Joined Nov 2005
I am still working on the soldered print board that I am going to use to attach the F3discovery to my quadcopter. So instead I used some balsa wood and female jumper wires to temporarily mount the board. Below is a video of my first flight in the park. This is with basic settings and I think there is a lot to improve but nevertheless it's looking good.
![]() Thanks to lilvinz for all his hard work in this.
Joined Nov 2005
The first picture is from my temporarily build balsa wood cradle. I connected everything with female jumper wires. I would definitely not recommend this for permanent usage but it was an easy way for me to discover the board and experience how flyable it was (and it's looking good ).The second picture is of the empty PCB board and the connectors. I have made a lay-out of the pins that should be connected. http://www.lumivo.nl/temp/f3protoboard.pdf. This link is also in the wiki on the page of the F3 pinasignment. The third picture is my board with the PWM inputs soldered to it. Unfortunately the solid core wire that I ordered seemed a bit to rigid for this job and the isolation of the white in the picture melts at a low temperature. Therefore it is taken more time for me than i anticipated on. Seeing the results of my first flight I think I am going to order myself some PCB boards from oshpark or seeedstudio. That way there won't be any soldering the wires left. Maybe this is going to be interesting for more people? |
But after seeing Vinz' first spaghetti board made me step back until someone comes up with a solution that even guys like me can handle.
No, it is PB6 SCL/PB7 SDA, see http://www.st.com/internet/com/TECHN...DM00063382.pdf
![]() Also add a 5V voltage regulator and add pins that allow to connect a I2C sensor board, e.g. for a barometer. That could be placed below the CPU board. You could also add some resistors for voltage deviders connected to free analog inputs for voltage and current measurement. |
| Thread Tools | |
| New Product DIY OpenPilot based FlightControl (F4) | lilvinz | Multirotor Electronics | 266 | May 17, 2013 07:27 AM |
| Sold High quality DIY openpilot-compatible controller | kanchana | Aircraft - Electric - Multirotor (FS/W) | 43 | Oct 21, 2012 10:56 AM |
| New Product zeroGravity - An STM32 Flightcontroller based on PIPO32 hardware | Jessestr | Multirotor Talk | 40 | Jun 25, 2012 08:18 PM |
| For Sale High quality DIY openpilot-compatible controller | kanchana | Aircraft - Electric - Multirotor (FS/W) | 0 | May 27, 2012 03:46 AM |
