Old Feb 26, 2013, 11:42 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
How is it for heat dissipation? And where did you locate it?
And how long are the battery leads?
Thanks.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 27, 2013, 12:29 PM
tom bacsanyi is offline
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
programming yge/yep
mjnco,
If the upper curser is flashing, you are on page 2. Simultaneously press the left buttons to change pages Here are my settings:
timing- 6 (4 pole inrunners)
brake-off
cut off-off
cells-12
Page two:
gov mode-off
startup speed-plane middle
pwm-8khz
start up-4%
remember to press enter after sellection to save.
Impressive blog! My grand nephew is building a large Pettigrew Solent.
tom bacsanyi is offline Find More Posts by tom bacsanyi
Old Feb 27, 2013, 01:29 PM
Joined Sep 2006
Yep 120
Cooler,
I believe your question was directed to mjnco and his slick F-16 but here is my mb339 setup. The plane had lots of flights with a turnigy 100 hv and 12s. In the middle of a flight, a trail of smoke was from a burning esc. I have learned to protect the foam from flaming escs' So the plane survived and I installed the YEP 120. The fan/motor was fine. The esc is exposed flush in the inlet duct so it is close to the batteries. I had extra caps in the bat leads but removed them because the YEP antispark function would be gone. I ran 3kw tests with no air flow on the yep and it just doesnt want to get hot But, it was easy to leave it in the duct.
Old Feb 27, 2013, 01:42 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
i have some of the king kong hi fei ones on HV 120 and 150A didn't test them but it ll be soon
it seems electronics comes from the same place as some of well known trade marks
so i'll keep you all informed as soon as i get them in a plane
gianni sanchez is offline Find More Posts by gianni sanchez
Old Feb 27, 2013, 01:44 PM
Joined Dec 2008
Thank you Tom, answered my questions. Just trying to save a buck, and as much as I like like a CC 120HV, this is considerably less expensive. I will be using a JF90/Het 1200Kv 12s. From what I have seen they are pretty easy on, amps, somewhere between 90A-105A . Mounting it in the ducts won't be a problem, but I do have to make them first!
Sold EDF items, CS120's, CS90, Scorpion motors, HV ESC's, receivers, EDF kits scatsob Non R/C Items (FS/W) 1 Sep 08, 2012 10:12 PM
Sold Castle Creations HV ESC's: Ice2 60HV (new), 85HV (used), 110HV (new) jgalexander Aircraft - Electric - Power Systems (FS/W) 3 Jun 23, 2012 02:31 PM
Sold Castle Creations HV ESC's: Ice2 60HV (new), Ice2 80HV (new), 85HV (used), 110HV (new) jgalexander Aircraft - Electric - Power Systems (FS/W) 11 Apr 26, 2012 07:26 AM
Wanted 100-160 hv esc's needed kremecheze Aircraft - Electric - Power Systems (FS/W) 3 Apr 13, 2012 08:30 AM
Discussion Differences between the CC HV ESC's and HV "ICE" ESC's? JEFFRO503 Power Systems 7 Dec 09, 2009 06:26 PM
