Old Dec 18, 2012, 06:30 AM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
thanks Bruce abbot
after encountering many difficulties with version 12f675 (a lot of glitches on the signal processing), I decided to use version 12f617
I have ordered buy the chip 12f617
I'll start work as soon as I have it
fantasy1988 is offline Find More Posts by fantasy1988
Old Dec 20, 2012, 06:13 PM
Joined Oct 2012
hi Bruce abbot
version 12f617
signal pulse 1.8ms full forward ,1.45ms -1.55ms neutral position and 1.2 full reverse
If signal pusle 1.8ms - 2.2ms or 1.2ms - 0.7ms is cut off ?
How do I do when my radio joystick max 2.2ms and min 0.7 ms?
it will be cut off if I move the joystick signal exceeds the limit
Old Dec 21, 2012, 09:35 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Standard pulse width range is 1~2mS, but I have generously allowed 0.7~2.3mS. If your radio produces pulses outside this range then it is faulty and needs to be repaired.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Dec 21, 2012, 11:29 PM
Joined Oct 2012
really, hard for me
Old Dec 22, 2012, 03:18 AM
Joined Jan 2001
really, hard for me
Fixing your radio is too hard?
You can modify the source code to accept a wider pulse range. Just change the limits (highlighted in the code fragment below) to whatever values you want.
Code:
;             Servo pulse measured. Check for good pulse
EndOfPulse:	btfsc	Flags,BadPulseFlag
		goto	BadPulse
	     	cmpi16	ServoCount,700
                skpc
                goto	BadPulse
		cmpi16	ServoCount,2300
                skpc
		goto	MoveThrottle
Old Dec 24, 2012, 06:16 PM
Joined Oct 2012
Hi bruce
I bought the new tranmiter and receive , and it can adjust the pulse is limited.
I do not understand a few places of the program version 12f 617
; 'Beep' the motor
Beep: return
and
RaStop:
; call Beep ; Play a 2KHz 'beep' sound through the motor
ENDIF ; throttle arming
I did not hear any tone from the motor?
Old Dec 26, 2012, 06:50 PM
Joined Jan 2001
It's a silent tone, inspired by John Cage's classical composition 4′33″.
But seriously...
Someone asked me to remove the arming sequence, so the 'beep' subroutine became redundant. I couldn't be bothered writing a version for the 12F617. Perhaps you would like to try?
Old Dec 27, 2012, 06:46 AM
Joined Oct 2012
I think the tone emitted from the motor is really interesting, it shows professional features of esc . I wanted it
For some people, adding to the tone seems redundant, because they do it to meet their temporary needs. but in the long run, I think they're going to buy at Hoppy store.
actually, I love to hand made the device in rc., but I do not understand much about the program for PIC or AVR . i will try more
I also want to pay to write the program for you instead of always "thank you "
.but I do not know how, because I'm in ASIA
Okay, I was just wondering small program to create tone.
 I will check the version, and hope you respond when I get stuck
wish you happy new year
Old Dec 29, 2012, 08:24 AM
rc my life is offline
Find More Posts by rc my life
Joined Nov 2012
you same me ,,but really language for Pic complicated and abstract
rc my life is offline Find More Posts by rc my life
Old Jan 04, 2013, 04:09 AM
Joined Oct 2012
help me Bruce Abbot
I detection my radio limits pulse max is 2.5ms .So the circuit is cut off beyond 2.3ms pulse
I can change the program like this?
Code
goto BadPulse
skpc
goto BadPulse
cmpi16 ServoCount,2500
skpc
goto MoveThrottle
Old Jan 04, 2013, 05:28 PM
Joined Jan 2001
help me Bruce Abbot
Yes.
However it might be better to have a slightly higher limit (eg. 2600) to account for possible variations in your radio's maxiumum pulse width.
Old Jan 08, 2013, 05:38 AM
future88 is offline
Find More Posts by future88
Joined Oct 2012
hello Bruce Abbot
Simonk wrote the program esc brushless (sensoless ) for the car, it consists of forward, reverse, brake. but the brake mode is in neutral position
you can change the brake mode like your esc brushed?
I ask Simonk help, but he did not understand the mode brakes for car
actually, there are many people interested in this issue, we hope you help
thank you very much
future88 is offline Find More Posts by future88
Old Jan 09, 2013, 02:08 AM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Btw, I was playing around with kapteinkuk's "BrushESCV3" brushed firmware for normally brushless ESCs (from here: http://www.rcgroups.com/forums/showt...1649270&page=2 ) on an RCTimer 40A ESC with ir2101 drivers. I think these drivers may depend on the FETs being off occasionally to keep the gate capacitor pumped above Vbatt. I noticed with a bigger motor that it seemed to work fine, but it kept cutting out about once a second with a smaller motor. Anyway, maybe that code may already do kind of what you want for brushed motors?
Brushless is a whole other animal though and should probably be in another thread..? With brake mode disabled entirely, hitting reverse while going forward still ends up braking (the same as it would with a brushed motor), but it's not as smooth since the timing tracking keeps skipping around. It can be quite a bother to do sensorless detection of motor direction to determine when to actually go reverse, though. I have a Hobbywing car ESC one that seems to do just to it by a timer.
simonk is offline Find More Posts by simonk
Old Jan 21, 2013, 11:05 AM
jankraak is offline
Find More Posts by jankraak
Joined May 2008
bruce is it possible to put a asm file on the forum with no brake''s
I need it for my modelship.
I made your speedcontroller and it works fine.( the first model of your site)
Now I read that there is a lot more in the asm file.
So what i need is a controller with all in it ( As failsave, low voltage and no brakes)
is there also a new scheme and board?
thanks
jankraak is offline Find More Posts by jankraak
Old Jan 23, 2013, 10:57 PM
Joined Nov 2012
version 12f675 .failsave,low voltage , no brake (v0.1 to v0.5 )
Discussion Ebay 320amp brushed esc and car starter narxer Power Systems 7 Aug 20, 2012 11:31 AM
Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors SARCFAN Dock Talk 5 Jul 02, 2012 11:58 AM
Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo fly_right Cars - Cars and Parts (FS/W) 6 Apr 14, 2012 07:39 PM
Discussion Replacment brushed ESC for the NitroRCX drift car. B dog Electric Power Cars 5 Mar 06, 2012 08:20 PM
