Old Oct 07, 2012, 07:48 AM
KM.Racing is offline
Find More Posts by KM.Racing
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Help!
Coupler Problem !
Hello guys what's up I'm facing a problem with my coupling system !
The original coupler is formed of 2 parts :
The primary part that's connected to the motor has gave up ( the plastic is melt ) !
while the secondary part still intact .
The motor shaft diameter is 4mm .
The shaft diameter is 3mm but it's beveled please see attached photos.
Please Help me find this system so I can buy it or anything else that's work with my shaft and motor
Thank you very much ...
KM.Racing is offline Find More Posts by KM.Racing
Old Oct 07, 2012, 08:31 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Try www.cornwallmodelboats.co.uk they have the type couplings your looking for .
highflyerbill is offline Find More Posts by highflyerbill
Old Oct 07, 2012, 10:49 AM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
does this help me
universal joint coupling 3mm to 4mm ?
Old Oct 08, 2012, 09:25 AM
Joined Nov 2009
That will probable work . You will need a flat filed on the motor shaft .Good luck .
Discussion RDS Couplers for Airtronics 94809 s2000 Multi Task F3X 0 Jul 27, 2012 11:03 PM
Discussion Looking for 2mm to 2mm u-joint or flex coupler metoo Racing Boats - Electric 2 Jul 19, 2012 05:33 PM
Sold 2 x HANGAR 9 Fuel Dot Filler with "T" Coupler - HAN115 super_dork Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 28, 2012 11:06 AM
Discussion Rjx x-treme 90 gasser coupler problem phanislo Fuel Heli Talk 8 Sep 22, 2010 04:37 AM
Discussion i ca glued the prop shaft and motor shaft to the coupler ? How to remove coupler ? mortonj69 Dock Talk 26 Feb 22, 2010 08:47 PM
