Old Oct 06, 2012, 12:23 PM
ElectroAviator is offline
Find More Posts by ElectroAviator
ElectroAviator
ElectroAviator's Avatar
Chicago, IL
Joined Sep 2008
Build Log
Guillow Lancer RC Conversion
I just finished my first conversion of a Guillow's kit to radio control flight.
I decided on the Lancer. The Lancer looked like an interesting design, with enough room for the ParkZone electronics and geared electric motor.
The Lancer is easy to build, but a bit fragile for RC flight. I added some fuselage balsa side panels, ply bracing for the landing gear and some balsa filler at the wing root area. Total weight was right at two ounces.
The Lancer fuselage is narrow, so I installed the ParkZone ESC brick vertically, along a fuselage side. The motor fit in the nose perfectly, no mods required. Keep an eye on the CG with the long nose moment. I had to add a bit of tail weight, even working to keep the electronics and battery as far aft as able.
I used So-Lite iron on covering (from Mountain Models). So-Lite worked just great. Not too much shrinkage, and the covering adds a lot of strength to the finished airframe.
The Lancer flies great indoors. The polyhedral wing provides lots of stability. The model was a bit sensitive to rudder on the first flight. The wing offers so much stability, best technique is to "bump" the rudder, just don't hold too long in place.
I am very happy with this Guillow conversion, and look forward to future projects!
Guillow Lancer RC Model Airplane (2 min 17 sec)
ElectroAviator is offline Find More Posts by ElectroAviator
Old Oct 08, 2012, 03:19 PM
joker24458 is offline
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Nice conversion! Still havent converted my 51...
-joker
joker24458 is offline Find More Posts by joker24458
Old Nov 12, 2012, 12:40 PM
sknubel is offline
Find More Posts by sknubel
Joined Nov 2012
Nice conversion ElectroAviator!!! I have a couple of questions...
I am doing the same project, have already bought my kit. I was looking at your photos and paying attention to the stab and rudder. It appears you did not add material to the ends of each, but rather "split" them in half. What did you use for the "new" trailing edge of the stab and leading edge of the elevator? Looks like spare balsa, correct?
Also, where did you get the electronics? Are you able to order them from somewhere, or did they come out of another project....Can you post a parts list and perhaps where you purchased them?
What is meant by the wing root area....where you added balsa filler?
thanks!!! I will post some photos as I work.
sknubel is offline Find More Posts by sknubel
Old Nov 12, 2012, 05:01 PM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Nice conversion! Looks to fly like it might be a tad bit tail heavy. Did you use the free flight CG?
I just picked one of these up at the LHS to build with my grandson. I like the way you mounted the rx on its side, I might have to 'borrow' that idea.
Glenn
glewis is offline Find More Posts by glewis
Old Nov 14, 2012, 08:42 AM
rcminiman is offline
Find More Posts by rcminiman
Scotland
rcminiman's Avatar
Move yer CG forward a little. She's way too tail heavy. Thats why you get the ground-loop problems on takeoff.
Fine wee plane tho, keep up the good work.
rcminiman is offline Find More Posts by rcminiman
Old Nov 26, 2012, 01:49 PM
sknubel is offline
Joined Nov 2012
Stab and Rudder question
How did you deal with the elevator and rudder? Did you just move the whole stab back, so the elevator would clear the rudder. Then trim the rudder, so there was enough room for it to move freely/
Old Dec 08, 2012, 07:16 PM
ElectroAviator
Chicago, IL
Joined Sep 2008
Sknubel,
Apologies for this late reply. Work items and such . . .
I kept the stab and rudder right at the same locations as on the plan. I made a 45 degree angle cut to the rudder to allow for up elevator. Nothing scientific, but worked out just fine.
Tim
Old Dec 08, 2012, 07:30 PM
ElectroAviator
Chicago, IL
Joined Sep 2008
Sknubel,
More info to answer your questions. To make both the rudder and elevator, I just "split" the vertical and horizontal tail surfaces, and used scrap balsa to make an edge. The edge was beveled to allow for rudder and elevator movement, and simple tape hinges used.
I use the ParkZomne motor, ESC brick and battery. The components can be ordered at the Stevens Aeromodel website (do a Google search). Bob Stevens has a section of models dedicated for the ParkZone equipment. I usually go to the Pietenpol airplane section, and then the tab of "other equipment used to complete" where you can easily order all items (to include the props).
For the wing root area, I just meant the wing section that is over the fuselage section. Looked like it needed a bit more strength.
Look forward to any photos you can share!
Regards,
Tim
Old Dec 08, 2012, 07:31 PM
ElectroAviator
Chicago, IL
Joined Sep 2008
Glen,
I used the free flight CG location. It was odd, right at the wing trailing edge. I figured the Guillows folks must have some idea on the reason for that location, maybe due to the lifting stab. Seems to work fine for me.
Tim
Old Dec 08, 2012, 07:34 PM
ElectroAviator
Chicago, IL
Joined Sep 2008
RCMiniMan,
Appreciate the update. I think the CG is in the right location. The Lancer flies really well, with good pitch response. I think the reason for the ground loops on takeoff is the silly-extreme forward location of the landing gear. Not quite sure what I was thinking as I bent the music wire, as the wheels are way too far forward. My main concern was ensuring prop clearance from the ground. For any future build, I'd locate the landing gear a bit further aft.
Tim
Old Jan 03, 2013, 01:21 PM
sknubel is offline
Joined Nov 2012
Thanks Electro...Have not been working on it, busy with the Holidays but plan on getting going on it soon...Thanks for the info!!!
Discussion thirty two inch guillows lancer paulatgis Parkflyers 3 Jun 22, 2012 03:05 PM
Discussion big old guillows lancer flight paulatgis Vintage & Old-Timer Designs 4 Apr 10, 2012 05:17 PM
Discussion Guillows Lancer RC Conversion *Power Questions* finchkid24 Scratchbuilt Indoor and Micro Models 22 Jun 02, 2009 02:37 PM
Discussion Guillows Lancer duration Mr-Punk Free Flight 4 Sep 06, 2007 11:08 PM
Guillow's Lancer- Not great Megowcoupe Scratchbuilt Indoor and Micro Models 5 Sep 07, 2006 07:15 AM
