Old Nov 06, 2012, 03:12 PM
funty127 is offline
Find More Posts by funty127
Joined Jun 2005
Originally Posted by JoergSH View Post
Donīt know what You see. What is the problem???
I think some of the folks are confused to see the flash and baro chip on the pcb. Lilvinz's wiki post does not call for any other components to be added to the F3 board. I am guessing you are adding those based on the study of original CC3D. The question is though, will Vinz add support for these chips in his compiled binaries? Or, will the currently available compiled binaries run without any interference from these chips. My knowledge is limited on this.
Thanks to you for taking the initiative on the board design.
funty127 is offline Find More Posts by funty127
Old Nov 06, 2012, 03:44 PM
TSC21 is offline
Find More Posts by TSC21
Joined Oct 2012
My actual shield silkscreen layout! Done with Diptrace.
Added pull-up resistors for I2C and SPI interfaces for future use.
I'll send the top and bottom layer layouts when I'm sure it's working.
TSC21 is offline Find More Posts by TSC21
Old Nov 06, 2012, 05:53 PM
Menno is offline
Find More Posts by Menno
Joined Nov 2005
I love the effort that you are putting into this board design. I do find it confusing however that you name your file STM32F3 while the wiring is for the F4 board. The wiring for these 2 boards are not compatible.
Therefore it would be more logical to rename the file and post it in the F4 tread.
Meanwhile I am discovering that making a good board design is very time consuming. I am going to call it a day for now. Below are some images of my first attempt. Take it easy with me, it's still in the works
Menno is offline Find More Posts by Menno
Old Nov 06, 2012, 06:03 PM
JoergSH is offline
Find More Posts by JoergSH
Joined Nov 2012
Who say that my Board is wired for the F4 ??? The wires are for F3 Discovery!
JoergSH is offline Find More Posts by JoergSH
Old Nov 06, 2012, 06:27 PM
Menno is offline
Joined Nov 2005
I did not check all the pins, so I guess I made a mistake on that one.
Is there a reason that you shuffled the PWM out ports? The order is different than on the pin assignment in the wiki?
Old Nov 06, 2012, 06:39 PM
TSC21 is offline
Joined Oct 2012
Here are some 3D models of how it looks like right know:
PS: I saw that I didn't identify the input pins and the other power selectors. That situation is now corrected.
Old Nov 07, 2012, 01:49 AM
JoergSH is offline
Joined Nov 2012
You are right, there are 3 mistakes with the PWM out.
Old Nov 07, 2012, 03:01 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Why did you add the flash data chip, if there is no need (yet) on the F3?
msev is offline Find More Posts by msev
Old Nov 07, 2012, 04:27 AM
JoergSH is offline
Joined Nov 2012
I have seen it on all OP Schematics. So I added it. Must not be placed but could.
By the way, where to find the new OP revolution schematics?
Old Nov 07, 2012, 04:40 AM
JUERGEN_ is offline
Find More Posts by JUERGEN_
xxxxxxxxxxxxx
JUERGEN_'s Avatar
Deutschland
Joined Nov 2009
why not U-Batt?
or,
LIPO monitoring?
why not standalone 5V voltage converter ? LF50
JUERGEN_ is offline Find More Posts by JUERGEN_
Old Nov 07, 2012, 04:46 AM
msev is offline
Joined Sep 2010
I believe that OP revolution schematic is not yet available.
Old Nov 07, 2012, 05:16 AM
JoergSH is offline
Joined Nov 2012
Originally Posted by JUERGEN_ View Post
why not U-Batt?
or,
LIPO monitoring?
Hello Jürgen,
I would like to add that to my Board. You have Schematics for that?
Old Nov 07, 2012, 05:45 AM
TSC21 is offline
Joined Oct 2012
why not U-Batt?
or,
LIPO monitoring?
The board can be powered externally from the PWRSEL2 pins (5V and 3V).
You're saying me that I need to add a voltage regulator after ther external power supply pins so I can connect the LIPO battery directly to power the board? For the case of the BEC power there is no need.
LIPO monitor?
http://www.hobbyking.com/hobbyking/s...po_users_.html
Adding this circuit to the board will increase its size and I can't increase it much more... So you can add one of those above if you want.
Old Nov 07, 2012, 07:14 AM
TSC21 is offline
Joined Oct 2012
lilvinz,
Is there anyway to adapt the code to connect the F3 to Raspberry Pi with the SPI interface?
Old Nov 07, 2012, 07:38 AM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
Is it possible to design the board so that it's about the same size as the f3Discovery?
I've downloaded DipTrace to give it a try but I'm a software guy, never tried to design a pcb.
I like where you are taking this JoergSH be really cool if we can get revo running with gps for ~$30
VArchT is offline Find More Posts by VArchT
New Product DIY OpenPilot based FlightControl (F4) lilvinz Multirotor Electronics 271 Jan 04, 2015 05:58 AM
Sold High quality DIY openpilot-compatible controller kanchana Aircraft - Electric - Multirotor (FS/W) 43 Oct 21, 2012 10:56 AM
New Product zeroGravity - An STM32 Flightcontroller based on PIPO32 hardware Jessestr Multirotor Talk 40 Jun 25, 2012 08:18 PM
For Sale High quality DIY openpilot-compatible controller kanchana Aircraft - Electric - Multirotor (FS/W) 0 May 27, 2012 03:46 AM
