| Thread Tools |
| This thread is privately moderated by TheFernMan, who may elect to delete unwanted replies. |
FLASHED HobbkyKing F-20A ESCs with lastest 2012-09-30 SimonK with bootloader enabled
![]() 5x HobbyKing F-20A @ $15 each "Standard ESCs are actually not designed for multirotor applications. They are programmed to increase and decrease the throttle command towards the motor in a gentle way. The reason for this is quite obvious. Imagine a motor accelerating and decelerating so abruptly in a helicopter or car... it would damage the gears and reductions in no time. In a multirotor application, we really want just the opposite. The goal is to change the motor speed, and thus the thrust, as fast as possible to achieve a perfectly stable platform. While the current ESCs used in most multrotor applications work considerably well, there is a lot of room for improvement. Using the same ESC, but loading it with dedicated optimized software, will increase the handling and stability of your multirotor greatly. We call this RapidESC: converting your regular lazy ESC into a high speed capable speed controller at no extra cost, ready for multirotor applications."* These are one of the best types of ESCs for the SimonK firmware. Read first post here All N-Fet: "The ESCs which use only N-channel FETs have the advantage of lower resistance, less losses and hence more efficiency."* External Oscillator: "An external oscillator may supply a more consistent timing signal and steadier motor speeds" "but the internal rc oscillator ones will drift quite a bit based on temperature."* HobbyKing F-20A Tested and flashed with latest SimonK with bootloader enabled so you can flash them in the future thought the servo cable with the USB linker from HobbyKing. I cut a little flap out and use clear tape to cover the opening. You can barely tell. Selling them for $15 each ESC plus shipping US shipping only. If you're interested send me a PM so I get proper shipping with your address. I'll be doing USPS shipping. It's $6. Any question feel free to ask. References: What is RapidEsc (Simonk firmware) All N-Fet Design External Oscillators |
| Thread Tools | |
| Sold FLASHED HobbkyKing F-30A ESCs with SimonK with bootloader enabled | TheFernMan | Aircraft - Electric - Multirotor (FS/W) | 0 | Oct 03, 2012 08:50 AM |
| Sold HobbkyKing 30A ESCs with SimonK with bootloader enabled | TheFernMan | Aircraft - Electric - Multirotor (FS/W) | 27 | Sep 29, 2012 01:03 PM |
| Sold FLASHED HobbkyKing F-30A ESCs with SimonK with bootloader enabled | TheFernMan | Aircraft - Electric - Multirotor (FS/W) | 7 | Sep 28, 2012 08:48 PM |
| Wanted Need (4+) 30A ESC Flashed with SimonK | Epoxies | Aircraft - Electric - Multirotor (FS/W) | 5 | Aug 12, 2012 05:20 PM |
| For Sale 30A ESCs simonK with bootloader | FlyinGizm0 | Aircraft - Electric - Multirotor (FS/W) | 2 | Aug 03, 2012 12:00 AM |
