Joined Nov 2012
when the boat is running high speed, if you want to change the direction (mixed signal as diagrams), two motor will spin in opposite directions. and the boat will turn 180 degrees.
the result is flipping boat if you want to run two motor boats, you need to install the feature mix the signals site built circuit control two motor for boats, http://julnet.ch/index.php?option=co...iques&Itemid=2 and this is the most perfect motor control circuit, but it is very difficult to implement http://evei.ru/?p=1623 ![]() ![]() ![]() install software
Joined Jun 2005
Hello Bruce,
I found the program by chance your esc with google, I deeply studied the code, but I'm too little scholar asm for it alone tonight and I found this topic, I'm happy. I would like an electronic servo output in amps for very beefy engine up ice in car, the H-bridge works well in replacing that there is a servo usual but I have problems with the code . The engine must withstand a permanent exit, so he growls, I said that the pwm should be weaker on reaching the equilibrium position, it can not do it because not enough power to combat stress. should therefore test whether the theoretical position is reached after a certain time, first time send more power and eventually stop even if it is not reached. I thought a pic 16F676 for the highest number of legs to keep the low battery detection. http://ww1.microchip.com/downloads/e...Doc/40039F.pdf Using a potentiometer as AS5045 is a plus as would choose the race or several rounds. http://www.ams.com/eng/Products/Magn...5045-Downloads Like for openservo http://www.openservo.com/ and in http://www.rcmart.com/hitec-premium-...h-p-31665.html burned ! but AS5045 is good :-) The project is too hard for you ? For me, sure !!! Excuse my english, google traduction is my friend |
Joined Oct 2012
hi Bruce abbot
I tested this new version brigde 17 v0.2, results error mode of loss of signal or bad signal (use led flash ) does not work when not turn tranmiter, it is only set up when turned tranmiter If the joystick is in forward or reveser position. turn tranmiter, car will run forward or reverse immediately use one LED to indicate the mode, forward brake, revese use three leds very difficult to design the circuit. you can change the program so that it becomes more complete thank you |
Joined Oct 2012
I have use both versions in a long time, until now, V 0.8 use 12F675 is best for me., and I'm trying to modify a mode signal loss program like 12f 617 V.0 2 (use the lED flash)
V.0.2 use 12f 617 encountered some difficulties in restarting the neutral position, but pwm pulse signal is good, it makes the engine less heat and less noise |
| Thread Tools | |
| Discussion Ebay 320amp brushed esc and car starter | narxer | Power Systems | 7 | Aug 20, 2012 11:31 AM |
| Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors | SARCFAN | Dock Talk | 5 | Jul 02, 2012 11:58 AM |
| Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo | fly_right | Cars - Cars and Parts (FS/W) | 6 | Apr 14, 2012 07:39 PM |
| Discussion Replacment brushed ESC for the NitroRCX drift car. | B dog | Electric Power Cars | 5 | Mar 06, 2012 08:20 PM |
