Joined Oct 2011
Using a chip with hardware PWM is the best choice, then we could change the PWM frequcncy to meet the request. I checked the 12F617 datasheet. It has one ECCP module, but only half bridge output. If the chip has full bridge output, it will be easy to replace 12F675. I am not sure how to generate 2 PWM output to drive the 2 N-MOSFET. Using PWM (Enhanced Mode) CCP1/P1A, switch the output between TRISIO2 and TRISIO5? Br, Sam |
However it should be possible to use half-bridge mode, which applies PWM to both the low-side and high-side FET(s). The alternate pin function then switches both P1A and P1B outputs, to provide forward or reverse with synchronous rectification. Single PWM mode will still be used for braking. The pin assignments are almost the same as in my current circuit, so I should be able to use the same pc board with one minor modification (pins 2 and 7 must be swapped). |
All the suppliers that I deal with stock both chips, but the 12F617 is significantly cheaper. |
Joined Oct 2012
hi Bruce Abbott
I've been using your new program V 0.7. use mode slows down the motor, but I have difficulty with this change when I brake, than 1.2ms pulse, mode brake operation ineffective, the motor continues to run. program should maintain the motor speed when bad signal before the return signal good (not restart) it does not restart when the signal is bad, but you just maintain its speed instead slows down when using mode slows down the motor, I usually move the joystick in neutral position, and the car becomes out of control with the sudden acceleration forward or backward when the returned signal good . (1.8ms or 1.2ms) if this change does not affect program implementation you please correct it I hope you can help me finish this, and forgive me for bothering you Again thank you,wish you health |
Joined Oct 2012
I built the circuit diagram, using the program V0.7 of Bruce abbot
just a little hard on the pulse signal bad , it is nearing completion.i have used it for old car HSP 1/10 bec 5v 3a lm2576 use mc 34063 generate 20V power supply, driver circuit h-bridge circuit through opamp lm 324 .. fet 3205 may result in saturation (20v - 7,2v to 12,8v ) have brake,forward,reverser ( program v0.6 or v0.7 of Bruce abbot ) |
Joined Oct 2012
noise from the motor brushed 540 are great, its spikes hanging pic or kill pic. I think this circuit uses low power and small size motor.
I admire the ability to write Bruce abott program, I stopped viewing your site, there are many applications for RC, it was really helpful hope to see construction projects esc brushed your use 12f617 chip, it's really perfect for brushled motor control applications with the leg create pwm available |
Secondly, make sure that the power supply wires feeding the 5V regulator are not passing motor current. The + and - wires going to the FETs should be separate from the wires going to the regulator (only joined together at the battery input terminals). To reduce voltage spikes, you should install a large low ESR electrolytic capacitor across the battery input terminals. Here is the first draft of my code for the 12F617. Using hardware PWM enables frequencies down to 250Hz with excellent stability. In the next release I hope to improve accuracy of the input pulse measurement (have to figure out how to get Timer1 gate working properly on the alternate pin input). NOTE: attached hex was produced in 'simulate' mode (no low voltage cutoff, no arming). |
Joined Oct 2012
thank you for sharing
I will resist the impulse noise from the motor 540 for your pic by the way new version using 12f617 chips, I saw a brief program and PWM control more flexible than previous versions I will test, and error checking of the program I saw your website, and I see you use two motors for boats, by connecting in parallel, ![]() if I want to use two separate motors with mixed signal functions, this schematic can work well? ![]() mixer from radio transmitter, or use separate circuit |
If the transmitter doesn't have suitable mixing functions then you can plug a v-tail mixer into the receiver to get the same effect. |
| Thread Tools | |
| Discussion Ebay 320amp brushed esc and car starter | narxer | Power Systems | 7 | Aug 20, 2012 11:31 AM |
| Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors | SARCFAN | Dock Talk | 5 | Jul 02, 2012 11:58 AM |
| Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo | fly_right | Cars - Cars and Parts (FS/W) | 6 | Apr 14, 2012 07:39 PM |
| Discussion Replacment brushed ESC for the NitroRCX drift car. | B dog | Electric Power Cars | 5 | Mar 06, 2012 08:20 PM |
