Old Dec 14, 2003, 03:41 AM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Re: Brushless mystery uncovered - part two
rysium,
It's called "synchronous motor"
Who said that?
ESC does not control driving with any motor rotation drive frequency.
I can not call it "synchronous motor".
Takao
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Dec 14, 2003, 10:40 AM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
Man, how do you guys remove the stator?? I hammered/twisted/plied at it for an hour and all I'm doing is deforming and generally totally maiming the bushing and metal mount... the brass bushing is NOT giving way anytime!
simingx is offline Find More Posts by simingx
Old Dec 14, 2003, 10:52 AM
Mi.Yutaka is offline
Find More Posts by Mi.Yutaka
M.Yutaka
Mi.Yutaka's Avatar
Gifu_Japan
Joined Dec 2003
Since I had care, please let me say.
There is the talk that a teacher of the university of an acquaintance said the other day.
[They are about brushless DC motor (it is also called DC brushless motor.)the following, "BLDCM", and a brief sketch.]
*Point out that with which the inverter and the permanent magnet form synchronous electric motor were united. A permanent magnet form synchronous electric motor is also called PM motor. PM is the initial of Permanent Magnet.
*When using BLDCM, input a direct-current power supply. It is changed into exchange by the inverter and a motor is driven by it. Since the input power supply of BLDCM is a direct current, although it is classified into the direct-current motor, it is classified into an exchange motor according to a motor simple substance.
With books that I read, the definition of a synchronous motor was what is depended on a rotation principle. I think that what Takao told about is that from which implications are a little different.
If I committed impoliteness, please allow.
Thanks.
Yutaka
Mi.Yutaka is offline Find More Posts by Mi.Yutaka
Old Dec 14, 2003, 11:10 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
Re: CD-ROM motor RC Prop. torque meter
Originally posted by Takao Shimizu
I hope that my torque meter has good accuracy.
The calculation(Torque x RPM) says that my CD-ROM motor's efficiency is 75%.
Wow, great results!
Really great for such a small motor.
mmormota is offline Find More Posts by mmormota
Old Dec 14, 2003, 11:13 AM
rysium is offline
Find More Posts by rysium
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Re: Re: Brushless mystery uncovered - part two
Who said that?
Takao [/B]
Please see the link http://members.chello.se/modellflyg/guide5.htm.
Scroll down to the end of the page to see the explanation how brushless motors work.
RysiuM
rysium is offline Find More Posts by rysium
Old Dec 14, 2003, 05:19 PM
JRW21 is offline
Find More Posts by JRW21
JRW21's Avatar
Dunlap, Illinois, United States
Joined Aug 2003
Ok, what type of glue can be used on this motor that won't destroy the magnet wire? I know C/A is bad for the wires.
JRW21 is offline Find More Posts by JRW21
Old Dec 14, 2003, 10:49 PM
Tokyo, Japan
Joined Nov 2002
Re: Re: Re: Brushless mystery uncovered - part two
rysium,
>Please see the link >http://members.chello.se/modellflyg/guide5.htm.
RC airplane BL motor does not run with constant RPM.
As, slowdown with going Vertical, High up with dive flying same as brush motor.
Therefore, that is absolutely incorrect explanation.
http://www.rcgroups.com/forums/showt...threadid=70373
Takao
Old Dec 15, 2003, 01:56 AM
rysium is offline
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Re: Re: Re: Re: Brushless mystery uncovered - part two
Of course it's not running the same rpm. The examples I have given were to compare two identical motors (size, design etc.) under the same test conditions.
Going vertical = more load, Diving = less load. It;s true that under different load RC BL motor turns different rpm (on the same throttle position and the same input voltage). But it doesn't mean it's not a synchronous motor. It is. It still turns the same speed as the frequency give by ESC. It's the ESC who is addjusting controling frequency to the given load. If ESC wouldn't do that, the motor would fall out of the sync when the load is bigger than the max torque of the motor.
The deffinition for synchronous motor is, that the magnetic field of the rotor is all the time in sync with the rotating magnetic field of the stator. And that is exacly what happens in the RC BL motors.
The design of DC-ROM conversion allows us to turn rotor 6 times slower than the frequency of ESC but it's total different story, and it's been explained already a couple times.
As I said, the ESC for BL motors is "smart enough" to sense the motor timing angle and when the motor is about jump out of sync, ESC lowers the frequency allowing the motor to draw more cureent, so the motor increases the torque loosing the rpm at the same time.
I hope this explanation helps.
RysiuM
Old Dec 15, 2003, 06:22 AM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
I just got my CDR motor running Here are some quick specs
24.6mm stator
20t .42mm wire/ delta wind
no load current .4amps
7x6 prop I took it up to 10 amps about half throttle much higher than I wanted so I'm going to change it to star wind and see how it does. I ran it yesterday with 25t .27mm Star wind and was pulling 5 amps on the 7x6 prop which was right about where I wanted it but I wanted to do some more playing around before I finish it off and mount it on somthing If nothing else these little motors are fun to play with.
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old Dec 15, 2003, 08:47 AM
Tokyo, Japan
Joined Nov 2002
Re: Re: Re: Re: Re: Brushless mystery uncovered - part two
rysium,
[/i]
[/QUOTE]
Sorry, I miss understand. I could say "And that is exactly what happens in the RC BL motors and RC brush motor". And I do not want to call them "synchronous motor".
Every time, I write ESC software to adjust the timing condition to supply the next power feed timing, not for any synchronization.
Takao
Old Dec 15, 2003, 09:05 AM
Greebe is offline
Find More Posts by Greebe
radar jammer
Greebe's Avatar
Bradenton, Florida
Joined May 2003
You'll find that many of us will not be conviced these are not AC synchronous motors as they are functionally made the same. Most manufactures claim the same.
Just because a controller is used to vary the speed/timing means nothing to the motor in general. The two should not be confused.
Greebe is offline Find More Posts by Greebe
Old Dec 15, 2003, 09:52 AM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
Re: Re: Re: Re: Re: Re: Brushless mystery uncovered - part two
Very nice circuit diagram, thank you. Clean, simple, practical. With a good firmware it will be the best homemade brushless controller for sure, competitive to the production types. Congratulations!
This extremely simple sensing part is really enough for the firmware?
Old Dec 15, 2003, 10:50 AM
rysium is offline
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Takao
Now I have a question:
As I mentioned before the most of the motor's losses are in the motor's core and magnets (Hysteresis losses, Eddy current losses). So to improve the motor efficency we can use coreless stator. It make peffect sense for outrunners where the magnetic field from the stator will not go outside the rottor, so we don't need the ferromagnetic core to direct the magnetic field.
At the same time magnets in the rotor have fixed and limited strength that limits the maximum torque provided by motor. To be able to increase the torque we would need the stronger magnetic field in the rotor. There are two possibilities:
1. Use electromagnets (like in the big scale synchronous motors), but then the motor will not be brushless any more - it will need brushes to deliver the power to the rottor.
2. Build 3-phase induction motor (the cage type). The good thing about this solution is, that it delivers the torque under the load (without "smart controler"). The ESC would be simple throttle to frequency converter, and the motor will do the rest.
So my bet for best RC BL motor is: Brushless, coreless, induction outrunner. It's light (no magnets or iron core), without energy losses except for the resistance of stator wire and resistance of rotor's cage. Low maintenance (just bearings), with very simple controler (variable frequency 3-phase inverter).
What do you guys think: will I get the Nobel Prize for that
RysiuM
Old Dec 15, 2003, 02:20 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Re: Re: Re: Re: Re: Re: Re: Brushless mystery uncovered - part two
Interesting ideas, but since this topic is about converting CD-ROM motors in one hour could you please start another thread. You may want to move these posts over there.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Dec 15, 2003, 07:12 PM
acvar is offline
Find More Posts by acvar
Joined May 2003
Re: Re: Re: Re: Re: Re: Re: Re: Brushless mystery uncovered - part two
Rick.
True enough, but maybe a better question is has anybody converted a cdrom motor to an inductance motor? Copper wire is definatelly cheaper than magnets and the controller would probably be cheaper also.
acvar is offline Find More Posts by acvar
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 07:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 09:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
