Joined Jun 2006
Need input on air pump for special use
I am trying to build a weird kind of propulsion system based on discrete co-flow jets. This system utilizes wings with discrete jets blowing from behind the leading edge, and a spanwise suction slot ahead of the trailing edge. The idea is to use an EDF, or perhaps some other design of mechanism, to provide air to the jets at a pressure ratio of at least 1.2.
To be more clear, I wanted to use an EDF mounted in semi-sealed ductwork to blow air forward to the jets, and suck the air to its intake from the rear slot. It would be a closed system except for the jets and slot. So the EDF or mechanism would be facing the opposite direction of normal inside the ductwork in the wing or fuselage. Can current off the shelf EDFs work in such an application, where air velocity is less important than volume and light pressure? I am worried it will cause heat to build up due to flow restrictions. I have zero experience with EDFs, and hope to get some helpful advice about this here. I am open to designing new blades/rotors if necessary, or even exploring a mini roots type system. See below for details on how this works. http://www7.miami.edu/ftp/acfdlab/pu...A2007-4442.pdf |
You might check out this thread-- How to compare fans
http://www.rcgroups.com/forums/showthread.php?t=1742680 There may be some "numbers" in there regarding air flows that could help. |
Brisbane, Australia
![]() He asked about what or how he could use an EDF, not how to make his project on a larger scale work This IS the place to ask that type of questionThanks dave |
Australia, WA, Perth
Joined May 2007
EDFs do compress air. How much by? Let's find out.
Something like an SM89-45, with a 4771mm2 fan area, putting out 4.5kg thrust with a 100% FSA exhaust. 4.5kg is 44.1N, 4771mm2 is 4771e-6m2. Simply, the pressure change is dP=F/A dP=44.1/4771e-6 dP=9243 Pascals. For those not into SI units, that's 2.7inches, or 1.3psi, or around 1/10th of an atmosphere. So, it's got a pressure ratio of 1.1. Not enough for the job at hand, but nothing to be sneezed at, no? Three inline would obviously give around 1.33 ratio, but huge amounts of power. |
So: my point is that he might get more and EXPANDED info over in the other forum. (In simple words for you , it's just like politely redirecting some questions about small foamies to the "foamie forum")
Joined Jun 2006
If more ideas are out there, let them flow! Also, it may be off topic here, but if anyone knows of a scale roots type air pump that might work for this, let me know. |
Joined Dec 2011
My thoughts exactly Mike, and infact do you have Pics of Uriah's work?
I think you need to do a search for a user named Uriah. He has several different type of special propulsion systems. I would post pics but im not at my office, im on the road in a friends i-pad. Uriah is the man for what you are looking to do. Nobody has come close to the achievements that he has done. Look up his name on here and research his old postings. That or get yourself a Dyson fan. |
| Thread Tools | |
| Help! Need inputs on winter build projects! | RMCCOR7737 | Scale Electric Planes | 5 | Oct 01, 2012 03:37 AM |
| Discussion Thread: Grand Cruiser Crash: Need input on investigation | F1nut | Electric Plane Talk | 26 | Jun 18, 2012 02:14 PM |
| Help! Need inputs on (re)building Piper Cub | vijayfx35 | Electric Plane Talk | 9 | May 26, 2012 10:02 AM |
| Found Air Pump for retract systems | Doubledog | Aircraft - Fuel - Airplanes (FS/W) | 0 | Apr 18, 2012 04:06 AM |
| Question Need input on AP build | rgoins21 | Multirotor Talk | 12 | Mar 15, 2012 01:27 PM |
