Old Oct 06, 2012, 04:05 PM
jforkner is offline
Find More Posts by jforkner
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Camera Resolution vs. Display Resolution
Probably a dumb question, but here goes...
If I have a display that has, say, 300-line resolution, why would I need/want a camera that provides a greater number of lines of resolution? From my experience with televisions and computer monitors, providing a higher resolution signal to a lower resolution screen provides no benefit. In fact in some cases, the image can be cropped to accommodate the screen.
Here's my situation...I have a 7" monitor that reportedly has an advertised resolution of 1440 x 234. I'd like to use this with my ground station as I take the leap into FPV. [FWIW, I currently use this monitor to display the live-view from my airborne camera to compose still images---works fine for that.] Anyway, I want to get a dedicated FPV camera and wonder why I should spend the money for, say, a 600-line camera versus getting a cheaper lower res. model. I realize the signal from the higher res. cameras is of higher quality, but will my monitor show the difference?
Thanks for your help.
Jack
jforkner is offline Find More Posts by jforkner
Old Oct 06, 2012, 08:27 PM
JimTMich is offline
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
The analog NTSC format is 525 lines. So in theory you should get a camera and display with that many lines to maximize the setup
JimTMich is offline Find More Posts by JimTMich
Old Oct 06, 2012, 08:48 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
the reason FOR is because compared to low res cameras (sub 480p) the higher res (480-600+) are simply better cameras with more advanced processing & better sensors
outside of that you're correct from a pure resolution standpoint (being the key, that's only one issue)
Toysrme is offline Find More Posts by Toysrme
Old Oct 07, 2012, 09:00 AM
jforkner is offline
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
I understand. Thanks guys.
Jack
Discussion What will the actual resolution be displayed on my monitor? TheNiceGuy FPV Talk 9 Jun 19, 2012 02:49 PM
Discussion Video Resolution/Color and TX frequency (900Mhz vs 1.3Ghz vs 2.4Ghz vs 5.8Ghz) mook FPV Talk 4 Apr 03, 2009 01:02 AM
Discussion Camera vs Receiver resolution question/ Ham license required at 500mW? markm75 FPV Talk 57 Aug 29, 2008 10:35 AM
Question mix curves, display resolution, helicopters, eclipse 7 zbandito Radios 0 Apr 12, 2004 01:37 PM
