Old Oct 07, 2012, 11:24 AM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
Diy esc brushed for car
hello, esc brushed on http://homepages.paradise.net.nz/bhabbott/bridge.html
i use very good,but it is no brake,because i donot know write ASM for 12f675
help me diy esc brushed car with break
thanks you very much
fantasy1988 is offline Find More Posts by fantasy1988
Old Oct 07, 2012, 11:34 AM
Joined Oct 2012
help me
Old Oct 07, 2012, 08:48 PM
Joined Oct 2012
hi,this is board esc brushed 7,2v
Old Oct 07, 2012, 09:19 PM
Joined Oct 2012
i am use lm2576 bec 3a,and 6 fet 3205, pic 12f675,mc34063
very good but no brake.
Old Oct 08, 2012, 06:18 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
How do you want the brake to work?
1. Reverse throttle = Brake only.
2. First application of reverse throttle = Brake. Back to neutral and then reverse throttle again = Reverse.
3. Brake at neutral, reverse throttle = instant Reverse.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Oct 08, 2012, 07:01 AM
Joined Oct 2012
thanks Bruce aboott
i want brake same esc brushed 320a car
you can write code Asm or C for 12f675 or 16f688 ? thank you very much
Old Oct 08, 2012, 09:40 AM
Joined Oct 2012
schematic esc brushed car no break
Old Oct 08, 2012, 04:05 PM
Joined Jan 2001
It's just a firmware change, the circuit is the same.
NOTE: I have only tested it on a breadboard. Everything seems to work, but I can't guarantee that it's bug free!
Here's the asm source and hex file for a 12F675.
Old Oct 08, 2012, 06:08 PM
Joined Oct 2012
Thanks, Bruce abbott
I will use the following and report the results
Old Oct 09, 2012, 01:59 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Well, I am missing option
4. advanced sensing of rotation, where instant move to reverse throttle would proportionaly brake at limited brake force, and after it really stops, then goes reverse - gently to save gears. The same for transition from reverse to forward.
Because 1. is not applicable for car/ship, 2 needs hard to find center of throttle, and 3. would strip the gears instantly.
coro is offline Find More Posts by coro
Old Oct 09, 2012, 02:21 AM
Joined Oct 2012
hello coro,
use the brake like esc 320A is very good, I almost completed the circuit like this esc, but I do not know the program change ASM 12F675
i will build esc for car 1/10 runs well
Old Oct 09, 2012, 02:33 AM
Joined Oct 2012
My esc circuit has the following components
mc3406 create 20 volt activate sources fet h profile because I use a 7.2 V battery.
20 -7.2 to 12.8v the size of fet run well
LM2576 Creating 5 v 3a
opto lm 324 fet driver from chip 12f675
runs very well, but there is no compression braking is not perfect
Old Oct 24, 2012, 10:41 PM
txtchain is offline
Find More Posts by txtchain
Joined Oct 2011
change PWM frequency in Bruce's PIC12F675 code
Hi Bruce,
I made an ESC with your PIC12F675 HEX and it is woking fine. The PWM frequency is around 2.7KHz. Is it possible to change the PWM frequency to around 600Hz, 300Hz or 70 Hz, some brushed motor works well under lower PWM frequency.
Sam
txtchain is offline Find More Posts by txtchain
Old Oct 28, 2012, 06:46 AM
Joined Oct 2012
hi bruce abbott
after a long time of check, circuit runs fine foward,reverse and brake, but I see the program appear some errors
1 pulse limit your program 1.8ms...........1.5ms.............1.2ms
if run forward too 1.8 or run reveser than 1.2 servo control pulse, the circuit automatically cut off, and set the initial state to the joystick in neutral position 1.5 This affects the speed when I'm playing
very difficult to adjust max 1.8ms and min 1.2ms of tranmiter 27mhz for car
So, if the pulse exceeds 1.8, or 1.2, motor max speed foward ,or max speed revese.,do not cut off
2 as txtchain said, 2.7khz frequency is relatively high, change down from 100Hz to 600Hz. some brushed motor works well under lower PWM frequency.
thank you very much
Old Oct 28, 2012, 09:46 PM
Joined Oct 2012
we are looking forward to your early reply.
thank you bruce abott
Discussion Ebay 320amp brushed esc and car starter narxer Power Systems 7 Aug 20, 2012 11:31 AM
Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors SARCFAN Dock Talk 5 Jul 02, 2012 11:58 AM
Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo fly_right Cars - Cars and Parts (FS/W) 6 Apr 14, 2012 07:39 PM
Discussion Replacment brushed ESC for the NitroRCX drift car. B dog Electric Power Cars 5 Mar 06, 2012 08:20 PM
