Old Dec 20, 2003, 07:31 AM
Jim Miller is offline
Find More Posts by Jim Miller
Parkton, MD
Joined Dec 2000
RysiuM
How are you measuring power out? Did you make a torque meter?
tnx
jtm
Jim Miller is offline Find More Posts by Jim Miller
Old Dec 20, 2003, 01:20 PM
rysium is offline
Find More Posts by rysium
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Originally posted by Jim Miller
RysiuM
No, not yet. I will. Soon.
I used my prop calculator based on prop size and rpm. I looks like it's not much off when I run Takao's data and his measured results.
I know, it's still not 100% correct, but I hope maybe +/- 10%.
When I build my torque meter I will know for sure.
RysiuM
rysium is offline Find More Posts by rysium
Old Dec 20, 2003, 09:09 PM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Re-measured the copper loss
I had used my DC power supply source meter.
The measureing current is 0.5A.
The copper wire resinstance at one phase wing is 0.3056 ohm.
The copper loss is 5.7^2 * 0.3=9.75W at APC 5.5x4.5, 10kRPM Direct Drive, 2s E-tec.
Also, We have to consider the loss on ESC MOSFET, It is about 15mill. ohm.
Obviously, 3s system is better by this result.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Dec 21, 2003, 06:35 PM
taekwondo is offline
Find More Posts by taekwondo
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
Gentlemen:
This thread is fascinating. I couldn't wait to get home and give it a try so forgive me for asking stupid questions and being behind the 8 ball. Here is what I got so far. I took the cdrom apart and split the motor in 2 pieces. I think next referring to the original post, I must de solder and rewire into a delta position? Is that absolutely necessary or will the motor work without all that rework?
taekwondo is offline Find More Posts by taekwondo
Old Dec 21, 2003, 06:48 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
new photo
Sorry, the file was too big. I shrunk it down and this should work I hope.
Old Dec 21, 2003, 06:51 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
And if you look at the above pic, should I separate the 2 pieces to the right? ie. the ones attached that are not the wires or magnets but the two at the right of the picture?
Old Dec 21, 2003, 08:31 PM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
OK,
First off you need to remove the stator it is the one on the left then you can rewind it re a semble it and solder it up and you should be good to go!
rcflyer2
Littlescreamers is offline Find More Posts by Littlescreamers
Old Dec 21, 2003, 09:30 PM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
The motor should work "as is". The Kv of the motor (rpm/V) is usually too low, it is working, but at 6-8 cells the maximum rpm and power is too low.
If you reconnect it to delta, the result is 1,7 times higher Kv. Similar result, if you rewind it with a thicker wire and 1,7 times lower turn number.
If your magnet ring is black, then the motor can't give really good power and efficiency unless you replace the ring to 12 pcs of neodym magnets. The grey ring is much better then a black one...
mmormota is offline Find More Posts by mmormota
Old Dec 21, 2003, 09:54 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
RCflyer and mrmota:
Thanks for your input. To remove the stator? Sorry for my ignorance, what is a stator? Never mind. The one on the left is the entire stator then if I desolder it and rewind it with thicker wire and 1-7 turns in a delta config I should get more kv? Question I have, the stator has 3 wires soldered to the plate, if I desolder them, looking at the original diagram from thread 1 I see 3 separate wires and three spliced wires, but mine only has 3 separate wires (ie. green red and blue in the original diagram). So (WAIT i THINK I GET IT). I rewire it completely different with the new wire? That seems to make sense. Please let me know, and what gauge copper wire should I use? It seems mrmota recommends 1-7 turns, is that correct? How many turns would you recommend? Thanks, this is my first time, but it's awesome, I feel like a kid! Thanks again. Henry.
Old Dec 21, 2003, 11:59 PM
Joined Nov 2003
Hi
My best advice would be to go back to the first page of this thread and click on the link to the first post about this subject and read read read!
rcflyer2
Old Dec 22, 2003, 01:23 AM
rysium is offline
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Mitsumi model CRMC-FX001D
This is something I've seen the first time. This CD-ROM has very unusual motor. I would say Coreless
Obviously I can't rewind it (not at home) does anyone have an idea how to connect it to be able to run it? I'm just very curious how it will behave.
The rotor is a flat plate with flat magnetic ring. So it's not a bell, but ring running in front of the coils.
As you see on the picture it has 6 poles (3 are small and 3 are bigger) and the rotor has 8 poles (quite strong magnet). The motor weights about 20g but can be shaved a little.
The coils are 1.3mm high, and the thickness of the whole motor is 7mm.
Any suggestions?
RysiuM
Old Dec 22, 2003, 02:15 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
rysium
Looking at your efficiency values, I did a quick calc. and come out at a very different value. The efficiency formula I use is
Prop dia to power of 4 --- multiplied by pitch --- multiplied by rpm to power of 3 --- multiplied by prop factor K. -- typical 1.11 (found via a link somewhere here)
All measurements in feet and RPM in thousands.
Thus
Diameter = 9 inch = 9/12 y/x of 4 = 0,316
Pitch = 4.7 = 4.7/12 = 0.3916
RPM = 4620 = 4.620 y/x of 3 = 98.61
Therefore efficiency = 0,316 x 0,3916 x 98.61 = 12.20 Watts to prop
K factor included (depending on prop) = 13.5 Watts to prop.
Efficiency therefore = 35%
Now have I got something wrong? If I have got it wrong, then my motor is looking awfully good for a CD-rom. So somebody please give me the real formula.
Mr DIY is offline Find More Posts by Mr DIY
Old Dec 22, 2003, 03:17 AM
rysium is offline
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Originally posted by Mr DIY
rysium
I run your data through my calculator. Don't ask me what the formula is because I just don't remember. I did it a couple years ago base on HP Static Thtust calculator program (and it's formulas). Anyway, my result is power out =17.17W, static thrust = 6.72oz)
I checke alse the site :
http://www.andersonparkflyers.org/flight-calc.htm
And when I put yopur data through ThrustHP calculator (ver 2.0d) I got HP = 0.022 (16.4W) and static thrust = 0.44lb = 7.4oz
I don't know why they are off, but maybe different prop data were used.
I just printed formulas from ThrustHP calculator:
Formulas from AMA mag Oct 86
Load = Prop Diameter^4 * Pitch
Speed = Pitch * rpm * 0.000947
Horse Power = Load * rpm^3 / 1.4 * 10^17
Static Thrust = 0.00000000000283 * rpm^2 * Prop Diameter^4 * Air Density/29.92 * CF value
Prop data is in [inch], horse power = [745W], Static thrust is in [lb]
I hope this helps,
RysiuM
Old Dec 22, 2003, 03:35 AM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Re: Mitsumi model CRMC-FX001D
Any suggestions?
RysiuM
That's very classic. Mitsumi double speed drive from '93, one of the first double speed bundled with SoundBlaster or Gateway PCs. It is even not IDE interfaced....
It should run as standard 3 phase DC BL motor. Of cource you should be able to connect coils to delta to have some more power. It reminds me the motor built in MicroFlight article. http://www.rcmicroflight.com/library/motor1.asp
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Dec 22, 2003, 04:03 AM
Mr DIY is offline
Mr DIY's Avatar
South Africa
Joined Aug 2003
Thanx for your feedback rysium
Not sure exactly what you are saying, but using a K factor of 1.11, I still get the figure listed. Not sure how you get your 17 Watts. Ether way though, it a long way off the 26 Watt and 70% efficiency you had listed before.
The rest of the formula listed is certainly interesting though.
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 03:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 08:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 08:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 10:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 02:03 PM
