Old Oct 06, 2012, 05:18 AM
renasis is offline
Find More Posts by renasis
renasis
Joined Oct 2012
Quadcopter long flight time
Hello,
I have been thinking about making a quadcopter that can run for a very long time. Why not use helium for the buoyancy needed to offset the weight of the quadcopter components? I googled this and found very little, I am surprised, why not?
-ren
renasis is offline Find More Posts by renasis
Old Oct 06, 2012, 05:25 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
i think that would make it a blimp!?
socommk23 is offline Find More Posts by socommk23
Old Oct 06, 2012, 09:04 PM
WonderKing is offline
Find More Posts by WonderKing
WonderKing's Avatar
Indonesia, Jakarta
Joined Sep 2012
Blimpcopter!
Uploaded with ImageShack.us
WonderKing is offline Find More Posts by WonderKing
Old Oct 07, 2012, 12:39 AM
jseyfert3 is offline
Find More Posts by jseyfert3
Posted as eflightdude 06-07
United States, IL, Peoria
Joined Aug 2012
Originally Posted by renasis View Post
Hello,
-ren
Simple physics, that's why. To lift 2.15 lbs you need a balloon with a diameter of 4 feet. What about lifting less weight? Well, to lift only 0.93 lbs, you still need a balloon with a diameter of 3 feet. http://www.stevespangler.com/in-the-...ysics-science/ As you can see, this gives you a blimp, not a quad, as socommk23 already said. And then there is no point in having the motor arrangement of a quad, you would be better suiting to mounting your motors vertically to provide forward and sidewise thrust, and only keeping one mounted vertically to allow easy ascent/decent. If you want a blimp, there's a section of RCG dedicated to that.
If, however, you want a quad, then your max flight time is obtained when the weight of your battery equals the weight of your quad minus the battery. In other words, the battery is half the ready to fly weight of the quad. Any more and you lose flight time do to the battery weighing too much, any less and you lose flight time because you aren't carrying as much battery as you could. Of course that's just the batteries, you also have to factor in motor efficiency, prop efficiency, proper prop size, etc.
Lots of good info here, you just have to have the time and willingness to sort through it all.
Also, to quote my physics teacher when I asked if making a small, autonomous line following speed robot if the best turning ability used more mass for a heavier weight for more tire friction but a larger inertial factor, or less mass which gives less tire friction but less inertia: "That has a lot of variables, many of which we haven't covered yet. Is it something you're going to build?" "Well, yes." "Then experiment." He smiled, and turned back to his work as I left. Needless to say, me and another guy will be experimenting quite a bit on the line follower for the competition in March, as we both plan on being the winning team.
jseyfert3 is offline Find More Posts by jseyfert3
Old Oct 07, 2012, 01:32 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
lol blimpcopter
gitit20 is offline Find More Posts by gitit20
Old Oct 07, 2012, 02:03 AM
rmteo is offline
Find More Posts by rmteo
User
Colorado
To get a high endurance vehicle (several hours+) with VTOL capability using today's technology, you'll have to go with a single rotor design powered by a fuel burning engine (internal combustion or perhaps gas turbine). No multi-rotor configurations or batteries will cut it. Be aware, however, that you will basically need to design a flying fuel tank.
Actually, there is one other option - the blimp that you are proposing.
rmteo is offline Find More Posts by rmteo
Old Oct 08, 2012, 10:42 PM
gitit20 is offline
gitit20's Avatar
Joined May 2012
Not correct if you have the money you can get one of these 4 to 8 hours of flight time
http://uniteddrones.com/products/aether-aero/
Old Oct 08, 2012, 11:00 PM
TayNinh68 is offline
Find More Posts by TayNinh68
Mosquito 6
Joined Jun 2012
Luv the ladders .. for miniature police persons .. damn cute I'd say
TayNinh68 is offline Find More Posts by TayNinh68
Old Oct 08, 2012, 11:13 PM
rmteo is offline
User
Colorado
Good one!!
And if you really have the money then one of these will give you 14 hours of endurance with a payload capacity of 600-700lb.
Old Oct 09, 2012, 01:00 AM
Mosquito 6
Joined Jun 2012
Hello,
-ren
Well, certainly it would fly, if you disconnect the dern tank silly Just joking Ren
Advantages: Long flight time .. long linger time .. payload dependent on balloon size .. very easy to see at great distances .. big enough balloon maybe sell ad space .. event managers may look more kindly at overhead videos with your future proven technology .. visa-vi; airworthiness.
Disadvantages: Very slow .. hard to maneuver .. even harder to maneuver with any wind .. can't do aerobatics or evasive manuevers .. clean air restricted to rotors reducing lift .. zero stealth during moonlight or brighter flights .. if your balloon fails your rotors will briefly churn balloon skin as the aircraft plummets to the ground while your left thumb instinctively attempts to burn stuff up .. and as mentioned previously, very easy to see at great distances .. which makes for some slightly challenging target practice for some nefarious person if so inclined .. even a .22 at 400 yards.
We do have a Lighter than air section here .. http://www.rcgroups.com/blimps-62/ but meanwhile, this guy would probably love for you to build him one
www.youtube.com/watch?v=Z7437gB3Cxo (video is argueably germane to this post, but OT for rcgroups in general, so c/p into u-tbe; .22@400 yds 2:33 .. my apologies)
How about making some large bird like balloons soo the gunners wouldn't have to blast away at (Cheneyerize) quail. While I make this post tongue in cheek, albeit with many truisms, serious marksmen want challenges and someone's gonna do this and make a business of it (using LiFeP04 of course)
Old Jul 15, 2013, 11:17 AM
powerblimp is offline
Find More Posts by powerblimp
rc blimp manufacturer
powerblimp's Avatar
Switzerland, VD, Crans-près-Céligny
Joined Dec 2005
Originally Posted by WonderKing View Post
Blimpcopter!
hello i have tried that solution with a 2.3m sphere
mk basis with 2 x fww engines
test ball cam (7 min 12 sec)
pretty hard to go straight but very long flight time with 2.5 kg payload
+ 2 hours ...
but max wind less than 20 km/h !
shall be improved
cheers phil
P.S i dont work for minizepp anymore
powerblimp is offline Find More Posts by powerblimp
Help! Long time viewer, first time poster. Need help with my KKboard Quad... IBeHoey Multirotor Talk 5 Sep 24, 2012 04:11 PM
For Sale AeroQuad Quadcopter FS, FPV Trimmed, Low flight time rcpilotp51 Aircraft - Electric - Multirotor (FS/W) 1 Aug 27, 2012 08:28 AM
Discussion What is the best mutlicopter for dslr and long flight time yepe Multirotor Talk 44 Aug 21, 2012 06:37 AM
Question Theoretical flight-time -vs.- practical Flight-time vineet_p Multirotor Talk 16 May 26, 2012 01:49 PM
Discussion New Lipo's: Long Charge Time & Short Flight Time? jsteel Batteries and Chargers 9 Apr 24, 2007 12:50 AM
