Old Nov 06, 2012, 07:01 AM
JoergSH is offline
Find More Posts by JoergSH
Joined Nov 2012
Originally Posted by ala42 View Post
I had a look for that. PA10 I2C2_SDA and PF6 I2C2_SCL, is correct.
PB6 SCL/PB7 SDA is I2C1
JoergSH is offline Find More Posts by JoergSH
Old Nov 06, 2012, 07:09 AM
JoergSH is offline
Joined Nov 2012
I hope you move the 3-pin connector to the side, as they do not help you under the board
Also add a 5V voltage regulator and add pins that allow to connect a I2C sensor board, e.g. for a barometer. That could be placed below the CPU board.
In the Moment I planed to fit the connection on the botton side. So the PCB can be smallest as possible.
A barometric chip is on the Board, possible to solder direct or with a DIL8 Adapter.
A 5 V regulator I will place
Old Nov 06, 2012, 07:17 AM
ala42 is offline
Find More Posts by ala42
ala42's Avatar
Germany
Joined Jan 2011
If you want to use I2C2, than remap both lines to port F and do not use PA10, which is the default USART1 port RX line used by the CPU built in boot loader.
ala42 is offline Find More Posts by ala42
Old Nov 06, 2012, 07:50 AM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
Not to look a gift horse in the mouth but horizontal pins off of one of the short edges would make for cleaner wiring IMO.
VArchT is offline Find More Posts by VArchT
Old Nov 06, 2012, 08:00 AM
JoergSH is offline
Joined Nov 2012
No Problem, I open my mouth wide
But I donīt understand what You want? I think You want to change Position of the in and output jumpers. I think I will do that.
@ ala42. That is the Pin witch Vinz used in his Documentation. Everything could be changed in the Moment.
Old Nov 06, 2012, 08:17 AM
tacitapproval is offline
Find More Posts by tacitapproval
Joined Mar 2012
FYI--For those in the US, F3 board is now instock at Digikey.
tacitapproval is offline Find More Posts by tacitapproval
Old Nov 06, 2012, 08:26 AM
VArchT is offline
SoCal
VArchT's Avatar
Joined Oct 2011
Yep, in and out connectors to the edge with something like
Old Nov 06, 2012, 08:58 AM
jihlein is offline
Find More Posts by jihlein
Albuquerque, NM
Joined Aug 2002
Thanks for the heads up, 2 on order......
jihlein is offline Find More Posts by jihlein
Old Nov 06, 2012, 11:45 AM
JoergSH is offline
Joined Nov 2012
Wow sold out
Old Nov 06, 2012, 12:14 PM
Menno is offline
Find More Posts by Menno
Joined Nov 2005
for those in Europe, Rutronik.com has some on stock in the German warehouse.
they have an old picture in the catalog but it is there articlenumber TOOL3470. (i already have received 2 boards from them and it's the correct board)
The only thing is that you need a valid VAT number to buy from them.
Menno is offline Find More Posts by Menno
Old Nov 06, 2012, 12:23 PM
robert b is offline
Find More Posts by robert b
Switzerland, Aargau
Joined Mar 2011
Hi robert,
this will be possible when the board is finished .
I started yesterday evening, please be patience
Joerg
hi joerg,
this is good news.
i am extremely bad when it comes to soldering.
and some sort of fpu is urgently needed.
best robert
robert b is offline Find More Posts by robert b
Old Nov 06, 2012, 12:28 PM
robert b is offline
Switzerland, Aargau
Joined Mar 2011
on stock here as well.
need also to grap 2
Old Nov 06, 2012, 12:39 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Originally Posted by Menno View Post
Isn’t this for the F4Discovery board?
I’m also drawing a PCB board in Eagle CAD for the F3Discovery. This is slow progress however because I have never worked with these kind of programs before. I will try to post my progress tonight when I get home.
I also think the same (since it has that flash chip) ? Or are we seeing maybe something wrong ?
msev is offline Find More Posts by msev
Old Nov 06, 2012, 02:39 PM
JoergSH is offline
Joined Nov 2012
I planned this layout now.
I added ESD protection for the Inputs.
Now there is a lot of more free space.
I think a 5V Regulator is not needed. The OpenPilots have none.
Old Nov 06, 2012, 03:02 PM
JoergSH is offline
Joined Nov 2012
Donīt know what You see. What is the problem???
New Product DIY OpenPilot based FlightControl (F4) lilvinz Multirotor Electronics 271 Jan 04, 2015 05:58 AM
Sold High quality DIY openpilot-compatible controller kanchana Aircraft - Electric - Multirotor (FS/W) 43 Oct 21, 2012 10:56 AM
New Product zeroGravity - An STM32 Flightcontroller based on PIPO32 hardware Jessestr Multirotor Talk 40 Jun 25, 2012 08:18 PM
For Sale High quality DIY openpilot-compatible controller kanchana Aircraft - Electric - Multirotor (FS/W) 0 May 27, 2012 03:46 AM
