Old Oct 05, 2012, 11:19 AM
DCDetector is offline
Find More Posts by DCDetector
DCDetector's Avatar
United States, KS, Dodge City
Joined Sep 2012
CX2 spinning clockwise no matter what I do?
Changed out the lower head/hub on my CX2 and now whether I give it left or right YAW/left stick it just spins fast clockwise? If I let the stick go to neutral the spin slows down. Left or right stick, and throttle, it spins fast clockwise.
DCDetector is offline Find More Posts by DCDetector
Old Oct 06, 2012, 03:37 AM
JDFiend is offline
Find More Posts by JDFiend
JDFiend's Avatar
Denver, CO
Joined Mar 2009
It sounds like one of your gears is slipping on the shaft. Check the B gear, and make sure it is fitting tight on the inner shaft. Also, make sure both motor pinions are making proper contact with both gears.
JDFiend is offline Find More Posts by JDFiend
Old Oct 06, 2012, 08:46 AM
flyeraroo is offline
Find More Posts by flyeraroo
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
Could be your motor wires have gotten switched around going to the control unit.
flyeraroo is offline Find More Posts by flyeraroo
Old Oct 07, 2012, 05:03 AM
DCDetector's Avatar
Joined Sep 2012
Found a loose screw on the lower gear. After tightening it up the problem was gone.
Old Oct 08, 2012, 08:50 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Just make sure you hit the flat spot with the screw. Otherwise you'll run into the same problem in short order.
http://www.dacaur.com/heli/bcxhelp/BladeCXAssembly.pdf
BTW, here is the "official" CX2 thread. You may want to put this in your subscriptions for further use.
http://www.rcgroups.com/forums/showt...07057&page=510
Welcome to RCG,
Mike.
Chap1012 is offline Find More Posts by Chap1012
Whoops! Check your control surfaces no matter what people! Oberst Crash Discussion 7 Aug 31, 2012 09:46 AM
Discussion ESCs going into cutoff no matter what. GTASouthPark Multirotor Electronics 3 Jul 25, 2012 10:56 AM
Discussion What to do with neutral/bad itrader rating when no transaction as made Hmerly Trader Talk 18 Jul 17, 2012 05:32 PM
Build Log Have no clue what I'm doing... EPP Air/Swamp Boat KTMRacr Dock Talk 17 Jul 16, 2012 11:24 AM
Discussion What mode do we fly and do you think it matters? Norfolk Flyer Auto Gyros 27 Jan 05, 2010 11:42 PM
