Flap flex is alarming. This was in almost zero wind with good servos (DS3288) and not too sloppy linkage. Ailerons have obviously much less flap. At the end of long launch you can also see change of launch camber. Normally I do this at much more early stage, maybe 1-2 sec. Using 2 stage camber improved my launch and made it more adaptable to variable conditions. |
Then you must conclude that your servos aren't simply up to the task
Would be interesting to see what it looked like if you used LiFe instead of NiMh?
Have stopped using NiMh and decided that all my gliders to work with LiFe, in one way or another. Uses multiple solutions today but it's probably just a matter of time before all vendors have high current servos. /Ville |
u.k
Joined Mar 2005
Evening Everyone,
Just did some more work on the Supra,found 1 servo horn connection to have a small amount of play on 1 of the flaps so sorted that,set the camber at -2,and it the next day or 2 getting a proper CG jig to check that. Will having the same amount of launch angle on the ailerons as the flaps tend to make it tip stall more ? |
Maybe (just maybe) having radical camber in tip section can provoke tip stalling. But then again, I do not know any modern F3J plane that has nasty tip stall tendencies. You get plenty of warning (directional unstability) before it really bites. |
u.k
Joined Mar 2005
| Thread Tools | |
| Sold Supra Pro-e Competition lite | IBWALT | Aircraft - Sailplanes (FS/W) | 4 | May 24, 2012 04:20 PM |
| For Sale Supra Pro Competition Carbon Lite, Bind and fly.$1800 | Wetcoast | Aircraft - Sailplanes (FS/W) | 2 | Mar 25, 2012 10:11 AM |
| For Sale Supra Pro Competition Carbon Lite, team plane | Wetcoast | Aircraft - Sailplanes (FS/W) | 4 | Mar 20, 2012 03:27 PM |
| Sold Supra Pro Competition NIB (ST and glass layup) | RCPC | Aircraft - Sailplanes (FS/W) | 11 | Mar 06, 2012 03:54 PM |
| Discussion Supra Pro vs Supra Pro Competition | brentrob | Thermal | 9 | Oct 08, 2011 01:30 PM |
