Old Oct 06, 2012, 08:32 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Balanced 4800 kv in Freewing Panther
Hi Don,
I have used your 4800 kv and fan setup (balanced) in my Starmax Panther and it was noticeably faster than stock 4300 kv. The same setup in my Freewing EPO Panther is not nearly as fast. I am thinking the lack of real ducting, small inlets and a cheater grate are causing it. Have you tried your combo in one of these?
Bill
Prof100 is offline Find More Posts by Prof100
Old Oct 06, 2012, 08:47 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Did you have thrust tubes in both? if not perhaps the exit nozzle area is larger on the Freewing one? I had a kit for a Freewing version but sold it, I though the Starmax one was cleaner looking, the Freewing one has real thick trailing edges if I recall that is pure drag.
The Don is offline Find More Posts by The Don
Old Oct 06, 2012, 10:48 PM
Prof100's Avatar
Joined Jul 2007
Nip tuck was done on the Starmax and stock outlet was used on the Freewing.
I could add a thrust tube to the Freewing to see if it helps. What outlet diameter would you suggest?
Old Oct 06, 2012, 11:24 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That is probably the difference. On these models thrust tubes can add 5-8 mph pretty easily. You want to shoot for 51.4mm.
Old Oct 06, 2012, 11:38 PM
Prof100's Avatar
Joined Jul 2007
I have some nice 7 mil mylar and I will make a thrust tube.
Discussion FreeWing F9F Panther 64mm EDF Kross Foamy EDFs 3 Sep 21, 2012 10:06 AM
Sold Pair of balanced Wicked 4800 motor and matching ESC for twin EDF setup The Don Aircraft - Electric - Jets (FS/W) 4 Jun 25, 2012 07:34 PM
For Sale Don's Wicked 4800 mounted in a dynamically balanced 64mm EDO Type I EDF Unit. jhamm Aircraft - Electric - Jets (FS/W) 1 Jun 06, 2010 07:03 AM
Sold Two Dynamically Balanced Wicked 4800 in 64mm fan The Don Aircraft - Electric - Jets (FS/W) 6 Nov 08, 2009 08:20 AM
