Old Oct 05, 2012, 11:45 AM
crash25 is offline
Find More Posts by crash25
Joined Dec 2008
Aerofoil pattern
Hi don't know if any one can help but I'm after some where that I can download aerofoil patterns for gliders. I want to design and build a glider that is a floaty slow glider I'm looking at about a 1.5m wing. It will have a carbon boom and a fibreglass pod any help would be greatly appreciated
crash25 is offline Find More Posts by crash25
Old Oct 05, 2012, 01:21 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Why not a DLG wing? They are easily made and the AG airfoils are readily available.
http://www.monkeytumble.com/dlg/supergee.htm
davidjensen is offline Find More Posts by davidjensen
Old Oct 05, 2012, 02:08 PM
crash25 is offline
Joined Dec 2008
I did look at that but Iv never used fibreglass and have only ever built with bulsa. I would like to get in to dlg but as I can not afford it building something is the way Iv got to go
Old Oct 05, 2012, 02:11 PM
GeeW is offline
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
http://www.profili2.com/eng/default.htm
GeeW is offline Find More Posts by GeeW
Old Oct 05, 2012, 02:29 PM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
The MiMi has plans that include a built up wing, it uses the AG03 airfoil. The Quick Flick 2 also has a built up wing, not sure which airfoil it uses.
Info on both gliders are down in the Handlaunch section.
But honestly foam is easy to cut yourself and a lot cheaper then balsa. Just cover the foam with 3/4 ounce glass and attach it with Minnwax Polycrylic. Very effective, quick and cheap!
Blue Skies.............................Tim
RWCLOUD is offline Find More Posts by RWCLOUD
Old Oct 05, 2012, 03:48 PM
crash25 is offline
Joined Dec 2008
Thanks for the info but could some one offer some links with tips on how to build with fibreglass or any one wanting to sell a dlg that is in the uk or will ship to the uk thanks
Old Oct 05, 2012, 08:31 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
If you want really floaty and really slow, check out some of the ff towline gliders at outerzone.co.uk Of course most of them are TOO floaty for an RC glider. Another place you can look is here:
http://www.ae.illinois.edu/m-selig/uiuc_lsat.html
and here:
http://www.ae.illinois.edu/m-selig/a..._database.html
I agree that Profili is very useful for evaluating and plotting airfoils.
You can learn a lot about design here:
http://charlesriverrc.org/articles.htm#On-Line%20Plans
You might think about a larger Apogee. The small ones stay up ok, but they're fast for their size so I wouldn't exactly call them floaters.
You can learn a lot by looking at one of these:
http://www.djaerotech.com/dj_product/chrysalis.html
You can learn even more by building one. I owned one for a few years and they fly very nicely. Float quite well but also have reasonable speed range. And they're simple. And inexpensive.
Any reason for the 1.5 meter size? They float better when they get larger, usually.
lincoln is offline Find More Posts by lincoln
Old Oct 06, 2012, 10:31 AM
crash25 is offline
Joined Dec 2008
1.5m as it will fit in my van in one peace. Up can go bigger if its better I'm now thinking maybe put a motor on it as a f5j. And after looking on the net I'm also looking for dlg bulsa plans but want some thing with ailerons and maybe my wallet can stretch to a kit
Old Oct 06, 2012, 12:35 PM
kw5368 is offline
Find More Posts by kw5368
United States, WV, Beverly
Joined Mar 2004
Here's a link to the short kit Quick Flik 2 mentioned above. There are links to a lot more information from this page about the plane. You can also get the full kit at this website.
http://www.mountainmodels.com/produc...0dc91bd834ed4c
Ken
kw5368 is offline Find More Posts by kw5368
Old Oct 06, 2012, 08:27 PM
lincoln is offline
Joined Dec 2001
If you're considering the QF2, you might also consider:
http://www.wrightbrothersrc.com/products/gambler.htm
Lots of the larger gliders have two or three piece wings. This is true, for instance, of the Gentle Lady and the Olympic 2, and I think it's true of the SIg Riser 2 meter, all nice handling, slow gliders. The Olympic II is 100 inch wingspan. The two piece wing fits pretty well crosswise in the back seat of my car*, or I could put it in the trunk if there weren't too many other things in there.
I carry two 3 meter gliders in the front seat. If I folded down the rear seat, I could keep them in back. At the same time, I can carry a 1.5 meter glider and an Olympic 2 or a Radian. Not much room for passengers with all those on board, however, unless I put the ski box on the roof.
*93 Saturn SL1, which is pretty small and gets 35 mpg on long trips
Old Oct 06, 2012, 08:28 PM
lincoln is offline
Joined Dec 2001
A good dlg will not exactly be floaty and slow, because then it wouldn't launch very well.
Old Oct 06, 2012, 08:46 PM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
United States, AZ, Tucson
Joined Jan 2007
I think a really good airfoil for that span would be the S-4083. I have a CR Climmax that is using one to good effect. As good as the SD-7037 is the 4083 has it beat in my opinion. It can float or scoot as necessary.
prodjx is offline Find More Posts by prodjx
Help! Required Nasa 0014, Nasa 0029 & Nasa 0030 aerofoil data Glueit The Builders Workshop 7 Sep 11, 2012 02:43 PM
Mini-HowTo hotwire-free aerofoil flying wing =) baconflyer Flying Wings 17 Jul 26, 2012 11:51 PM
Discussion CM Analysis in Aerofoil Selection Billy88 Modeling Science 20 Apr 13, 2012 01:50 PM
Discussion I need aerofoils please Billy88 Modeling Science 9 Mar 24, 2012 04:01 PM
Help! Aerofoil templates? Anjan Babu Electric Plane Talk 7 Feb 23, 2012 05:08 PM
