Old Oct 08, 2012, 02:22 PM
sherlockshah is offline
Find More Posts by sherlockshah
Joined Feb 2006
I cant go past 14inch prop, I would like to get 13inch just to be safe
what set up can i use for 13inch prop? what pitch?
sherlockshah is offline Find More Posts by sherlockshah
Old Oct 09, 2012, 08:14 PM
Eli Lipschitz is offline
Find More Posts by Eli Lipschitz
Joined Sep 2012
13x8 is pretty standard. If you do not have a watt meter, you should purchase one. Watch your amperes and wattage as you give it more throttle. If it goes over and above your ESC limits, you should use a smaller prop or a large ESC or motor.
Eli Lipschitz is offline Find More Posts by Eli Lipschitz
Reply With Quote  (Disabled)
Old Oct 10, 2012, 12:12 AM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
I think the model weighing at least 16 lbs.
At that stall speed will be 27mph.
Required to fly at about 80-85mph. APC 13x10 with a 10.300 rpm.
And consume around 1900 watts.
6s is necessary for a motor of 480 to 600 grams with 560 Kv. ESC 90-100A.
For necessary 8s same engine but with a weight of 421 Kv., ESC 75-85A.
Manuel V.
manuel v is online now Find More Posts by manuel v
Old Oct 10, 2012, 03:44 AM
Joined Feb 2006
what about 12s
what prop and motor kv
Old Oct 10, 2012, 12:46 PM
manuel v's Avatar
Joined Aug 2004
would be equal, but with an motor of around 340 Kv.
, 51A, esc 60A.
Maybe 4000 ma are enough for 4minutes.
If you can fit a larger diameter propeller, then we can get better push, if you can, a 13x10 3 blade work better, but occupy the same rpm. and a little more a amperes.
Manuel V.
Old Oct 10, 2012, 03:07 PM View Post
DDURGADASS
A moderator felt this post violated the following rule: Trolling (Widespread). Show it to me anyway.
Old Oct 10, 2012, 11:05 PM
Joined Feb 2006
3 blade prop?
, 51A, esc 60A.
Manuel V.
so get a 3 blade 13x10 prop and run it on 12s with a low kv motor? they sell 295kv or 245kv as the lowest.
Old Oct 10, 2012, 11:22 PM
manuel v's Avatar
Joined Aug 2004
sherlock
You best chance is with 295 Kv.
What brand of motor, you mean?
We could put the link?
Manuel V.
Old Oct 11, 2012, 08:30 AM
Joined Feb 2006
here is the motor great reviews
http://www.hobbypartz.com/96m607-big...325-295kv.html
Old Oct 11, 2012, 05:43 PM
manuel v's Avatar
Joined Aug 2004
, 51A, esc 60A.
Manuel V.
Im sorry, this numbers are for 10s.
For 12s is a motor 280Kv and around 42A.
Maybe with tacon big foot. is around 11.000 rpm and 45-48A.
Manuel V.
Old Oct 30, 2012, 11:10 AM
Joined Feb 2006
I got the 295k motor today and the 120hv esc
I need to figure out which prop i can use on 12s. I guess if i go with a lower size prop it should pull less amps. I can only do 12s, I dont have any other batteries. If i can prop it down with 295kv i rather do that than buy new batteries.
Old Oct 30, 2012, 02:41 PM
Joined Feb 2006
Im going to experiment with a 3 blade 11x8 and 12x8
on 12s at 295kv sounds about right. I have 120amp esc so I think it will have the punch.
Old Oct 30, 2012, 03:21 PM
manuel v's Avatar
Joined Aug 2004
I think your motor may well up to 13x10 propeller.
But very good test before the 12x8 propeller fot check ampers and rpm.
and so see if you can do the test with the 13x10.
Manuel V.
Old Nov 06, 2012, 05:45 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
sherlockshah,
Are you a member of the AMA here in America?
ApexAero is offline Find More Posts by ApexAero
Old Nov 06, 2012, 09:23 PM
Joined Feb 2006
yes I am
hey check out my turbine jet!!! I am working with a friend who is going to help me get a waiver
Skymaster Gripen with VT-80 turbine engine RC jet (maiden flight) (7 min 21 sec)
Discussion F4 --can you please give me your opinions Ldm Foamy EDFs 9 Apr 06, 2010 04:34 AM
Idea Sombody flying the IMA Twin Otter - Give me your opinion anyway!! Ben_E Foamies (Kits) 2 Jul 23, 2009 07:32 AM
Discussion Give me your opinion...... Fox Rider 4 Life, The Universe, and Politics 179 Oct 28, 2008 05:49 PM
Discussion Please give me your opinions. tomcatguy74 Off-road Cars 3 May 20, 2008 09:19 AM
Alert Please take a look at this and give me your Honest Opinion Starguard Parkflyers 5 Jul 24, 2004 11:29 PM
