Old Oct 07, 2012, 04:22 PM
f35vertical is offline
Find More Posts by f35vertical
Joined May 2012
F35 vtol from italy
Hello, I have made ​​30 flights a complete transition from vertical to straight, to improve directional control in hover I added a mini fan 27 mm at the rear. C is someone who has done something similar with a fan?
F35 VTOL FLY (1 min 22 sec)
f35vertical is offline Find More Posts by f35vertical
Old Oct 07, 2012, 06:08 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Great job!
So there is just one main ducted fan and one mini fan for pitch and yaw control?
It looks like there are vanes under the main fan. What do they control?
Anyone that has tried this type of transitioning VTOL craft knows it is not easy.
Congratulations on a fantastic project!
leadfeather is online now Find More Posts by leadfeather
Old Oct 07, 2012, 07:26 PM
Joined May 2012
The flight is assigned to the main fan, vettorabile in 2-axis swivel and 3 positions 0, 45 and 90 . a small fan 27 mm is placed in the queue and serves only for the control of the directional hovering
Old Oct 07, 2012, 07:49 PM
Winging it >
Joined May 2006
Do you think it is possible to remove the 27mm fan and use the vanes for yaw control?
Old Oct 09, 2012, 02:04 AM
Joined May 2012
I tried but the command in the stream carried away too much importance to the fans and was ineffective. Excellent system is to take a portion of flow to the fan with a tube of depron Please install a valve and a flow diverter for use as yaw control for hovering. see photos
I send you also a test drive with the model controlled by the tube depron visible under the fuselage, facing forward. The system is best for very low weight but less effective than the minifan. Moreno
F35 Vtol - From Vertical Take Off to Horizontal Flight di Moreno Lippi (1 min 8 sec)
Old Oct 10, 2012, 05:12 PM
sergiot78 is offline
Find More Posts by sergiot78
Joined Dec 2005
Very very nice
You are very good! congratulations
How long can you hover ? 3 mn ?
Do you use a 70mm EDf? Which battery
What is the weight of the model ?
Thanks for the answer
sergiot78 is offline Find More Posts by sergiot78
Old Oct 11, 2012, 02:23 AM
Joined May 2012
Thank you, range 2 to 3 minutes, total weight 900 grams, 70 mm fan. gens 2250 battery 4-cell, 58 ampere consumption in hovering.
Moreno.
Old Oct 11, 2012, 12:26 PM
happysamuel is offline
Find More Posts by happysamuel
Joined Feb 2012
Moreno.
May i ask how can the 70mm edf push more than 1kg?
I got a 70 mm edf with 5 blade using 4050 kv with 4s cell 14.8V but can only push
till around 700g my whole plane (F-35) weight around 900g~ can't even modify it to VTOL f-35......
Do you have any suggestions for me to make improvement?
happysamuel is offline Find More Posts by happysamuel
Old Oct 12, 2012, 01:27 AM
Joined May 2012
I've tried a lot of fans on the bench for more than 1 kg of thrust to be put in a cell more. I have fans with 3700 kv motor that gives me 1450 g thrust at 62 amps. Important not to make long flights otherwise burn the motor. Important to use good batteries, often after the first 5, 6 flights get older and do not raise more than the floor model! Take a test stand and controls thrust and consumption in watts. Moreno
Old Oct 13, 2012, 08:04 AM
lochead is offline
Find More Posts by lochead
Joined Oct 2012
Very beautiful!
lochead is offline Find More Posts by lochead
Old Oct 13, 2012, 11:49 AM
Joined Feb 2012
Do you know any website talking about duct fan, how to choose good blades with corresponding to motor?
Since i have totally no idea where to find them......
Old Oct 13, 2012, 04:22 PM
Joined May 2012
I do not know, I have done many tests whereas now the aeromodelling materials are cheap. 25 years ago it was different, everything cost so much and what they bought had to be good for strength ....
Old Oct 13, 2012, 05:00 PM
native18 is offline
Find More Posts by native18
Arkhangelsk, Russia
Joined Apr 2009
Good job.
What flight controller are you using?
native18 is offline Find More Posts by native18
Old Oct 13, 2012, 05:51 PM
swami is offline
Find More Posts by swami
swami's Avatar
Ursel, Belgium, Europe
Joined Jul 2001
You can find a lot here: http://www.jepe.org/indek.htm
Dirk.
swami is offline Find More Posts by swami
Old Oct 15, 2012, 11:08 AM
Joined Feb 2012
To: f35vertical
I would like to ask how did you derive the equation of motion of your f-35 since there are problems on the rolling and pitching problem due to disturbance from environment during hovering...
It is really a big problem to deal with, as you only got 1 edf to hover your plane...
Discussion f35 VTOL vertical takeoff, straight flight, vertical landing f35vertical VTOLs 25 Sep 09, 2013 06:57 AM
Discussion F35 vtol build thread (It works!) superchomper2003 VTOLs 40 Mar 06, 2013 12:18 PM
Discussion First F35 mono edf vtol??? jetric Foamy EDFs 9 May 28, 2012 09:22 PM
Video F35 VTOL test #2 capt Electric Plane Talk 2 Aug 12, 2009 03:16 AM
Video F35 VTOL test capt Electric Plane Talk 0 Aug 10, 2009 06:09 PM
