Old Jan 26, 2004, 12:50 PM
sousap is offline
Find More Posts by sousap
Joined Jan 2004
and the HD one...
sousap is offline Find More Posts by sousap
Old Jan 26, 2004, 03:07 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Re: 3 motors to rewind...
Originally posted by sousap
1-may you guys recomend me how to achieve a working solution for both CDrom motors?
2-how to make a twin CDrom motor, ie wind both stators and use both bells? and about the magnets for it? may I use two 5x5x1 to make one 10x5x1?
3-about the HD motor, how to wind it?
1- I've had good success with 28 ga wire in delta and star winding patterns. Having two similar motors, you could try both and compare the results with various props.
2- I've done a double stacked motor with a modified speed 280 bell, with two rows of 5x5x1. Glue one row first and let it dry. Be careful to maintain matching polarity on the second row
3- Go LRK: http://www.torcman.de/peterslrk/Wickel_arten_eng.html
Pierre Audette is offline Find More Posts by Pierre Audette
Old Jan 26, 2004, 07:31 PM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
The stator was too big to fit in the bell with 6 x 3 x 1.5mm N45s, so I made a mandrel for my Dremel from a 3mm CD-ROM laser tray guide and an MPJ 3mm prop adapter. I spun the stator in the Dremel, using a sanding block with 150 grit paper to sloooooowly shave the stator until it fit with < 0.5mm clearance all around.
Tony Turley
t-turley is offline Find More Posts by t-turley
Old Jan 26, 2004, 07:34 PM
t-turley is offline
Joined Mar 2001
While I'm sitting in front of the TV this evening, this will be my project:
Old Jan 27, 2004, 02:52 PM
azfrench is offline
Find More Posts by azfrench
Tucson Avra Valley, Arizona, United States
Joined Nov 2003
Ok, probably asked many times but this thread is so long that Im just going to ask again. What type of glue is used to secure the magnets in the bell? I have my magnets ready.. Thanks
Rick
azfrench is offline Find More Posts by azfrench
Old Jan 27, 2004, 03:00 PM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
I used medium CA (gap-filling) to secure the magnets. I may spread a little epoxy on them for some additional strength.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Jan 28, 2004, 10:16 AM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Links to rewind AirCraft motor
Let me try to summarise rough steps. 900 messages of 'One hour CD_ROM motor construction' in a message.
1, Remove bell from motor
Open the end to remove stopper from shaft in any way.
http://www.rcgroups.com/forums/showt...77#post1314377
or
http://www.rcgroups.com/forums/showt...65#post1069665
2, Remove stator from mount
The brass stator mount is tightly pushed to stator and iron motor mount. Hammer it out.
http://www.rcgroups.com/forums/showt...22#post1089922
3, Rewind
Unwind removed stator, rewind as the following. I suggest to start with 0.3 mm 39T or 0.35mm 29T or so.
http://www.rcgroups.com/forums/showt...36#post1089936
Connect to star. Delta draws 1.7 times more current.
http://www.rcgroups.com/forums/showt...79#post1069679
Wire to your ESC with proper connector.
You can try to spin the motor at this stage. It is recommended to remagnet for better efficiency and stability.
4, Remove original ring magnet from bell
The ring magnet is glued to the bell metal.
Burn
http://www.rcgroups.com/forums/showt...50#post1274250
or crack it
http://www.rcgroups.com/forums/showt...63#post1362963
5, Glue 5x5x1 mm magnet to the bell
12 magnet in NSNS... order. Use CA.
http://www.rcgroups.com/forums/showt...59#post1279959
6, Rebuild motor
You need to prepare motor mount. See below for an idea.
http://www.rcgroups.com/forums/showt...50#post1089950
Put stator and bell to original brass stator mount. Note we do use any stopper for the shaft. Magnet force will keep it in place.
Use your idea mount prop. Mr. Shimizu use 5 mm plastic nut and works great with APC prop. I replaced original shaft with GWS IPS/EPS shaft as attached.
http://www.rcgroups.com/forums/showt...91#post1069691
That's all!
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Jan 28, 2004, 11:30 AM
rysium is offline
Find More Posts by rysium
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Re: Links to rewind AirCraft motor
Not always . In my motor I measured the force that keeps the rotor. It's about 8oz. My motor can pull over 9oz when powered by 3 cell lipo. I tried it and the rottor flew away
It was OK from 2 lipos (static thrust is about 7.5oz).
RysiuM
rysium is offline Find More Posts by rysium
Old Jan 28, 2004, 12:02 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Frustrated ? You will be after this episode of cd-rom flight
http://www.bruessow.de/video/extrema.wmv (5.5MByte)
http://www.bruessow.de/video/mfk-muenster.wmv (16MByte)
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 28, 2004, 01:04 PM
Depdog is offline
Find More Posts by Depdog
Foam Flyer
Depdog's Avatar
Stockbridge, Georgia, United States
Joined Jan 2003
I would love to see a short clip of the pilots thumbs (or fingers depending on the way they work the Radio Sticks) while doing some of thos rolling harrier circles.
That was cool
Glenn
Depdog is offline Find More Posts by Depdog
Old Jan 28, 2004, 01:17 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Amazing.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jan 28, 2004, 02:18 PM
t-turley is offline
Joined Mar 2001
[B]4, Remove original ring magnet from bell
Burn
or crack it
If you have a female in the house, steal some of her nail polish remover, and soak the bell in some of that for about an hour. The magnet will pop right out - or at least, mine did. I suppose some mfgs could use a glue that is impervious to NPR.
Tony Turley
Old Jan 28, 2004, 03:00 PM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
airgap
I measured the same stator with two slightly different bells.
Stator: 18 mm diameter, 5,5mm length.
Bells: both machined low carbon steel, 12 pcs 5*5*1,5mm N45 magnets.
The difference:
stator 1: 0,5 mm air gap
stator 2: 0,25 mm air gap
(I learnt to believe in the accuracy of a precision lathe...)
The measured parameters are improved a lot with the smaller airgap:
bell1:
Kv: 1740
Rm: 1,21
Io: 0,32
bell2:
Kv: 1470
Rm:1,167
Io: 0,31
The Rm and Io is almost the same, but Kv lowered from 1740 to 1470. You may think that's not a big deal, but it is!!!
The Rm is the same, so if I modify the motor with lower turn number, thicker wire to get the same Kv, Rm will be about (1470/1740)^2*1,167= 0,83 ohm.
It means more then 30% less copper loss, that is a big improvement in efficiency.
This result clearly shows, that we have to keep the airgap as low as possible. Unfortunately it needs a more accurate bell and better bearings.
mmormota is offline Find More Posts by mmormota
Old Jan 28, 2004, 04:28 PM
rysium is offline
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Re: airgap
I guess, a little less than that. This is the same result as putting stronger magnets.
But I noticed you have over 1 ohm resistanc. It's a lot. Imagine you put 5Amp through, the power poss in the copper will be I^2*R that is 5 * 5 *1 = 25W. That's the total power I'm putting throuh my motor.
In my motor, and I used 26G wire 24 turn, using 0.4m per pole, so I used total 1.2m per phase. In delta connection my Rm = 0.08 ohm. Now if I put 5 amps throuht I'm loosing 2W in copper (and over 10W in iron ).
B.T.W. I gave my plane with Razor300 to my son, and I'm flying exclusivly other one with CD-ROM motor in board. Powered by 3s1p 700 LiPo I have 12-15 minuts doing torque roll, full speed snaps and rolls, waterfalls, climbing flat spins (straight and inverted) and so on. It's my personal 3D trainer - much better than any flight simulator. Anyway, after over 12 minutes of such practice I can notice, that it doesn't pull from torque roll as hard as it should. It's my cue to land. Battery usually is draind over 80% as it takes around 600mAh on charger(out of 700 capacity).
I will post some videos soon.
For now here is a picture:
RysiuM
Old Jan 28, 2004, 05:56 PM
burgan is offline
Find More Posts by burgan
Joined Mar 2002
rcall (or ne1) how much does the taig lathe ...
weigh?
is it portable enough to haul back and forth between a table top and a closet on a daily basis?
my space is limited (no basements here in texas) so i would need it to go back into a closet quite frequently.
thanks,
jeff
burgan is offline Find More Posts by burgan
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 07:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 09:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
