Old Oct 10, 2012, 10:05 AM
lesterpk is offline
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
Been flying at 103mm for on Supra for 5 years now, seen no need to change.
lesterpk is offline Find More Posts by lesterpk
Old Oct 10, 2012, 10:13 AM
RC-JG is offline
Find More Posts by RC-JG
RC-JG's Avatar
United Kingdom, Holbeach Saint Johns
Joined Mar 2005
Can i ask where your tow hook is in the slot ?
RC-JG is offline Find More Posts by RC-JG
Old Oct 10, 2012, 06:50 PM
Joe W is offline
Find More Posts by Joe W
launch low, fly high
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
For winch towing, I use about 3-5 mm ahead of the aft end of the slot. For a good handtow team, I put the towhook all of the way aft.
Joe W is offline Find More Posts by Joe W
Old Oct 10, 2012, 07:59 PM
lesterpk is offline
lesterpk's Avatar
Joined Oct 2003
What Joe said. Measured both models this morning and found both are at around 4-5mm in front of the rear of the slot. When Joe is throwing at the J WC, it goes all the way back.
Without putting the model together launch flap is only around 12mm IIRC, and I do have the flaps going a couple of mm lower than the ailerons to allow for some blowback.
Old Oct 10, 2012, 08:08 PM
lesterpk is offline
lesterpk's Avatar
Joined Oct 2003
Forgot to mention like JW said that the hook position is tension dependant. So when practicing from a bungee the hook goes fwd to about middle of the slot for safety.
Old Oct 10, 2012, 11:42 PM
Boagy is offline
Find More Posts by Boagy
mmmmm....BEER
Launceston, Tasmania
Joined Jan 2010
Joe & Les were kind enough to give me advice when I was originally setting up my Supra Pro Comp (103mm CG & hook is 3mm from rear of slot). It launches and flies sweeeeeet.
Thanks once again guys.
Steve
Boagy is offline Find More Posts by Boagy
Old Oct 11, 2012, 03:04 AM
Joe W is offline
Joined Dec 2004
Forgot to mention... the elevator setting on launch is the same as the cruise elevator trim setting.
As noted above, the towhook location should be dependent on the expected launch tension. More tension, and the hook can go further aft.
Old Oct 11, 2012, 04:46 AM
RC-JG is offline
RC-JG's Avatar
Joined Mar 2005
Morning Everyone - I will move the tow hook 5mm from the rear of the the slot this afternoon,must say that seems a long way backthink my other glider tow hook was about 3 mm in front of the CG.
Old Oct 11, 2012, 06:35 AM
floquet is offline
Find More Posts by floquet
Hugh Blackburn
floquet's Avatar
Melbourne, Australia
Joined Jun 2005
Here is a summary of my starting setup, based roughly on what Boagy & Joe measured from JW Supra Pro in 2011 (any deviations you can blame on me...). My towhook could go back some, sure JW was further back.
CG 103mm behind LE
Towhook position a little rear of central in slot
All throws linear
ALL MODES:
Elev throws +/- 11mm at TE with neutral approx 38mm above top of boom
Rudder throws +/- 50mm at TE
Aileron->flap mix about 50% at dihedral break, all modes (before setting diff)
Elev->flap/aileron mix about +/-7mm at wing CL, for full elev throws
CAMBER:
Speed mode: lower surfaces approx tangential across hinge line
Cruise mode: upper surfaces approx tangential across hinge line
Thermal mode: about another +2mm at CL
Launch mode: +10mm at CL (relative to cruise). Slightly less than a match at dihedral break
All modes: more camber travel on slider, about +/-3mm (+ elevator trim mix)
AILERON THROWS + DIFFERENTIAL:
Approx +/-13mm at dihedral break in all modes, but as modified by differential
Speed mode: almost no differential
Thermal mode: Enough differential that down-going aileron matches
flap TE deflection at break (so as not to stall inner wing tip with
adverse aileron when circling)
Cruise mode: differential halfway between speed and thermal
Launch mode: 100% differential (no downwards deflection)
AILERON -> RUDDER MIX
Approx +/- 10mm rudder throw with max aileron throw, less in thermal
(because more differential used)
Landing and launch mode: 100% aileron->rudder
Hugh
floquet is offline Find More Posts by floquet
Old Oct 12, 2012, 10:16 AM
RC-JG is offline
RC-JG's Avatar
Joined Mar 2005
Thanks Everyone for your help fingers crossed going test flying tomorrow again
Old Oct 15, 2012, 08:25 AM
lesterpk is offline
lesterpk's Avatar
Joined Oct 2003
Right, took some measurements tonight for you. Reading are in mm from the top of the boom to the top of the elevator TE.
Neutral = 40mm
Speed/reflex = 39.7mm (moved just little down)
Launch = 39mm
Full up = 56mm
Full down = 24mm
Full down with landing flap = 10mm
Also measured launch flap, I had a little more than I thought, 14mm down.
Old Oct 15, 2012, 10:37 AM
RC-JG is offline
RC-JG's Avatar
Joined Mar 2005
Neutral = 40mm
Launch = 39mm
Full up = 56mm
Full down = 24mm
Evening Les
That's grand i have just set all my settings as the same as yours .. ready for this weekend coming Top Man
Old Oct 15, 2012, 08:22 PM
Boagy is offline
mmmmm....BEER
Joined Jan 2010
Neutral = 40mm
Launch = 39mm
Full up = 56mm
Full down = 24mm
You sure that elevator setting for Speed/reflex wasn't 39.75mm Les
Old Oct 20, 2012, 05:57 AM
Nestinator is offline
Find More Posts by Nestinator
Joined Aug 2007
Originally Posted by RC-JG View Post
Everyone - Do you have your ailerons set the same as your flaps on launch ?
I set my entire trailing edge to that of the Supra Template. I set Flap Diff so that the flaps are locked regardless of Aileron movement. Aileron Diff set so that only upward travel is permitted. I set Aileron-to-Rudder rates quite high. On windy days you can pull the trailing edge up by half, partly to reduce loading on glass outer panels but mainly to get up the line faster.
Nestinator is offline Find More Posts by Nestinator
Old Oct 21, 2012, 03:24 AM
RC-JG is offline
RC-JG's Avatar
Joined Mar 2005
Thanks To Everyone Who Has Posted With Advice . . .
I have my flaps working as Ailerons which move up and down a little less than the Ailerons.
Sold Supra Pro-e Competition lite IBWALT Aircraft - Sailplanes (FS/W) 4 May 24, 2012 04:20 PM
For Sale Supra Pro Competition Carbon Lite, Bind and fly.$1800 Wetcoast Aircraft - Sailplanes (FS/W) 2 Mar 25, 2012 10:11 AM
For Sale Supra Pro Competition Carbon Lite, team plane Wetcoast Aircraft - Sailplanes (FS/W) 4 Mar 20, 2012 03:27 PM
Sold Supra Pro Competition NIB (ST and glass layup) RCPC Aircraft - Sailplanes (FS/W) 11 Mar 06, 2012 03:54 PM
Discussion Supra Pro vs Supra Pro Competition brentrob Thermal 9 Oct 08, 2011 01:30 PM
