Espritmodel.com Heli Air
Old Oct 09, 2012, 04:13 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Here's AG 12, 13, 14 and Clark Y plotted in AeroPlot. What is the aspect ratio (wingspan/chord) of your sailplane? Glider territory usually begins around 6.
whitecrest is offline Find More Posts by whitecrest
Old Oct 09, 2012, 01:35 PM
Joined Oct 2012
So Drela, KFm, and Clark Y would be better than a NACA?
sraden is offline Find More Posts by sraden
Old Oct 09, 2012, 02:05 PM
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
For a 40" span sailplane.. The Drela would give genuinely good performance. The Clark Y isnt really very good for anything that small and slow flying and the KFm just isnt any good for sailplanes unless ease of building is your main driver.
Dont write of all NACA airfoils because there are thousands of variations on the NACA theme. Of the 4 digit type NACA a 3306 would be pretty good for a small sailplane, maybe not as good as the Drela but much better than the Clark-Y and in a different league performance wise from the KFm
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Oct 09, 2012, 02:12 PM
Aberdeen
Joined Mar 2006
Here are some polars for the drela AG13 vs. Clark-Y vs. NACA 3306 at Re=40k
Drela is good, the NACA is ok, the Clark-Y pretty awful. KFm airfoils are difficult to run on this software but performance would be worse than the Clark-Y
Old Oct 09, 2012, 05:12 PM
Joined Oct 2012
Not quite sure yet...
Old Oct 09, 2012, 10:03 PM
HELModels's Avatar
Joined Aug 2003
Here's Clark Y and NACA 4412 superimposed in AeroPlot:
Interesting, you might also find this interesting. I went to UIUC database and found the Clark Y smoothed and I did a similar overlay. First, what I did was adjust the thickness and camber of the NACA 4412 so that it matched the "smoothed" Clark Y and then I overlayed the Clark Y. It's not just coincidence that the match gets closer.
HELModels is offline Find More Posts by HELModels
Old Oct 10, 2012, 12:14 AM
Aberdeen
Joined Mar 2006
Yeah, but a smoothed Clark-Y isn't really a Clark-Y anymore. For starters the (very strong) smoothing process caused the bottom surface to go slightly under-cambered. Also a NACA 4412 with thickness and camber parameters adjusted isn't a NACA 4412 any more
But I take your point.. The NACA 4412 is very close to a Clark-Y, but it's incorrect to say they are the same because there are small but significant differences.
Old Oct 10, 2012, 01:26 AM
HELModels's Avatar
Joined Aug 2003
What's an airfoil but a distribution of points around a mean line. That was the point of tweaking the 4412 to the same thickness and camber. Do that with a Selig or something(I should) and the visible differences would be more pronounced. It reinforces what historians have said about the NACA 4 digit and the Clark Y, they have the same blood lines.
As for the smoothed vs. non smoothed, I checked the difference between the smoothed and the non smoothed Clark Y and it was very small in thickness and camber, much less than what I did to the 4412 to normalize it. I even tried using CADD and PANE to smooth the standard Clark Y, but there are some strange extra ordinates that show up as squiggles.
Old Oct 10, 2012, 01:50 AM
HELModels's Avatar
Joined Aug 2003
Here, just for kicks. I normalized a Selig 4061 to the Clark Y and you can see the difference is in the back end, very visible. Eppler did a lot of tweaking on the back end of airfoils. That was where he figured he could control flow seperation, from what I've read.
Old Oct 10, 2012, 07:28 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Here's Selig 4061 and Eppler 193 superimposed on Clark Y. These are straight data plots. Both the Selig and Eppler airfoils seem to be tweaking Clark Y for less drag (thinner) and more lift (greater camber).
Old Oct 11, 2012, 02:38 AM
HELModels's Avatar
Joined Aug 2003
I was hoping one of you might be able to run a sequence on 4 different airfoils, RAF32, Clark Y, Selig 4061, NACA 4508. The version of Clark Y I have gives crazy results and Xfoil's pplot isnt as good as profili.
Here's what I did as a comparison, Re 50000, Mach .025.
Old Oct 11, 2012, 07:04 AM
Aberdeen
Joined Mar 2006
I'll run them tonight
Old Oct 13, 2012, 05:57 AM
HELModels's Avatar
Joined Aug 2003
Wow, the more I play with the NACA 4 digits, the more I believe you can find a combination to do whatever you want.
Old Oct 13, 2012, 02:36 PM
So many kits, so little time..
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Ok... Revised question
Best NACA and KFm (1, 2, 3, etc) for a sailplane with a roughly 40 in. wingspan. Also, can a Clark Y be used with this.
To answer the question we still need more info. What are you looking for - slope aerobatics, thermal, speed, turn performance? What approximate weight will the model be, and how will it be constructed (moulded, built up, foam etc).
MattyB is online now Find More Posts by MattyB
Old Oct 13, 2012, 07:12 PM
Joined Oct 2012
Full info:
-Roughly 4 foot wingspan
-constructed of foam (simple insulation board foam)
-not sure about weight, probably 250 grams or so
-mostly looking for smooth, steady, long flight with low stall speed
just looking for 3 different airfoils that i could compare
Rant Change- Usta's common cents plan to help save the economy Usta Bee Life, The Universe, and Politics 11 Feb 27, 2012 07:01 AM
Which airfoil is most commonly used on 3D planes? Tumbler 3D Flying 8 Nov 04, 2004 05:03 PM
Common combat flying wing airfoils? Ronbo Power Systems 16 Dec 16, 2001 02:45 AM
