Old Oct 07, 2012, 05:27 PM
m.schlage is offline
Find More Posts by m.schlage
Joined Jun 2012
not good!
http://m.youtube.com/#/watch?list=TL...FRyeCbxI&gl=DE.
Marcel Schlage
m.schlage is offline Find More Posts by m.schlage
Old Oct 07, 2012, 10:38 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
yep... looks like the lack of vertical tail area caused that instability..
BulletMaster is offline Find More Posts by BulletMaster
Old Oct 08, 2012, 09:10 AM
Steve C is online now
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Looked pretty impressive to me!
Good pilot didn't panic and pull a bunch of elevator.
Steve C is online now Find More Posts by Steve C
Old Oct 08, 2012, 09:46 AM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
Hmmm! Maybe it's not such a great idea after all. Mind you, If I found away, and I could make them get away as cleanly as the F3K's do without adding to much drag in the process. It could be a good idea?
I have a feeling weight distrubution has alot to do with it. F3K models are so light and dont have a great big motor up in the nose. Something to do with circular motion and angular momentum.
Now i think about it an F5D model will probably need ALOT more fin area to get away cleanly after a discus lauch... Probably not worth the extra drag?
SB7 is offline Find More Posts by SB7
Old Oct 08, 2012, 10:13 AM
shhhhh! is offline
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Originally Posted by Dbox View Post
I have done it once and would not recommend to anybody,experienced or not.
Have to say ,I been practicing DLG launches,with DLG planes, since 1997 ,so not a beginner in technique.
Totally different behavior for F5D plane ,for many many reasons.
I will mention just one- all F5D planes have about 3 times smaller vertical tail then regular DLG plane which makes huge difference in stability of the frame on launch.
Otherwords,instead of going straight after leaving Your hand,plane spins horizontally .
....but it brings more spice to whole flying event
Still wanna try
Yuri
Yes........................+1
shhhhh! is offline Find More Posts by shhhhh!
Old Oct 09, 2012, 03:44 AM
Paul.S is offline
Find More Posts by Paul.S
Paul.S's Avatar
Aachen, very western Germany
Joined Sep 2007
Another pretty important value in this consideration is the inertia of the plane. With the gear drive in it, it's much higher and would need an even bigger vertical tail or lever than a DLG.
...Edit: SlowBarless said it all already.
Paul.S is offline Find More Posts by Paul.S
Old Oct 10, 2012, 08:41 AM
epwierman is offline
Find More Posts by epwierman
epwierman's Avatar
Joined Aug 2004
Interesting idea. In my limited discus experience, a rudder and yaw gyro made things very safe and easy for learning the ins and outs. With those two elements, and maybe a longer tail moment, perhaps you could get the result you are looking for, without having to go big on the vert fin surface. Looking forward to seeing the results of your experience. It would surely have the potentential to revolutionize F5D and maybe B as well.
epwierman is offline Find More Posts by epwierman
Old Oct 10, 2012, 09:51 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Except no gyros in B or D allowed.
Troy is offline Find More Posts by Troy
Old Oct 10, 2012, 10:23 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Maybe if you had a peg mounted between the wingtip and the fuse somehow, to lessen the rotation of the airframe at release... not sure how you'd actually get hold of it though!
Maybe a super streamlined peg coming out of the bottom of the wing, at half span, that you hold onto with your index finger...
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Oct 10, 2012, 10:41 PM
epwierman's Avatar
Joined Aug 2004
Troy, forgot to thank you for the flying car video. Too cool!!!!
Cool Attention to all you Hand Launch, Discus Launch, F3K pilots aeajr Sailplane Talk 5 Jul 23, 2012 07:43 AM
Sold HJZ Predator 2 Discus Hand Launch glider checkprop Aircraft - Sailplanes (FS/W) 1 Jul 20, 2012 08:21 PM
Sold HJZ Predator 2 Discus Hand Launch glider checkprop Aircraft - Sailplanes (FS/W) 5 Jul 14, 2012 08:19 PM
For Sale HJZ Predator 2 Dlg Discus Hand Launch Glider checkprop Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jun 30, 2012 12:25 PM
Sold Carbon/Kevlar DLG Discus Launch Glider RTF - $400 OBO sdueck Aircraft - Sailplanes (FS/W) 1 Jun 11, 2012 07:26 PM
