This thread is privately moderated by acetech09, who may elect to delete unwanted replies.
Old Oct 06, 2012, 12:58 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Cool
24 Inch EPP Wing
I dug out an old motor from the toolbox when cleaning it, and I didn't even know I had it. So I built a plane to stick it on.
Name: 24in Wing 1.jpg
Description:
Here's the stats from a CG calculator, showing what I did with it:
Name: Screen Shot 2012-09-28 at 8.34.27 PM.png
Description:
The construction is fairly simple... a main wing shape and then a kFm2 step on top. LE is duct-tape backed with gorilla glue, which makes it a hard plastic leading edge. Some winglets foam-tac'd on with some scrap EPP. After building it, I realized I didn't have enough area to make suitable surfaces, so I stuck 'em in the back. The airflow over the wing will be pretty turbulent but I think it'll work.
Name: 24in Wing 2.jpg
Description:
Motor mount is a piece of EPP saturated in gorilla glue. The stuff foams and hardens into a hard plastic, so it's great for making soft areas hard like motor mounts. It's best used in conjunction with foam-tac, as GG doesn't adhere great to EPP - it's good to support compression and torsion but not tension.
Name: 24in Wing Motor Mount.jpg
Description:
Linkages are 2mm CF tube and heat-shrink with a wire Z-bend. I use Gorilla Glue for that too - I've found that thin CA is a bit too brittle and will snap under a hard crash, leaving the wire sliding free (even with sanding). I haven't had that problem since I switched to GG.
Name: 24in Wing Linkage.jpg
Description:
These 9g Solar Servos are really nice. They're smoother and quieter than the HXT900s (which have recently turned downhill in quality), but seem to put out less torque and draw less current, which is actually welcome in my mind.
Name: 9g Solar Servo.jpg
Description:
The electronics are fairly cheap. A 6A Plush ESC, 18-11 2900kv outrunner, OrangeRx, and some custom batteries (I buy cells and make my own packs).
Name: 24in Wing Electronics.jpg
Description:
I originally wasn't going to tape it, but it wasn't as laterally stiff as I wanted so I taped the bottom with packing tape.
Name: 24in Wing Bottom.jpg
Description:
20% CG is marked, and that's where it balances. 15% CG is "A little bit infront of 20%" and 25% CG is "A little bit behind 20%".
Name: 24in Wing CG.jpg
Description:
Weight without the battery is 130g (you can do the math to find dry weight).
Description:
And weight with battery is 166g.
Name: 24in Wing Weight W. Battery.jpg
Description:
I didn't have enough hands to measure weight on full throttle and take a picture of it, but it weighs 310g on full throttle down into the scale. That's nearly a 1:1 thrust ratio.
I'm gonna maiden it tomorrow at the club field (among the tall grasses )
acetech09 is offline Find More Posts by acetech09
For Sale SALE !!!!!! --16 inch EPP Foam wing kits, brushless motor, props, etc., etc.,.. sylair Aircraft - Electric - Airplanes (FS/W) 7 Apr 02, 2012 10:50 PM
For Sale 16 inch Brushless Goliath EPP micro-wing kits sylair Aircraft - Electric - Airplanes (FS/W) 5 Mar 26, 2012 11:42 PM
For Sale 16 Inch brushless Goliath EPP Wing kits sylair Aircraft - Electric - Airplanes (FS/W) 5 Mar 06, 2012 11:31 AM
For Sale 22 inch EPP wing Kit w/3000kv, 24 gm brushless motor, APC Prop, can be FAST, ON SALE sylair Aircraft - Electric - Airplanes (FS/W) 2 Nov 27, 2009 04:14 PM
New 24 inch EPP wings on order!! dr.E Bergen County Silent Fliers 5 Mar 28, 2003 03:14 PM
