Old Oct 21, 2012, 04:51 AM
Nestinator is offline
Find More Posts by Nestinator
Joined Aug 2007
@ RC-JG
Have you considered investing in class 1 or 3 of these DVDs? http://www.radiocarbonart.com/produc...r-Class-1.html
http://www.radiocarbonart.com/produc...r-Class-3.html
and later
http://www.radiocarbonart.com/produc...r-Class-2.html
When you consider the questions you've been asking, they may be well worth the outlay. I still watch them from time to time...even for motivation.
Nestinator is offline Find More Posts by Nestinator
Old Oct 21, 2012, 05:08 AM
RC-JG is offline
Find More Posts by RC-JG
RC-JG's Avatar
United Kingdom, Holbeach Saint Johns
Joined Mar 2005
Originally Posted by Nestinator View Post
@ RC-JG
and later
Hello to be honest that thought never crossed my mind - but yeh i will now look into them
RC-JG is offline Find More Posts by RC-JG
Old Oct 21, 2012, 09:30 AM
burke757 is offline
Find More Posts by burke757
United States, VA, Norfolk
Joined Sep 2007
I have my ailerons at the same camber as my flaps for launch.
burke757 is offline Find More Posts by burke757
Old Nov 16, 2012, 07:34 AM
RC-JG is offline
RC-JG's Avatar
Joined Mar 2005
Hello Everyone - Yep i brought that dvd
I have another question about braking - do people use Crow or just Flaps ?
Old Nov 16, 2012, 11:58 AM
Francesco is offline
Find More Posts by Francesco
Francesco's Avatar
United States, CA, Mountain View
Joined Apr 2001
I only use positive camber for braking, i.e. both ailerons and flaps go down. They go down together to about 15 degrees up to halfway of the stick travel, then ailerons stop and only flaps descend to about 65 degrees for the second half of the stick travel.
Francesco is offline Find More Posts by Francesco
Old Nov 16, 2012, 04:49 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
I get more flap travel than that and the second half of my stick travel, the ailerons go back up for crow. Going down together is nice to really slow the model down, but when the lift is strong in the landing zone, the crow really helps.
mlachow is offline Find More Posts by mlachow
Old Nov 17, 2012, 03:59 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
I think most of F3J competitors are using the very basic braking system. Close to 90 degree flap deflection with zero (or very small) aileron movement (a few mm up or down). This is the KISS approach
Personally I do not have any aileron movement in crow. Years back I used some up aileron since it was popular back then. Then with Aspires I tested a setup Francesco described. Having some xtra camber in wing tips was nice at the time when 2.3 kg C68 Aspire was considered as "normal", but I do not see need for that anymore.
Having ailerons at zero setting all the time seems to be a good compromise. Increasing tip camber along with flap movement can be nice with fast/heavy model or in total calm conditions. However, I feel that in stronger winds it slowed down the approach too much and makes the plane feel too high lift.
Choose the setup philosophy you like. Then get flap -> aileron mix dialed just right. Ultimately your landings are 98% about pilot skill and 2% of luck.
Tuomo is offline Find More Posts by Tuomo
Old Nov 17, 2012, 04:08 AM
ak79 is offline
Find More Posts by ak79
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
If you watch master class 2, you will see that most of the guys do not have any flap down the last few seconds of the approach.
They use the flaps to modulate energy earlier in the landing setup and have a nice medium approach speed fairly low, and stick it in with out much flap. The planes seam to be very controllable in this configuration versus lots of flap deflection in the last few seconds of approach. This is something I'm doing to work in next season. Of course this was standard TD contest stuff, not sure how it applies to F3J.
ak79 is offline Find More Posts by ak79
Site Sponsor
Old Nov 17, 2012, 04:19 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
I do not know about TD, but F3J landing is generally quite fast. One could say that if you have to slow down so much that low speed performance is an issue, you are doing something wrong.
Landing flaps down and extra maintenance go together
Old Nov 23, 2014, 01:24 PM
Bernd Brunner is offline
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
Is anyone flying a Supra and one of the newer planes like Maxa or Xplorer and can compare both?
Would be interesting to see what´s changed.
Bernd Brunner is offline Find More Posts by Bernd Brunner
Old Nov 23, 2014, 01:41 PM
Francesco's Avatar
Joined Apr 2001
I have both a Supra Carbon Lite and a Maxa 3.5 Light. Comparable weights.
The Supra has lower overall inertia, rotates faster on tow. But to me it requires more careful "driving" not to end up in uncomfortable attitudes. The Maxa in comparison seems more stable, in both pitch and yaw, and more tolerant to not-so-keen piloting.
I also have a Maxa 4 Light, which is easier to see when flying far away, and more suitable for weak conditions, but that's mostly due to lower wing loading.
Sold Supra Pro-e Competition lite IBWALT Aircraft - Sailplanes (FS/W) 4 May 24, 2012 04:20 PM
For Sale Supra Pro Competition Carbon Lite, Bind and fly.$1800 Wetcoast Aircraft - Sailplanes (FS/W) 2 Mar 25, 2012 10:11 AM
For Sale Supra Pro Competition Carbon Lite, team plane Wetcoast Aircraft - Sailplanes (FS/W) 4 Mar 20, 2012 03:27 PM
Sold Supra Pro Competition NIB (ST and glass layup) RCPC Aircraft - Sailplanes (FS/W) 11 Mar 06, 2012 03:54 PM
Discussion Supra Pro vs Supra Pro Competition brentrob Thermal 9 Oct 08, 2011 01:30 PM
