Old Dec 02, 2012, 08:04 PM
Joined Oct 2012
I have checked the circuit using ir 2101,
result is that only the bottom FET working
FET above does not work . I'm having trouble
fantasy1988 is offline Find More Posts by fantasy1988
Old Dec 06, 2012, 03:24 PM
Joined Nov 2012
how did you test it?
what frequency are you using in IC 2101:HIN,LIN?
does the bootstrap cap is big enough?
have you tried to check that all your IC is working?
"only the bottom FET working
FET above does not work"
how do you know that?
*IC- Integrated circuit
goly is offline Find More Posts by goly
Old Dec 06, 2012, 10:02 PM
Joined Oct 2012
thank you, I'm really disappointed with the new circuit ir 2101
 I killed many things: 3 ir 2101, 8 fet 3205 and 1 chip 12f 675
I have abandoned this design
Old Dec 07, 2012, 06:02 AM
Joined Nov 2012
you use schematic circuit with ir2184, it is work well
it use two input : PWM and ON/OFF
rc my life is offline Find More Posts by rc my life
Old Dec 07, 2012, 08:23 AM
Joined Oct 2012
hi Bruce abbot
blink frequency of LED version 12f 617 near 1s., but sometimes I see LEDs blink very fast, I do not know the error is due design my circuit or for some other reason?
why is capacitor 50p? I replace by 100n capacitor, result is pic does not receive the input signal
future88 is offline Find More Posts by future88
Old Dec 07, 2012, 11:56 AM
Joined Nov 2012
you may try to use pnp npn h bridge instead
less efficient but works great, i have one on wildthumper
pnp- of the same type as the npn at the high side of the h bridge
it uses IC-4027 to drive the mosfet and IC-AND gate for PWM speed ctrl
Old Dec 07, 2012, 01:52 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Originally Posted by future88 View Post
hi Bruce abbot
Not an error. The LED toggles on and off for every 8 bad pulses. If there is no signal the pulse measuring routine times out after 33 milliseconds, and the flash rate is quite slow. But if there is interference the pulses can be very short and rapid, so the flash rate will be a lot higher.
Its purpose is to bypass high frequency interference (eg. RF output from a 27MHz transmitter). If the value is too large then it will also filter out the throttle signal!
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Dec 08, 2012, 12:52 AM
Joined Oct 2012
you can show me the command line makes the LED flashes quickly.
I only see the command makes the LED flashes slowly
BadPulse:
ifdef FAILSAFE
movi16 MIDTHROTTLE,ServoCount ; set to neutral
endif
incf BadPulseCount
movf BadPulseCount,w
sublw 7
skpnc ; toggle LED every 8 bad pulses
goto bp_done
clrf BadPulseCount ; reset count
btfss GPIO,LedBit
goto bp_LED_on
bcf GPIO,LedBit ; Toggle Status LED
goto bp_done
bp_LED_on: bsf GPIO,LedBit
bp_done:
Old Dec 08, 2012, 01:49 AM
Joined Jan 2001
It's the same code.
The rate at which the LED flashes is dependent on how long the code takes to measure the servo pulse. Normally that will be around 10 to 20mS (depending on the frame rate of your receiver), but the LED doesn't flash when there is a good signal.
If no pulse is detected then the 'Measure' subroutine will time out after ~33mS, and the flash rate will be 8*33mS off, 8*33mS on, ie. about 2 flashes per second. This is the normal 'no signal' response.
However, if you are using an AM or FM radio and the receiver picks up interference, then it may put out a lot of short pulses. The LED will then flash on and off 16 times slower than the average frequency of those pulses (which could be several kHz).
This behavior is good because you can tell the difference between interference (fast flash) and no signal (slow flash).
Old Dec 08, 2012, 08:19 AM
Joined Oct 2012
thank you,I had given up all
Old Dec 09, 2012, 01:19 AM
Joined Oct 2012
thank Bruce abbot
why your website have not comment for the viewer?
you should integrate this feature, I am very interested
Old Dec 11, 2012, 09:12 AM
Joined Nov 2012
I have write a small program in version 12f617
create tone "beep" when the loss signal.
create tone "beep beep beep" when the set is complete for neutral
but I'm having difficulties in interrupt of PIC, pic do two jobs at once."Blinking leds and create melody "
I'll post the asm file, hope people will help me
Old Dec 15, 2012, 07:39 PM
Joined Oct 2012
I think, 12f 617 program has completed, you should use it, because change program is very difficult
Old Dec 17, 2012, 12:37 AM
Joined Oct 2012
hello bruce abbot
I using the program winpic 800 ( jdm propramer ) to load the hex file for 12f675
during the loading of software appear notice of the alternative addresses for pic: select YES or NO. ?
I do not understand, and it seems to affect the certification of the neutral position of the signal pulse
I loaded the program for two pic 12f675. but a neutral position in two different places.
Old Dec 17, 2012, 03:48 AM
Joined Jan 2001
Sounds like it is overwriting the osccal subroutine at address 0x3ff, so you must select the other option which doesn't overwrite it. For the PICs you have already burned, you can determine the correct calibration value using the circiuit and code found here. Alternatively you could just try different values until you get close enough to 1500uS.
If you decide to change it manually then the following information may help:-
REGISTER 2-7: OSCCAL — OSCILLATOR CALIBRATION REGISTER (ADDRESS: 90h)
bit 7-2 CAL5:CAL0: 6-bit Signed Oscillator Calibration bits
111111 = Maximum frequency
100000 = Center frequency
000000 = Minimum frequency
bit 1-0 Unimplemented: Read as '0'
example:-
ORG 0x3ff
RETLW 0xfc ; osccal value = maximum frequency (b'11111100')
Discussion Ebay 320amp brushed esc and car starter narxer Power Systems 7 Aug 20, 2012 11:31 AM
Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors SARCFAN Dock Talk 5 Jul 02, 2012 11:58 AM
Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo fly_right Cars - Cars and Parts (FS/W) 6 Apr 14, 2012 07:39 PM
Discussion Replacment brushed ESC for the NitroRCX drift car. B dog Electric Power Cars 5 Mar 06, 2012 08:20 PM
