Joined Oct 2012
If you please explain me those I'll send you a board layout file so it can be posted in your wiki and used to create a PCB of your board. Thanks! Regards, TSC21 |
So without software support for the UART builtin inverter, usage of an external one is still necessary |
Joined Oct 2012
Anyone?
I was just able to make a pre-layout of the board. It has to be a double side pcb so it can keep a small size and doesn't have a huge amount of jumper wires. Just waiting for someone to help with the USART of Flexiport equivalent, Mainport equivalent, (Receiver Port equivalent!?), or other possible connectors... lilvinz can you help me with those, please? You're using USART3 for Flexiport and USART4 to Mainport but you have a 3rd connector in your perfboard? Is it just a simple USART that is unused? What about Mainport equivalent pin SBUS_ENABLE (PD7)? Is it necessary or not, since we have a built in inverter on F3 USART? If necessary, where does it fit in the configuration of the USART connector you gave (with the +3V/+5V selector)? Thanks! |
Joined Nov 2005
Finally received my F3 boards today. The supplier had send them to the billing adress instead to the shipping adress (my home
)Can't wait to load the Openpilot firmware to this board. I will also upload a schematic drawing of the PCB print. I still have some doubts on the proper way to power this board. If you have servo's connected to the board (e.g. tricopter or camera gimbal) while it's powered throught the USB connector of your PC you are likely going to draw a lot more than the alowed 100 mA. I think the most simple solution is putting a diode between the + 5v pin of the ESC and the board. Anyone else got thoughts on this? |
Joined Nov 2005
it's alive.
At first I could not get the CGS to recognize the board. It was because I still had the USB plugged in to the USB-ST link connector. After I connected the board with the USB user connector it recognized the board right away. Now of to building the PCB board with the PCM in and outputs. |
Joined Nov 2005
hmm, i have connected everything on the board using female jumper wires (soldering the pcb board is a bit more work than i thought). All connections look ok. I can calibrate my transmitter channels etc. but......... right now the setting are not saved to the board. Whenever I cycle the power al my settings are gone. Does this have anything to do with the jumper setting of the ST-Link,
Can anybody help on this? |
Joined Nov 2005
Nope I have tried everything that I can think of.
- First I flashed the F3 board through the ST Link USB connector ( bl_disocoveryf3.bin file) - After that I start the CGS firmware. - CGS only recognizes the board if I connect it to the user USB connector. So I switch the cable. - I can than push the rescue button, select fw_discoveryf3.opfw file and flash it to the F3Discovery. - The board reacts to movement and I can callibrate the RC input and motor outputs. All seems fine. I can push disconnect in the bottom of the CGS, connect again and it will remember the settings. However, once I disconnect the USB or push the black button on the F3discovery board al the settings are forgotten. What am I missing. Why will it flash the firmware but refuse to write the settings? Is this a jumper setting or do I need to connect both USB plugs at the same time? (I hope not because I only have on mini USB (who still uses mini USB when everything is micro USB) |
Joined Nov 2005
I have tried the 2 latests from the Github downloads:
discovery_20121101_b8eb2d56e8 discovery_20121024_3152318bc9 I have also loaded the firmware on my second board. No wires attached, just flashed the firmware and connected it to the CGS firmware. It does exactly the same thing. I can flash FW on it but I can't write settings to it. As soon as the power is cycled the flighttime returns to zero and all settings are gone. Is it also normal for the CGS to only recognize the board through the user USB connection? It does not recognize the boards through the USB ST Link. |
| Thread Tools | |
| New Product DIY OpenPilot based FlightControl (F4) | lilvinz | Multirotor Electronics | 266 | May 17, 2013 07:27 AM |
| Sold High quality DIY openpilot-compatible controller | kanchana | Aircraft - Electric - Multirotor (FS/W) | 43 | Oct 21, 2012 10:56 AM |
| New Product zeroGravity - An STM32 Flightcontroller based on PIPO32 hardware | Jessestr | Multirotor Talk | 40 | Jun 25, 2012 08:18 PM |
| For Sale High quality DIY openpilot-compatible controller | kanchana | Aircraft - Electric - Multirotor (FS/W) | 0 | May 27, 2012 03:46 AM |
