Old Oct 16, 2012, 05:15 PM
Joined May 2012
for hovering there are 3 of the 3-axis gyro nano acting on the commands vettoriabili fan, switching to straight flight, the gyro are disabled
f35vertical is offline Find More Posts by f35vertical
Old Oct 17, 2012, 06:08 AM
Joined Feb 2012
okok~ thanks a lot~
Is those gyro have to attached to the main fan??? or just attached to the body of the plane???
happysamuel is offline Find More Posts by happysamuel
Old Oct 19, 2012, 01:09 AM
Joined May 2012
2 gyroscopes, acting in two deflectors in the flow of the fan, the third party acts on the valve deflector minifan the queue for the control of the directional axis (rudder). The mobile plans, ailerons and cabra, not related to the gyroscopes
Old Oct 19, 2012, 04:39 AM
Moreno, credo che la domanda fosse se i giroscopi sono attaccati al condotto della ventola o se sono solidali con la fusoliera.
Moreno, I think the guy was asking wheter the gyros tilt with the fan or are solidal with the body of the plane.
Brandano is offline Find More Posts by Brandano
Old Oct 19, 2012, 09:50 AM
Joined Feb 2012
ok~ noted....
Besides, how do you know where is the CG of the airplane you used?? I have been thinking that the Fan should be put at the CG for proper hovering. Am I right??
And I just noticed the picture, there is a big, long red thing under the airplane and in front of the fan. What is that??
Old Oct 19, 2012, 05:30 PM
Joined May 2012
I tested the model in conventional flight before turning it into VTOL, when you find the CG, I have placed the fan. The gyro are in the fuselage, and at the bottom check the fan duct with its vettorabile that then, passing to the straight flight, rotates 90 degrees
In the initial part of the discussion there are detailed photos of the system fan.
Old Oct 25, 2012, 12:25 AM
Joined May 2009
f35 vertical
When the fan duct moves from "hover" to normal flight (90 degrees) is that moved with a servo or some other method
mavericko is offline Find More Posts by mavericko
Old Nov 04, 2012, 04:40 PM
Joined Apr 2010
Thrust vectoring motor mount(suprisingly simple stuff) (1 min 15 sec)
tomcon5 is offline Find More Posts by tomcon5
Discussion F35 vtol build thread (It works!) superchomper2003 VTOLs 40 Mar 06, 2013 11:18 AM
Discussion f35 VTOL vertical takeoff, straight flight, vertical landing f35vertical VTOLs 24 Feb 02, 2013 05:33 PM
Discussion First F35 mono edf vtol??? jetric Foamy EDFs 9 May 28, 2012 08:22 PM
Video F35 VTOL test #2 capt Electric Plane Talk 2 Aug 12, 2009 02:16 AM
Video F35 VTOL test capt Electric Plane Talk 0 Aug 10, 2009 05:09 PM
