Old Oct 09, 2012, 08:59 PM
mikeythev is offline
Find More Posts by mikeythev
I like foam
mikeythev's Avatar
outside of philadelphia
Joined Nov 2005
This plane is incredible. Thank you for sharing your plans!
mikeythev is offline Find More Posts by mikeythev
Old Oct 09, 2012, 09:12 PM
Mauilvr is offline
Find More Posts by Mauilvr
Almost a Pilot
Mauilvr's Avatar
NorCal
Joined Oct 2001
Very, very cool. What is it covered with? Did I miss that?
Mauilvr is offline Find More Posts by Mauilvr
Old Oct 09, 2012, 10:04 PM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Laser cutter computer is still down, so I can't do a live build yet. Here is my first crack at an assembly guide using the CAD parts. All parts are covered first, by adhering the skin (I use RA Microlite) to the foam with 3m77. All paint also happens before assembly. The skin is used as the hinge material for all control surfaces.
-A
AJWoods is online now Find More Posts by AJWoods
Old Oct 09, 2012, 10:57 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Great guide.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 10, 2012, 06:43 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
If I unblunk my eyeballs just right, I can see balsa ...
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Oct 10, 2012, 08:11 AM
AJWoods's Avatar
Joined Jul 2005
Originally Posted by boredom.is.me View Post
Great guide.
Thanks! I wanted to incorporate the skinning process, but it ended up being too much of a pain. For those interested in learning more about the process and materials selection, I highly recommend reading Gordon's Skeletonized Airframes thread, where I learned many of these techniques:
http://www.rcgroups.com/forums/showthread.php?t=1362423
One thing to note on the fuse construction, I do not bond the forward, middle, and rear fuse sections together. I bond them all to the skin, and use the skin as a hinge to make the tapered forward and rear sections. After everything is set to shape, you can go back and wick a very small amount of thin foam safe into those joints to bond the foam sections of the fuselage together.
-A
Old Oct 11, 2012, 09:23 AM
AJWoods's Avatar
Joined Jul 2005
Laser cutter's back up! Foam sets should go out Saturday.
-A
Old Oct 11, 2012, 11:09 AM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Time to clear off the bench!
Petefoss is online now Find More Posts by Petefoss
Old Oct 15, 2012, 04:49 PM
Petefoss's Avatar
Joined Aug 1999
What do I owe you Adam? Did the foam ship?
Old Oct 15, 2012, 06:23 PM
AJWoods's Avatar
Joined Jul 2005
Just put the first batch in the mail. You guys get them for free, just post some build pic in here.
-A
Old Oct 15, 2012, 06:58 PM
racie34 is offline
Find More Posts by racie34
road wart
racie34's Avatar
United States, IN, Terre Haute
Joined Aug 2003
Adam,I had some laser cut by Brian and 2 that are big enough for 2s micro stuff...witha fleet....I'm brave
racie34 is offline Find More Posts by racie34
Old Oct 16, 2012, 04:52 AM
Petefoss's Avatar
Joined Aug 1999
-A
Cool thanks. Will do!
Old Oct 17, 2012, 01:16 PM
I like foam
mikeythev's Avatar
Joined Nov 2005
cad question
What scale is the cad file? It appears to be drawn in millimeters but I'm not sure.
Old Oct 17, 2012, 07:03 PM
AJWoods's Avatar
Joined Jul 2005
I believe import should be in millimeters. The drawing should end up as a full 24x12 inch sheet.
-A
Old Oct 20, 2012, 12:27 PM
Petefoss's Avatar
Joined Aug 1999
-A
Foam came today Adam. Thanks a bunch.
Pete
Discussion Maybe Im just getting old or maybe just bold! aerogel Life, The Universe, and Politics 68 Aug 25, 2012 06:25 AM
Wanted Dynaflite Spitfire plans or kit fomocokid Aircraft - Fuel - Airplanes (FS/W) 10 May 15, 2012 05:51 PM
Wanted 3 views, plans or maybe a kit for a Mr. Mulligan??? SteveT. Aircraft - Fuel - Airplanes (FS/W) 2 Jan 04, 2009 08:06 AM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
Looking for plans for an aerobatic indoor depron plane (Minsai or similar maybe?) Erik Johansson Scratchbuilt Indoor and Micro Models 3 Oct 19, 2002 01:17 PM
