Old Oct 07, 2012, 04:56 PM
garrettt04s is offline
Find More Posts by garrettt04s
3d Master in Training
United States, PA, Tunkhannock
Joined Dec 2011
Sr Telemaster electrified
Picked up a high mileage old gas telemaster last week. Has the rubber band held wing setup. Wanted to do a quick electric swap over on the old lady. Installed an Exceed RC Rocket 4120-515KV Brushless Motor. Things rated at 1700watts. Im using a cheapy 100a hobbywing esc and a 5 cell 5000mah turnigy pack. Servos are all orange HK units. Used 4" standoff's and thread rod as the motor mount. Looks aside she flies like a dream once airborne. My question for everyone is how do I go about adding a gyro to the rudder for take offs? She wants to go one way or another on me when i start to gain speed.
garrettt04s is offline Find More Posts by garrettt04s
Old Oct 07, 2012, 05:41 PM
Eli Lipschitz is offline
Find More Posts by Eli Lipschitz
Joined Sep 2012
Just pick up a gyro and mount it with the correct orientation. You connect your rudder servo to the gyro, and the gyro to the rudder port.
Some inexpensive gyros (they will work fine) have the gyro gain on the gyro-however most gyros have the gain control on the transmitter. So, you will need an extra channel open so you can control the gyro gain from a knob on your transmitter.
It's easy to check if it works-wag the plane back and forth, and watch the rudder compensate. Adjust the gain for the sensitivity you would like.
Eli Lipschitz is offline Find More Posts by Eli Lipschitz
Reply With Quote  (Disabled)
Old Oct 07, 2012, 06:02 PM
Joined Dec 2011
thanks i have a few gyros from my 450 helis.
Old Oct 08, 2012, 12:21 PM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
probably where your landing gear are mounted. Fix the problem, don't band aide it.
Evan D is online now Find More Posts by Evan D
Old Oct 08, 2012, 02:25 PM
Joined Dec 2011
Im confused?
Old Oct 08, 2012, 02:26 PM
Joined Sep 2012
Do not forget to post photos. Telemasters are neat planes!
Old Oct 08, 2012, 03:14 PM
Joined Dec 2011
its not the best looking plane lol. Rather beat up looking but flies like a dream. I figured I would do all the cosmetic fix ups and recovering after I knew it was airworthy and had all the bugs worked out.
Old Oct 08, 2012, 03:37 PM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Originally Posted by garrettt04s View Post
Im confused?
Evan D is spot on with what he is suggesting. Any tail dragger could have handling problems if the main gear is located in the wrong spot, or a spot that puts to much plane behind the main gear. The closer the gear is to the CG with out tipping the better it handles on the ground. Also some are just not that good with the left thumb and a gyro really helps with that.
All of my tail draggers with handling problems were due to main gear placement.
Good luck
DAG
dag214 is offline Find More Posts by dag214
Old Oct 08, 2012, 03:44 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Good luck
DAG
Or alignment.
The Sr. Telemaster is a very good plane to train the left hand on.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Oct 08, 2012, 03:47 PM
Joined Dec 2011
funny thing is mine goes to the left on takeoff.
Old Oct 08, 2012, 04:27 PM
Joined Dec 2011
few pics
Old Oct 08, 2012, 07:24 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
try throttling up nice and slow, you'll still need rudder, but it'll be less sudden and easier to control. You might need expo on the rudder to keep from wagging like a fish on takeoff.
If you use a gyro make sure you have a way to turn it off in-flight.
ashdec87 is offline Find More Posts by ashdec87
Old Oct 08, 2012, 07:55 PM
Joined Dec 2011
Adding expo on the rudder is prolly a good idea. Im going to install the gyro this week and just have it switched on or off for takeoff
Old Oct 08, 2012, 08:55 PM
ant1 is offline
Find More Posts by ant1
United States, RI, Providence
Joined Sep 2009
We had a SR. Tele with a hot 6s setup,somewhere in the 1500 watt area.
A word of caution... our wings folded up when doing a power on loop. It was an older kit with no wing struts.
The prop chopped the wings up like confetti,looked like fireworks. So hilarious at the time,but I miss that plane.
ant1 is offline Find More Posts by ant1
Old Oct 09, 2012, 05:15 AM
Joined Dec 2011
Im not even going to attempt a loop. Dont trust all that weight on rubberbands
Article Hobby Lobby's Senior Telemaster ARF Electrified Review Steve H. Electric Plane Talk 45 Nov 26, 2014 07:41 AM
Sold HobbyLobby Telemaster SR LPU $275.00 eng30 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 16, 2012 08:09 AM
Sold Telemaster Sr. LPU Nashville, TN $325.00 eng30 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2012 08:05 AM
Discussion Sr Telemaster 2 piece wing Dad_Roman Fuel Plane Talk 2 Jun 20, 2012 05:15 AM
Wanted sr telemaster Plus 8 foot version chyorn Aircraft - Fuel - Airplanes (FS/W) 0 Apr 01, 2012 03:25 PM
