Old Oct 06, 2012, 06:54 PM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
Help!
Selecting objects in AutoCad
I've upgraded???? my AutoCad to 2013. For some reason when selecting
objects to erase, for instance. I select the first object but when I select the
second the first is no longer selected. There must be some switch that I'm
missing. Can anyone help???
John
jcyr1 is offline Find More Posts by jcyr1
Old Oct 06, 2012, 09:33 PM
jcpatrick is offline
Find More Posts by jcpatrick
Jim C Patrick
jcpatrick's Avatar
United States, VA, Basye
Hold shift while selecting.
But I think you want a permanent solution. Type pickadd in the command window, then set to 1 when prompted for new value.
jcpatrick is offline Find More Posts by jcpatrick
Old Oct 07, 2012, 10:49 AM
jcyr1 is offline
Joined Jul 2002
Jim,
Thanks, I guess too lazy to read the upgrades. This version different
than 2000. Thanks again.
John
Old Oct 07, 2012, 01:27 PM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Pickadd goes way back - certainly to AutoCAD 2000, possibly to R14 when AutoCAD began attempting Windows compliance. There are so many of those system variables it's hard to keep track.
potshot is offline Find More Posts by potshot
Old Oct 07, 2012, 08:13 PM
Jim C Patrick
jcpatrick's Avatar
The pickadd system variable goes back before Autocad R14, my Release 13 book from 1994 lists it in a way that suggests it was in version 12. I don't have the R12 books (R12 sucked horribly and R13 sucked slightly less) and I simply can't remember if it was in R11 or R12, the last two DOS-based versions. According to Autodesk, pickadd was implimented in release 12, June 1992.
Pickadd was either on or off, 0 or 1 respectively. Autocad 2011 added an new setting, pickadd value 2, where entities remain selected after the command Select is finished.
The OP, jcyr1, just upgraded from v2000 to 2013 (which is beyond where I am) and that big of a jump has got to be a big adjustment.
Old Oct 07, 2012, 08:35 PM
potshot is offline
potshot's Avatar
Joined Mar 2009
Agreed. I worked with it daily starting with version 2.17 in 1985. There wasn't much to learn back then as compared to now, and you (hopefully) picked up the new features as they came along. Learning it from scratch at the current levels of complexity is a daunting task. Hats off to those who are doing it.
Old Oct 08, 2012, 12:40 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
autocad
nice to see version 2.71 that's must be back in the days before 286 machines i was Lucky started on version 9 and still use 2006 is autocad still using autolisp
dpot is offline Find More Posts by dpot
Old Oct 08, 2012, 04:46 AM
Jim C Patrick
jcpatrick's Avatar
Autolisp still works, a scripting language adopted by Autocad very early on. It's a subset of Lisp, invented in 1958 (!) and is the second oldest computer language still used. The inventor, John McCarthy, died last year; but Lisp continues. McCarthy's webpage is still up as a memorial.
The great thing about Autocad and Autolisp is that beginners can write scripts (SCRs) to automate drawing. As users get proficient, Autolisp is the next step to writing automated functions; Lisp can do complex geometry and math but is not too hard for a user to understand. Neither programming requires a deep knowlege of programming language, and Autolisp references from 10-20 years ago are still valid today.
Old Oct 08, 2012, 08:37 AM
potshot is offline
potshot's Avatar
Joined Mar 2009
Not to dwell in the past, but I first ran AutoCAD on an 8086 machine with no hard drive and 256K of RAM. AND walked 8 miles through the snow to school - uphill, both ways
Discussion autocad cnc para45home CAD/CAM 4 Jun 27, 2012 08:52 PM
Discussion Important illusion- Motion of an object can mask a change in the object CNY_Dave Beginner Training Area (Aircraft-Electric) 15 Jan 12, 2011 12:26 AM
Discussion section lofted object autoCAD xterarc The Builders Workshop 5 Oct 19, 2008 12:24 PM
