Old Oct 07, 2012, 03:43 AM
patternmaker is offline
Find More Posts by patternmaker
Joined Jul 2010
Steam Drifter Resolute
New project, 1/24 scale wooden Steam Drifter Resolute built 1909.
History, Requisitioned by the Admiralty in 1914 and fitted with 6 pounder gun mounted on the fore deck, she was captured by UB 22 and sank by gunfire.
The fibre glass hull has been altered from a flat transom to a counter stern & the freeboard raised 1/2 Lenght 56 beam 22 draught 4.5 inches, deck planked in oak.
Total weight will be 44lbs and will need 11lbs of ballast
The forward hatch has been made to fit water tank, gas tank & electrics.
Resolute will be powered by an Edgar Westbury design twin oscillating Engine with Cheddar design vertical boiler with piezo ignition.
patternmaker is offline Find More Posts by patternmaker
Old Oct 07, 2012, 06:51 AM
scoots15 is offline
Find More Posts by scoots15
Joined Mar 2012
Hi Mick,
We look forward for this new project
Regards, Alain
scoots15 is offline Find More Posts by scoots15
Old Oct 07, 2012, 01:26 PM
ooyah is offline
Find More Posts by ooyah
ooyah's Avatar
GLASGOW
Joined Feb 2011
Hi Mick,
You've done it again, resurrected a tired old boat into a thing of beauty, your skills with wood and F/Glass are remarkable, look forward to the finished article.
Is it to be steam powered or electric ?
George.
ooyah is offline Find More Posts by ooyah
Old Oct 07, 2012, 01:55 PM
Joined Jul 2010
Thanks George & Alain for your interest, it will be powered by Steam.
Regards Mick
Old Oct 07, 2012, 02:29 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Man, this is going to be Great !
A steam powered steam drifter model !
Where did you ge the hull ?
Tim B. is offline Find More Posts by Tim B.
Old Oct 08, 2012, 03:22 AM
Joined Jul 2010
Hi Tim,
I got this fibreglass hull from someone attempting to build a Coaster but gave up, I liked the hull lines which suited a Steam Drifter apart from the transom, I completely stripped the hull raised the freeboard with a new deck and hatch openings added a counter stern which made it the correct length for 24th scale wooden Drifter Resolute which was 116 ft long & 23ft beam. I understand that only 4 hull mouldings where made.
Mick
Old Oct 09, 2012, 02:40 AM
scoots15 is offline
Joined Mar 2012
Hi Mick,
Can you point us to anything (drawing, characteristics...) about the planned E. Westbury engine ?
I believe this engine will be built from scratch ?
Regards, Alain
Old Oct 09, 2012, 09:40 AM
Joined Jul 2010
Hi Alain,
The engine came with the boat but did not work, stripped and rebuilt now runs very well and will tickover on 5psi steam pressure it is also very powerfull, bore 1/2" stroke 3/4" and should
be just right for scale speed of the Drifter which was 9 knots
running at 25 to 30psi. The design is quite easy to build with no
castings needed I have not been able to find any plans for this
engine but I believe its a copy of Edgar Westbury single cylinder oscillator doubled as a twin
Mick
Old Oct 09, 2012, 10:28 AM
scoots15 is offline
Joined Mar 2012
Hi Mick,
thanks for your reply, I have searched on the net and found nothing !
Your engine is similar to the Stuart D10 for power available...
Just found these infos about Westbury engines on another ME site :
http://modelenginenews.org/etw/etw_steam_engines.html
Regards, Alain
Old Oct 09, 2012, 02:14 PM
gyula. is offline
Find More Posts by gyula.
Romania
Joined Mar 2009
Isn't that the Miranda steam engine?
http://www.flickr.com/photos/2886513...57622660772239
gyula. is offline Find More Posts by gyula.
Old Oct 09, 2012, 04:08 PM
the goon is offline
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Mark
the goon is offline Find More Posts by the goon
Old Oct 09, 2012, 04:52 PM
Joined Jul 2010
Its very similar in appearance, but in know way matches performance, I built a Thames launch Miranda 6 years ago and the boiler all to Basil Hartley design, not only were the hull line plans wrong also the engine dimensions incorrect the engine and boiler were far to heavy for the displacement of the hull, it ended up a museum piece as it sat 1/2 below the waterline.
There is a video of Miranda on youtube running in a neighbours
swimming pool, when I find the link I will post it.
Mick
Old Oct 09, 2012, 05:00 PM
Joined Jul 2010
Video Miranda.
THAMES STEAM LAUNCH MIRANDA (1 min 6 sec)
Old Oct 09, 2012, 05:36 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
wow ~
Discussion Camera Resolution vs. Display Resolution jforkner FPV Talk 3 Oct 07, 2012 09:00 AM
Discussion flysky CT6B stick not centering, resolution seems off. slowjett Radios 5 Apr 17, 2012 08:06 PM
Discussion corona RP8D1 synthesized dual conversion 40mhz. low resolution!!! galaxy1 Radios 0 Apr 08, 2012 01:53 PM
Build Log Lady Margaret-Wooden Steam Drifter ajferkovich Scale Boats 44 Nov 13, 2010 10:33 AM
Wanted old plans search merlyn sagitta ro8 drifter 2 wind drifter pval3 Aircraft - Sailplanes (FS/W) 3 Jul 05, 2007 06:01 PM
