Old Oct 09, 2012, 05:52 AM
cauley65 is offline
Find More Posts by cauley65
USA, DE, Dover
Joined Sep 2010
I have the senior tele, gas hog. flys nice, runs stright on take offs. no gyros. engine is off set to counter prop torque.
cauley65 is offline Find More Posts by cauley65
Old Oct 09, 2012, 02:39 PM
txflyboys2 is offline
Find More Posts by txflyboys2
txflyboys2's Avatar
USA, TX, Lancaster
Joined Nov 2004
Torque will always be the prime suspect, as it will pull a well-trimmed and aligned plane to the left on a takeoff roll. 2-3 deg. of right thrust and/or offsetting the vertical stab are often used to compensate for the left-pulling effect. The gyro idea should also work well as previously described.
As for looping, provided the wing is sound and reinforced in the center section with fiberglass tape, it should lazy-loop without a problem. I have flown Tele Sr.'s and every other size, starting in 1973 with an original German-produced kit.......that one was even more of a "stick" construction than the later slabbed versions. Nearly all had rubber banded wings. All looped, rolled and stall-turned without issue. I wouldn't advise holding full power through the loop.....I have always throttled back to about half at the top of the loop.
The ONLY time I have seen a Tele's wing fold was under experimental circumstances.........the bird was scaled up to have a ten ft. Wingspan and the fuse was lengthened and widened to hold a 2 gal. Fuel tank......it weighed 25 LB. wet and built to fly a loooong cross country flight (using a chase car w/transmitter). Disaster didn't occur due to looping though.....but while S-turning to lose altitude and over-banked/over-G'd at full throttle (it was being flown by a friend/owner&builder of the bird at the time). Consequently, around 20 lbs. Of fuel plus a 4000 mah nicad ( it was 1976) hanging below and in. The center of a 10 ft. WS is a formula for exactly what happened.........an even break in the center of the wing and a spectacular crash. Post mortem inspection revealed that the wing center section had NOT been reinforced with fiberglass tape.......only epoxied together.
So, built correctly and flown under stock parameters, the bird will handle looping without problems. If you wonder the reason for the "flying tail", that would lead me to still another account but for another post. Best regards with one of THE most enjoyable RC birds ever designed!
Larry
txflyboys2 is offline Find More Posts by txflyboys2
Old Oct 09, 2012, 02:54 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
I'm flying mine with a bolt on wing, tail, and struts. ~13 lbs. flying weight. Rudder and elevator are on pull-pull controls. The 5s 8000 mAH battery is almost all under the wing and it still feels a tad nose heavy. A very easy and lazy flyer. I easily get three 8 min. flights per charge. Wing struts are recommended for this version. Lots of info in this review and in some other threads here and on RCU.
http://www.rcgroups.com/forums/showthread.php?t=463310
Tim Wolff is offline Find More Posts by Tim Wolff
Old Oct 09, 2012, 04:34 PM
garrettt04s is offline
Find More Posts by garrettt04s
3d Master in Training
United States, PA, Tunkhannock
Joined Dec 2011
i only get about 8-10 min flight out of my 5s 5000mah pack
garrettt04s is offline Find More Posts by garrettt04s
Old Oct 12, 2012, 10:59 PM
txflyboys2's Avatar
USA, TX, Lancaster
Joined Nov 2004
Hobby Lobby's Telemaster Electro is slightly smaller with a 6 ft. WS and lighter than the 8 ft. Sr. My electro will deliver 15-20 min. flights with time to spare, on a 3s, 4000 mah and AXI 2820/14.
Larry
Old Oct 13, 2012, 06:47 AM
Joined Dec 2011
I like bigger lol
Old Oct 13, 2012, 03:47 PM
txflyboys2's Avatar
USA, TX, Lancaster
Joined Nov 2004
LOL! Yep, they're sweethearts, too! I flew two modified Tele's on cross countries.....one had a 10 ft. WS and the other 14 ft. They still flew like Tele's! Hard to beat 'em!
Larry
Old Nov 26, 2014, 08:09 AM
eggsplurt is offline
Find More Posts by eggsplurt
USA, NJ, Red Bank
Joined Sep 2010
Hey Garret.....Your left turning tendencies will be.....Torque.....spiraling slipstream.....gyroscopic precession......and what they call "P" factor.........in a nutshell, their is nothing wrong with your airplane. Physics dictates the need for right rudder on take-off.....you can't avoid it........and, it will be more prevalent based on the acceleration and amount of power added.......look these up and you will understand the dynamics.........no big deal man.........Enjoy that big Telemaster......Steve......N.J........
eggsplurt is offline Find More Posts by eggsplurt
Old Nov 26, 2014, 08:31 AM
LaxLife is offline
Find More Posts by LaxLife
USA, VA, Arlington
Joined Jul 2002
I converted and flew a Senior Telemaster for many years. 10s, Axi41xx gave it lots of power. I always started a new season flying this plane to get the cobwebs out. It could fly by itself for minutes at a time. Flaperons were programmed in to provide slower landings as she floated forever on warm days. I donated it to my Club's training program. Trainers are good but monster size trainers like this are GREAT, the size makes it fun and rewarding. Kids love flying a plane twice as big as they are.
LaxLife is offline Find More Posts by LaxLife
Old Nov 26, 2014, 12:13 PM
soarrich is offline
Find More Posts by soarrich
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
If you bend the axles so that the wheels are toed in or pigeon toed, your gound handling problems will go away.
What happens is that if the plane veers to the right:
The left wheel scuffs sideways.
The right wheel is pointed straight ahead, rolling easier.
The plane automatically swings back to the left.
soarrich is offline Find More Posts by soarrich
Old Nov 26, 2014, 05:31 PM
Joined Dec 2011
Thanks for the info guys
Old Nov 26, 2014, 05:32 PM
Joined Dec 2011
That looks just like my setup on the front lol crazy
Old Nov 26, 2014, 06:49 PM
soarrich is offline
Soarrich
soarrich's Avatar
Middletown, NJ
Joined Dec 2003
It is.
Old Nov 29, 2014, 04:51 PM
Joined Dec 2011
Here is mine
Article Hobby Lobby's Senior Telemaster ARF Electrified Review Steve H. Electric Plane Talk 45 Nov 26, 2014 07:41 AM
Sold HobbyLobby Telemaster SR LPU $275.00 eng30 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 16, 2012 08:09 AM
Sold Telemaster Sr. LPU Nashville, TN $325.00 eng30 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2012 08:05 AM
Discussion Sr Telemaster 2 piece wing Dad_Roman Fuel Plane Talk 2 Jun 20, 2012 05:15 AM
Wanted sr telemaster Plus 8 foot version chyorn Aircraft - Fuel - Airplanes (FS/W) 0 Apr 01, 2012 03:25 PM
