Old Oct 12, 2012, 08:29 AM
Brandano is online now
Find More Posts by Brandano
Why should there be any thrust if the propulsor can't accelerate air to a speed higher than that of the plane?
Brandano is online now Find More Posts by Brandano
Old Oct 12, 2012, 10:42 AM
TangoKilo is offline
Find More Posts by TangoKilo
Joined Oct 2012
Tell me what is pushing your plane along at "a speed" (against the resistance of aerodynamic drag) if there is no thrust.
Not only that, if your propulsor is not producing any thrust it is not doing any work so it won't need any power input. Why do you need "wide open throttle" to achieve maximum speed? Where is the power going?
TangoKilo is offline Find More Posts by TangoKilo
Old Oct 12, 2012, 11:58 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Into countering the aerodynamic drag.
BMatthews is offline Find More Posts by BMatthews
Old Oct 12, 2012, 12:25 PM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
If the propeller is providing zero available thrust, then the work from thrust available is W = T_A * V_infinity = 0. However, the work from the motor is the product of the angular velocity of the shaft and the torque. In steady state, the torque on the shaft from the motor is equal and opposite to the torque on the shaft from the propeller, which will be nonzero.
DPATE is offline Find More Posts by DPATE
Old Oct 12, 2012, 02:40 PM
A slight dive? If the efflux velocity is matching that of the free airstream the engine is just wasting energy as heat. A plane could never exceed the speed of the efflux from its propeller or jet engines in balanced level flight, which is one reason why hypersonic engines are exotic affairs or rockets. This does not mean that a plane can't go faster than the speed a prop can accelerate air on a stand. The prop adds speed to the airstream, so what you measure on a stand is not what you will have on the plane.
Old Oct 12, 2012, 06:36 PM
Joined Oct 2012
If the propeller is doing no work, there is no resistance to rotation (torque).
Angular velocity times nothing equals nothing.
Torque required from motor - none. Power required - none.
Old Oct 12, 2012, 06:46 PM
Joined Oct 2012
"A plane could never exceed the speed of the efflux from its propeller..." but "This does not mean that a plane can't go faster than the speed a prop can accelerate air on a stand."
It is twenty five minutes past one here, I've had a good dinner and a few glasses of cognac. I can't be bothered to work out what you mean. Good night.
Old Oct 12, 2012, 07:14 PM
DPATE is offline
Joined Oct 2010
The there will be profile drag on the propeller whether it is producing thrust or not. Of course, this drag produces a torque on the shaft.
Old Oct 13, 2012, 04:25 AM
Joined Oct 2012
OK, let me put it another way.
If the propeller is doing no work in producing thrust, there is very little resistance to rotation (torque).
Angular velocity times very little equals an insignificant amount.
Torque required from motor - insignificant amount.
Power required - insignificant amount.
Battery life at maximum speed - about three years.
(Last sentence was a joke by the way, before you correct me)
Old Oct 13, 2012, 06:01 AM
Surface drag is quadratically related to speed. The same is true for friction drag in the bearings of the motor. Energy is dissipated as heat in both cases. You can do no work and waste a lot of energy all the same.
Old Oct 13, 2012, 06:26 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
stumax did a little program that did the job
70 mm exhaust 1.8 pounds = 45.6 m/sec
clausxpf is offline Find More Posts by clausxpf
Old Oct 13, 2012, 09:27 AM
ShoeDLG is offline
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
The propeller of a 3D plane in a hover is supplying zero power to the airplane ( power = thrust times velocity). In a hover, the propeller experiences significant resistance to rotation. The input power (torque times RPM) is likely quite high.
ShoeDLG is offline Find More Posts by ShoeDLG
Old Oct 13, 2012, 11:45 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Those are opposite situations. In hover, the induced power is quite high (relatively large amount of acceleration of the air). When the speed of a ducted fan aircraft reaches the efflux velocity (if that could happen), the induced power is zero but the parasite power (from drag of the aircraft) and profile power (from drag of the propeller blades) are quite high.
In the first situation, the total power required by the motor is just the induced power. In the second situation, there is no contribution from induced power.
Montag DP is offline Find More Posts by Montag DP
Old Oct 13, 2012, 01:26 PM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
Montag,
I wasn't comparing the induced to the profile power, but instead comparing the power delivered by the propeller to a hovering airplane to the power required to turn the propeller.
Old Oct 14, 2012, 05:38 PM
Joined Oct 2012
Gentlemen, this is becoming a bit silly. What on earth is “parasite power” or “profile power”?
It doesn’t matter if you are hovering or flying straight and level. In the first case the thrust is countering weight, in the second the thrust is countering drag. If the drag, (in the second hypothetical case) were to be the same as the weight (in the first hypothetical case) the same amount of thrust would be required.
Thrust is the equal and opposite reaction to a moving mass of air relative to a frame of reference, so the velocity term must be the velocity of that moving air relative to the same frame of reference. It makes no difference if the model is moving (has momentum) or not as long as the same frame of reference is used.
Just because the hovering model is not moving does not mean that no power is being produced. If a motor is drawing a number of Watts of electrical power there must be a number of Watts of output power (depending on the efficiency) whether the body, to which the motor is attached, is moving or not. It is a mass of air which is moving and that mass of air and its velocity are factors of the output power.
Similarly, the propulsion system of a model moving at maximum speed is also producing thrust. The thrust is that required to equal the drag at that speed and is a factor of the output power.
Output power is half mass flow times velocity squared.
There is electrical power going in and there is mechanical power (in the form of moving air) going out.
The efficiency of a propulsion unit is the percentage of power going in which is converted to useful power output. If, for example, the efficiency of a propulsion unit is 75%, the useful power output is 75% of the electrical power input. Profile drag, bearing friction, and wasted heat are only a part of the 25% losses, they will only consume a small part of the power input.
The power required to turn the propeller is part of the efficiency equation, the power transferred to the air by the turning propeller is another part of the same equation.
Incidently, shaft power is torque times angular velocity, not RPM.
Sold 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 2 Jun 16, 2012 11:58 PM
For Sale 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 0 Mar 02, 2012 06:33 PM
Sold NIP Velocity WM400MK2 70mm Ducted Fan OCLightning Aircraft - Electric - Jets (FS/W) 4 Apr 16, 2010 01:48 PM
Discussion Estes Air Force Ducted Fan Jet In Action FlyBoyTha1 Foamy EDFs 0 Jan 02, 2009 12:43 PM
