This thread is privately moderated by jgalexander, who may elect to delete unwanted replies.
Old Oct 06, 2012, 02:07 PM
jgalexander is offline
Find More Posts by jgalexander
Trader Rating: 829
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Trader Rating: 829
Sold
Turnigy 420, 16 Amp 250W Chargery Power A20 power supply, Apache 2500 Smart Charger
**Moved to a New Thread
All prices are shipped USPS with tracking. Cash, MO, check, Paypal, all good for payment.
Thanks for looking,
Josh
Apache 2500 Smart Charger. Great shape, has deans attached, 5mm bullets on the power supply side. Will charge 1-4 cells at 250-2500mA/hour. More info is at the bottom of this ad. http://aeromicro.com/catalog/apache_...00_2374671.htm
$22 shipped
1 x Turnigy 420 Balancer/Charger. Does 2s-4s. Balance charges through the balance ports. Works great, and is in nice shape. http://www.hobbyking.com/hobbyking/s...ger_2S_4S.html
Includes 16A 250W Chargery Power A20 power supply. http://www.chargery.com/a20.asp, http://www.aliexpress.com/product-fm...olesalers.html
http://www.jmttop.com/chargery-power...49_314_316_335
$59 shipped as a set, or $49 shipped for the power supply and $20 shipped for the charger.
Apache 2500 Smart Charger Instructions/Manual:
Compact - Reliable - Intelligent - SAFER
Smart Charger 2500 is intended for charging Li-Poly batteries only!
Please read this manual carefully and use this charger correctly.
Features of the SMART CHARGER 2500
The newest charger for 1-cell to 4-cell Lithium Polymer in series in RC is a recent advance, and a very promising one. One of the restraints to wider adoption, however, has been the poor reliability of charging systems. But, the technology for safe charging of these cells has just taken a major step forward - with the introduction of these new chargers from Apache. Other charger manufacturers have developed fully automatic detection for cell count to set charge voltage, but none of these systems have been proven reliable. The result, in many cases, has been destroyed batteries, which is both costly and unsafe.
Apache looked at this problem and determined that the best possible system was a combination of manual settings made by the user, plus an extremely sophisticated detection routine to check the voltage setting before charging begins. Using jumpers to set voltage and charge rate also insures that settings do not change inadvertently, as they can with chargers using rotary dials or software systems.
We believe that the Apache SMART Charger line is the safest on the market today. In a recent test of the safety detection circuit they contain, more than 1000 improper combinations of battery and jumper settings were connected, and the chargers were 100% accurate in detecting these errors - emitting a warning light and refusing to charge in each case. Human error is much more likely than charger error, and the Apache oversight circuit is highly recommended insurance for that rare case when your attention might wander for a moment.
Specifications & Instructions
Specifications:
• Chargeable cells: 1 cell to 4 cell.
• Input Voltage: 10.5V ~ 15V
• Charge voltage: 4.2V per cell in series.
• Selectable output voltage: 4.2V(1Cell), 8.4V(2Cell), 12.6V(3Cell), 16.8V(4Cell)
• Selectable output current: 250mA, 700mA, 1200mA, 1700mAh, 2000mAh, 2500mAh.
• Constant battery output voltage maintenance program included.
• Reverse polarity protection circuit included.
• Dimensions: 105mm x 56mm x 16mm
LED Display:
• Green LED On (Left side) : Power On.
• Reverse Polarity of input source: LED will NOT turn ON.
• Reverse Polarity of output source: Red LED Flashes.
• Short Circuit of output tab: Red LED Flashes (The result may destroy only the battery.)
• Incorrect cell count set by jumper: Red LED Flashes
• Incorrect voltage set by jumper: Red LED Flashes
• Charging Mode: Red LED ON
• 80% complete charging: Red LED & Green LED On
• Completed Charging: Green LED ON.
(When the Green LED is ON, the battery is over 99% charged, and it will be
switched to Trickle Mode. The battery is now ready to be used.)
Cautions
• SMART CHARGER 2500 is intended for Li-Poly battery only (Please do not charge NiCd,
NiMH or PB BATTERY.)
• Charging Rate: 1C - Max
• Please do not use this charger in a small case with inadequate ventilation.
• Please do not disassemble.
• Please never exceed input voltage over 15V.
jgalexander is offline Find More Posts by jgalexander
Old Oct 06, 2012, 07:29 PM
invert is offline
Find More Posts by invert
Trader Rating: 5
invert's Avatar
Joined Jun 2008
Trader Rating: 5
Buddy ended up giving me a extra that he has so gotta pass....
invert is offline Find More Posts by invert
Old Oct 06, 2012, 07:35 PM
Trader Rating: 829
Joined Apr 2010
Trader Rating: 829
You got it. Pm on the way.
Josh
Old Oct 06, 2012, 08:34 PM
invert is offline
Trader Rating: 5
invert's Avatar
Joined Jun 2008
Trader Rating: 5
Sent you a PM and edited my first post..Sorry about that..
Old Oct 06, 2012, 08:46 PM
Trader Rating: 829
Joined Apr 2010
Trader Rating: 829
No prob! Everything is still up for grabs.
Sold Turnigy 420, 16 Amp 250W Chargery Power A20 power supply, Apache 2500 Smart Charger jgalexander Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 02, 2012 06:18 PM
Sold FMA Direct Cellpro 4S charger with 250W power supply (((SOLD the charger))) bah7566 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 15, 2012 07:55 PM
Discussion 240v power supply for Apache Smart 2500 Li-Po charger? Redbaron25 Scale Kit/Scratch Built 1 Mar 20, 2006 10:43 AM
FS:Apache 2500 Li-Poly Smart Charger + Elco Power Supply nhorianopoulos Aircraft - Electric - Airplanes (FS/W) 5 Dec 30, 2004 04:41 PM
FS:Apache 2500 Li-Poly Smart Charger + Elco Power Supply nhorianopoulos Aircraft - General - Radio Equipment (FS/W) 1 Dec 30, 2004 02:18 PM
