Old Oct 07, 2012, 09:31 AM
roontoon is offline
Find More Posts by roontoon
Joined Aug 2012
Help!
Mystery ESC Polarity
Hi,
I am building a roll your own frame and I have purchased a Mystery ESC and I am having some problems identifying the polarity of the BEC. In all of the documentation that I have seen here and elsewhere have the signal wires voltage wires colored as red/black/white however on the Mystery it is brown/orange/yellow. I have poured over the docs that came with the ESC and there is no mention of the polarity it simply states "hook it up". I am concerned about hooking it up to my AMP incorrectly and bricking it. Is there anyway to test it to determine which wire is which? Has anyone hooked these things up who can advise me? Thanks.
Dan
roontoon is offline Find More Posts by roontoon
Old Oct 07, 2012, 09:55 AM
Zapro is offline
Find More Posts by Zapro
Joined Dec 2011
Brown is GND, Orange is Positive and Yellow is signal. This is standard wiring on most cheap ESC's.
// Per.
Zapro is offline Find More Posts by Zapro
Old Oct 07, 2012, 09:57 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
In many ESCs, the colors are black for ground, red for power and white for signal... or brown for ground, red for power, yellow for signal......if yours has the central wire orange, then that will be power.. brown will be ground and yellow will be signal.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 07, 2012, 12:01 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Even if you connect it backwards it won't hurt anything, the receiver and servos just will not work. They configure the connector with the positive power in the middle just for that eventuallity. When it is connected backwards the positive power still goes to the same receiver terminal. The ground, however, now goes to the receiver signal terminal which will not harm anything and the signal now goes to the receiver ground terminal which also will not harm anything.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Oct 07, 2012, 06:37 PM
roontoon is offline
Joined Aug 2012
Thanks for all the great replys.
d
Old Oct 08, 2012, 07:15 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
Black, red, white is Futaba "standard"?
Brown, orange, yellow ir JR "standard"?
Esc, servo etc manufacturers use either one or which reel they happen to have.
B12 is offline Find More Posts by B12
Old Oct 09, 2012, 01:26 PM
rvlevy7 is offline
Find More Posts by rvlevy7
rvlevy7
rvlevy7's Avatar
United States, NJ, Clinton Township
Joined Sep 2012
Good replys
signal wire always upper to Rx or esc or else. Power always middle wire. Keep us remind polarity connectors.
rvlevy7 is offline Find More Posts by rvlevy7
Discussion Turnigy/hobbywing/mystery ESC music Underthetire Power Systems 6 Jan 17, 2014 03:47 PM
Discussion esc with wrong battery polarity tulushadi DIY Electronics 5 Oct 02, 2012 04:08 AM
For Sale Mystery 20A Brushless ESC with Built-in BEC for RC Plane/ Helicopter (Yellow) Aiden6 Aircraft - Electric - Power Systems (FS/W) 0 Jul 16, 2012 10:20 PM
Sold Mystery 60amp ESC and Hobbywing 3 amp UBEC jeb6684 Aircraft - Electric - Power Systems (FS/W) 2 Jul 15, 2012 05:53 AM
Help! Mystery ESC Not working correctly! Alex Schauer Power Systems 6 Jul 09, 2012 08:41 PM
