to add throw, do it in small increments until you don't see much change. I wouldn't go past 45 degrees throw though.
cfircav8r is online now Find More Posts by cfircav8r
Old Oct 09, 2012, 07:40 PM
Gedexas is offline
CP heli ≠ 3D heli
Gedexas's Avatar
Joined Mar 2009
I guess that's what it's called. I always assumed that a snap roll starts out horizontal and ends up vertical with the plane rapidly changing direction, but I may be wrong.
Discussion Walkera Mini Cp Flips/Rolls too slow? Jaydawgx7 Micro Helis 5 Jun 13, 2012 11:33 AM
Cool I think our motors are slowing things down Flyextreme High Performance 1 Mar 09, 2012 07:13 PM
Discussion my slow stick can do rolls steve ypsi mi GWS (Grand Wing Servo) 4 Aug 16, 2007 05:22 AM
Why my P-51D slow on rolling rate? peterjaw Parkflyers 4 Oct 31, 2004 10:25 PM
Zagi aerobatics-Slow Roll? 4 Point Roll? Balin Foamies (Kits) 9 May 02, 2001 11:30 AM
